Question about Genesis Gx7 astra
Where can I get rear bike mounted rack that fits over a 29 inch wheel?
How do you replace the rack and opinion on a 92 cutlass ceira
Here you are - power rack & pinion.
Except 2.2L and 1993-96 3.1L Engines
See Figure 1
  1. Raise the intermediate shaft seal and remove intermediate shaft-to-stub shaft pinch bolt.
  2. Remove the air cleaner and disconnect the pressure hoses from the steering gear.
  3. Raise and support the vehicle on jackstands, then remove both front wheel and tire assemblies.
  4. Remove the cotter pins and nuts from both tie rod ends. Using tool J-6627 or BT-7101, press the tie rod ends from the steering knuckle.
  5. If equipped with an Air Management pipe, remove the bracket bolt from the crossmember.
  6. Remove the 2 rear cradle mounting bolts and lower the rear of the cradle about 4-5 in. (102-127mm).
WARNING
If the rear of the cradle is lowered too far, the engine components nearest the cowl may be damaged.
  1. If equipped, remove the rack and pinion heat shield.
Fig. Fig. 1: Power rack and pinion assembly
  1. Remove the rack and pinion mounting bolts, then the gear assembly through the left wheel opening.
To install:
  1. Install the gear assembly through the left wheel opening and install the mounting bolts.
  2. Install the heat shield.
  3. Raise the rear of the cradle and install the mounting bolts.
  4. Install the bracket bolt to the crossmember under the air management pipe.
  5. Install the tie rod ends to the steering knuckles, install the retaining nuts and insert new cotter pins.
  6. Install the front wheels and lower the vehicle.
  7. Install the high pressure hoses to the steering gear and install the air cleaner.
  8. Install the intermediate shaft seal and the intermediate shaft-to-stub shaft pinch bolt.
2.2L Engine
  1. Disconnect the negative battery cable.
  2. Install an engine support fixture J-28467-A, or the equivalent.
  3. Raise and safely support the vehicle.
  4. Remove the tire and wheel assembly.
  5. Remove the intermediate shaft lower pinch bolt.
  6. Disconnect the intermediate shaft from stub shaft.
CAUTION
Failure to disconnect the intermediate shaft from the rack and pinion stub shaft can result in damage to the steering gear and/or intermediate shaft. This damage can cause loss of steering control which could result in personal injury.
  1. Remove the exhaust pipe hanger bracket near rear of frame including the brake line retainer and rubber exhaust pipe hangers.
  2. Remove the engine and transaxle mount nuts at the subframe.
  3. Support the rear of the subframe with jack stands.
  4. Remove the rear subframe bolts and discard.
  5. Lower the subframe for access to rack and pinion.
Do not lower the rear of the cradle too far, as damage to engine components nearest the cowl may result.
  1. Remove the cotter pins and castle nuts from the outer tie rod ends and separate the tie rod ends from the steering knuckles using a suitable puller.
  2. Disconnect the power steering lines from the steering gear.
  3. Remove the rack and pinion mounting bolts and nuts.
  4. Remove the rack and pinion through left wheel opening.
To Install:
  1. Install the rack and pinion through left wheel opening.
  2. Install the rack and pinion mounting bolts and nuts and tighten to 66 ft. lbs. (90 Nm).
  3. Connect the power steering lines to the rack using new O-rings and tighten the fittings to 13 ft. lbs. (17 Nm) on the return line and 21 ft. lbs. (28 Nm) on the pressure line.
  4. Install the power steering line clip to steering gear.
  5. Connect the tie rod ends to the steering knuckles. Tighten the castle nuts to 31 ft. lbs. (42 Nm). Install new cotter pins.
  6. Raise the subframe into position and install new frame mounting bolts. Tighten the bolts to 103 ft. lbs. (140 Nm).
  7. Remove the jack.
  8. Install the engine mount and transaxle mount nuts and tighten to 39 ft. lbs. (53 Nm).
  9. Install the exhaust pipe hanger bracket near the rear of frame including brake line retainer and rubber exhaust pipe hanger.
  10. Connect the intermediate shaft to the stub shaft and tighten the pinch bolt to 29 ft. lbs. (40 Nm).
  11. Install the tire and wheel assembly.
  12. Lower the vehicle.
  13. Remove the support fixture.
  14. Connect the negative battery cable.
  15. Refill the power steering reservoir and bleed the system.
  16. Check the front end alignment and adjust as necessary.
3.1L Engine (VIN M)
  2. Remove engine torque strut from engine.
  3. Install an engine support fixture J-28467-A, or the equivalent.
  4. Raise and safely support the vehicle.
  5. Remove the tire and wheel assembly.
  6. Remove the cotter pins and castle nuts from the outer tie rod ends and separate the tie rod ends from the steering knuckles using a suitable puller.
