SOURCE: frigidaire affinity dryer problem
message "ad" showing on my affinity frigidaire, anything wrong with this?
SOURCE: how to replace fuse dryer frigidaire affinity
If it is like any other frigidaire dryer it is mounted on the upper right hand corner of the rear bulkhead.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
SOURCE: Frigidaire Affinity Electric dryer E68 error.
this is a fault code that means there is a stuck key on the board you may have to remove the control panel and check the keys if this does not work you may have to replace the panel or control board
Testimonial: "Thanks I relayed the information to my dad (I'm in CA and he is in FL) and he checking it out."
Hello friend, thank you for your post!
Based off the information you have provided, I understand that your Frigidaire dryer is displaying an "E52" code and the dryer will not start. Typically an "E52" code stands for motor fault, I would attempt to perform a reset on your appliance by disconnecting power for roughly ten minutes. After the reset if you are still receiving the error code I would recommend having a professional come out to diagnose and repair the appliance. Best of luck. -Matt
