Question about Vehicle Parts & Accessories
Caliper 1998 nissan front
    Master:
  • 710 Answers
Yes
Posted on Aug 31, 2014
How to release brake caliper pressure on 2000 nissan sentra
Hi Shelby,what are you trying to do?To release pressure,get a wrench and open up the bleeder valve their,get a rag to catch the fluid.Here's a link to a diagram of the bleeder valve.Also here's another link on bleeding,Is your brakes sticking,you may need a new caliber. Repair Guides Front Disc Brakes Brake Caliper AutoZone com Here's how to bleed. http://www.autozone.com/repairinfo/repairguide/repairGuideContent.jsp?pageId=0996b43f80381ef5 Here's another link on replacing your caliber. Repair Guides Front Disc Brakes Brake Caliper AutoZone com Here's a link to a new caliber. Brake Caliper Front
Aug 26, 2016 | 2000 Nissan Sentra
How do I remove and replace front brake disc pads for a 1998 Nissan Presage 2.4 Litre cylinder
Jack the car corner your working on, remove the wheel/tire, use a c-clamp to squeeze the brake caliper and outside pad together pushing all the fluid back to master cylinder, remove the 2 slide bolts attaching the caliper to the bracket, slide the caliper off, replace the pads, pit the caliper back on and tighten the 2 slide bolts, now pump the brake pedal to get the fluid back into the caliper, put the wheel/tire back on and back on the ground. Same with other side. Your only problem is finding the c-clamp you need that's just large enough to squeeze the piston back in to begin with. Place the c-frame on the back of the caliper and the screw in part on the outer brake pad and turn it in till it stops. Gives you lots of room for removal and new pads will fit right in.
Sep 25, 2014 | Cars & Trucks
How i do replace the kit in the front calipers?
it is just as cheap to replace the caliper, than it is to rebuild them
Feb 18, 2010 | 1998 Nissan Pathfinder
How do you replace front brake pads on 1998 saturn station wagon
jack up car, remove wheel. take 2 bolts out holding caliper to caliper bracket. take old pads off, compress the piston until its flush with the caliper with a c-clamp. new pads on, grease the caliper bolts and bolt it back on. put wheel on, lower jack.
Dec 10, 2009 | 1998 Saturn SW
REPLACE REAR BRAKE SHOES ON 199 NISSAN ALTIMA
Have you tried a big c clamp and squezing it that way also try to loosen the emergency brake tensioner its in the back part of the brake assembly use a flat head to loosen it
Oct 28, 2009 | 2001 Nissan Altima
2001 brake pad replacement 2001 nissan quest
The hard part is pressing the caliper piston abck into the caliper so you can get the new, thicker pads over the rotor. A large C Clamp works best.
SECTION 206-03: Front Disc Brake 2001 Villager Workshop Manual
REMOVAL AND INSTALLATION Pads —Front Disc Brake Removal
  1. Remove the wheel and tire assembly. For additional information, refer to Section 204-04 .
  1. Remove the front disc brake caliper bolts. torx bit. T20?
  1. Support the front disc brake caliper from the front strut and spring assembly using mechanics wire.
  1. Remove the front disc brake pads.
    1. Remove the outboard front disc brake pad.
    1. Remove the inboard front disc brake pad.
Installation
  1. s1v~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Make sure the master cylinder reservoir does not overfill and spill brake fluid while retracting the front disc brake caliper piston.
    NOTE: It is necessary to fully retract the front disc brake caliper piston in the bore before installing the front disc brake pads.
    Install the front disc brake pads.
    1. Install the inboard front disc brake pad.
    1. Install the outboard front disc brake pad.
Caution. The outer pads are left and right. put left on driver side.
  1. Position the front disc brake caliper on the front-wheel knuckle and install the brake caliper pin bolts.
  1. s1v~us~en~file=ani_caut.gif~gen~ref.gif WARNING: It is necessary to depress the brake pedal several times to position the front disc brake caliper piston before driving the vehicle.
Apr 23, 2009 | 2001 Nissan Quest
Replacing brake pads on a 1998 Nissan Hardody
one bolt to remove, and the caliper will swing out of the way. Get a C-clamp and loosen the brake bleederand compress the piston back into the caliper. Tighten the bleeded screw & take the clamp back off after the bleeded screw is tighten!!!! When U purchase the pads, make sure the you get the jelley type, RTV the you put on the metal of the pad backing to keep the brakes from squeeling when you apply the brakes going down the road, Install the pads, and put bolt back on. Your finish, brake job done.
Jan 31, 2009 | 1990 Nissan Hardbody King Cab
1998 C1500 left front brake locks up.
Try replacing the brake hose to that caliper, they collapse on the inside.
Jan 12, 2009 | 1998 Chevrolet C1500
Vehicle Parts & Accessories Logo
12 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