  7. Remove the center engine and rear transaxle mounts from the frame.
  8. Remove the intermediate shaft lower pinch bolt.
  9. Disconnect the intermediate shaft from stub shaft.
CAUTION
  1. Remove the brace bolts and brace, including brake line brace.
  2. Support the rear of the subframe with jack stands.
  3. Remove the rear subframe bolts and discard.
  4. Lower the subframe for access to rack and pinion.
  5. Remove the steering gear heat shield.
  6. Remove the clip holding lines at rack assembly.
  7. Disconnect the power steering lines and O-rings.
  8. Remove the rack and pinion mounting bolts and nuts.
  9. Remove the rack and pinion unit through the left wheel well.
To Install:
  2. Install the rack and pinion mounting bolts and nuts and tighten the mounting bolts to 66 ft. lbs. (90 Nm).
  3. Connect the power steering lines to the rack using new O-rings and tighten the fittings to 13 ft. lbs. (17 Nm) on the return line and 21 ft. lbs. (28 Nm). on the pressure line.
  5. Install the steering gear heat shield.
  7. Remove the jack.
  9. Install the brace and bolts including brake line brace.
  11. Connect the tie rod ends to the steering knuckles. Tighten the castle nuts to 31 ft. lbs. (42 Nm). Install new cotter pins.
  12. Install the tire and wheel assembly.
  13. Lower the vehicle.
  14. Remove the support fixture.
  15. Connect the negative battery cable.
  16. Refill the power steering reservoir and bleed the system.
  17. Check the front end alignment and adjust as necessary.
Nov 01, 2015 | Cars & Trucks
How to replace rack an pinion cutlass ciera 1992
You aren't saying what engine is in it, or whether it is manual or power steering. Here is the R/R procedure for power steering rack for all engine sizes.
See Figure 1
WARNING
To install:
2.2L Engine
CAUTION
To Install:
  7. Remove the jack.
3.1L Engine (VIN M)
CAUTION
To Install:
  7. Remove the jack.
How can I lower my bike?
Fit a shorter suspension, maybe? Is it possible to attach the front fork 1-2 inch lower? You could mount a smaller wheel at the back, but the whole gearbox will be "shorter". If so you can keep the original gear ratios by mounting a smaller rear sprocket. The ratios of wheel diameters and teeth numbers should be the same, especially for a 125. Ask a mechanic.
Jul 21, 2014 | 2000 Aprilia RS 125
What size bolts does the rear frame take for mounting a bike rack
Since you probably need to go to a hardware store to get them anyway, you could just take the bike in and guarantee a good fit. They're probably metric. Make sure they're long enough. Get washers.
May 23, 2011 | Pacific International Pacific Evolution...
20 inch Slumber party bicycle will not accept training wheels? Rear threaded axle is not long enough to allow for training wheels (that i cna find)
Yes you can add training wheels to this bike. The origional axle is too short, however, if you are mechanical enough, you can remove the axle and buy a longer one. I did this for my daughters bike, and for abot 5 dollars you can pick up a longer axle which will accept training wheels. But be warned, there are several bearings and you need to place them back in the correct position or the bike will not work.
Dec 27, 2010 | Dynacraft Cycling
How do you install rear bike rack on a bike with disc brakes?
Depends. If it's a frame with the rear caliper inside the rear triangle the rack will usually bolt right on. If it's a frame with an IS mount caliper hanging off the back of the seatstay you will usually need a to use a longer bolt and a spacer to let the brake and rack share a mounting point. If it's a bike with a post mount brake you will probably have to improvise something. P-clamps can be helpful.
Dec 16, 2010 | Cycling
I brought a relaigh cordless cycle computer i think its a 12 function one for my old bike but now i want to put it on my new bike but my new bike has different wheels sized 26x1.50 but i have lost the...
26 inch wheel becomes 29 inches when you add on tyre depth ( 1.5 * 2 )
29 x Pi is 91 inches
Computer setting should be 91.2 inch or 2316 mm
Nov 29, 2010 | Cycling
Hitch mounted bike rack that doesn't seem to fit Envoy
there are draw bar extensions you can buy that will extend the rack beyond the tire. check with your local trailer parts store.
Jun 24, 2009 | GMC Envoy Cars & Trucks
Can't fit my rear axel
hi jenny,
what is the brand and model of your frame and your rear wheel assembly?usual fitting is better made with the bike mounted upside down, letting gravity make the balancing. but this is possible to most mountain bike, not most road bikes.
looking forward to your reply.
regards,
voodoo
Apr 19, 2009 | Cycling
Genesis Gx7 astra Logo
46 people viewed this question
Top Genesis Cycling Experts
rdjagger
ray gallant
dante
Are you a Genesis Cycling Expert? Answer questions, earn points and help others
