Question about Clothing Accessories
How to find 793D intermittent harsh auto retarder
80% of the time the retarder operation is fine but the other 20% it either holds on for too long or applies itself very harshly,
  • 23 Answers
SOURCE: 96 Ford Contour CD4E Auto Trans.
The item referred to needing adjustment in the previous reply is called the MLP (manual lever position sensor). It tells the computer electronically that the car is in P, R, N, D, 2,1 (depending on the gear selector) It also allows the car to only be started in P and N for safety.
If it is out of adjustment, the sensor is misaligned with it's reference point on the gear selector rod, which goes into the trans case and pushes/pulls a rod that moves the selector piston/valve. The valve will be in the right place but the computer will say other wise and it controls the shifting with the solenoids.
SOURCE INFO:
{MLP transaxle function: determion desired gear and electronic pressure control (EPC) pressure:
Symptoms: Harsh engagements and firm shift feel, engine may not crank, may downshift to a lower gear, 2nd or 3rd gear operation, transaxle not inicating the proper gear, no 4th gear operation. no manual first gear.}
Another point of interest is the EPC (electronic pressure control)solenoid inside the black side cover.
Failed OFF-maximum EPC pressure, harsh engagements and harsh shifts.
Another possible issue may just worn out clutches if the unit has high mileage or maybe verify fluid level and recent change of fluid. The filter is inside unit and trans has to be removed to change, some Hondas are like this too.
Posted on Jul 29, 2008
bozcro
  • 867 Answers
SOURCE: 07 street glide 15000 miles bad vibration at 1100
have a good look at all the engine mounts, top, bottom and to tranny.maybe a cracked mount.make sure all bolts are tight
Posted on Jul 30, 2009
  • 44 Answers
SOURCE: 2000 Discover TD5 Auto harsh vibration under power at 2000 -2500
The "lift off and it goes away" is the clue I feel. This eliminates engine out of balance issues and points squarely to fueling issues. I would say try a compression test (always a good first start before you try much else) but with plenty of power and no vibration except in the range, probably not a compression issue. So, what's left? Fuel or air is the answer. Check air inlet path is from air filter to turbo and (more importantly) from turbo to intake manifold. Check wastegate on turbo is OK - disconnect the wastegate (it's bolted on to the turbo) hose, then **** on the wastegate hose, you should feel resistance. If not wastegate aneroid has perforated. At this point, I suggest taking it to a LR dealer and get them to pull all the engine codes. If all OK, next step is injectors. It's a common rail diesel and removal is a bit tricky, but if you pull them out, you will often be able to see a single injector with all the carbon deposits around it. If all injectors look the same, suggest that at this point you need to take them to a diesel specialist for testing and calibrating. This process usually cures 70% of diesel misfire problems. The other 30% really requires specialist knowledge of your vehicle's engine.
Posted on Jul 31, 2009
  • 29 Answers
SOURCE: it smells like something is burning smells like
If it smells like an incomplete combustion smell, clean the burner first. I'm assuming it used to work and now doesn't? If it never worked correctly it may have the wrong jet in it. There is a jet for propane and one for natural gas. They do not interchange. If it smells like plastic burning, something probably got past the screen and fell into the burner.
Posted on Sep 28, 2009
ebjebs
  • 197 Answers
SOURCE: harsh shifting on a 4t65e trans how to repair
You can the info you need here also a little of any thing you need to know. http://aa1car.com/
Posted on Feb 28, 2010
Testimonial: "Thanks big time help"
I put a 80-81 Cdi on a 82 xlh, runs but backfires should I advance or retard
probably retard it a bit but I don't think it is the timing
You say it runs and backfires but if the timing was too far advanced it would backfire on starting and be difficult to start
I suspect the fault to be electronic ---like a loose wire on the coil , faulty coil, faulty ignition control module, loose wire at ignition switch, loose ground wire , loose ground wire on battery
look for something that is making and breaking contact at random as that action induces a spark at the wrong time
Feb 27, 2016 | Motorcycles
What is the knock sensor function for
the knock sensor adjusts the timing, advances/retards the in case the engine : knocks , retards or diesels
Jan 09, 2015 | Cars & Trucks
1989 chevy s10 power window intermittent problem.
Your power windows run on a heat operated circut breaker. When temps get warmer, an old breaker can act up. Try replacing the breaker and see if it cures your problem.
Jan 08, 2014 | 1989 Chevy S10 Pickup Outer Window Sweeps...
Ravenheat 80/20 boiler. the boiler looses water pressure but only when working in central heating mode. Boiler holds pressure indefinitely if central heating is not used,hot water can be drawn without a...
Hi, your boilers pressure should be holding 1.5 bar with the relief set about 3. If the pressure is below this the flow switch will cause the boiler to stop as theirs not enough pressure to operate. Another thing, does your boiler have an auto fill system or do you need to plug a hose in to fill it? If its an auto fill system and you lose pressure you could have a leak.
Sep 15, 2013 | Water Heaters
Effect of wrong timing
cam, well that depends on DIRECTION
retarded would cause, lower compression and power.
advanced can be more power fast but not slow.
really that is what VVT does, runs one way for slow, and other for fast.
why do you ask.
curious
yours is?
why not check compression,
if the belt slipped, most go to RETARD.
can moves fast and cam says, i dont wont to and it slips,
the crank over runs the cam. so very easy, with belt.
it retards and compression can fall from 150+PSI to 80,
and engine acts like 1Liter , pip squeak engine.
Jul 13, 2013 | 2003 Honda Stream
Hello i have a 1993 chevrolet silverado 1500 and i jus replaced the fuel pump and the distributor and now it wont stay running and it back fires can u tell wat might be wrong
Hello theman022002,
Your description would indicate that the timing is off. Possibly when you installed the new distributor you were off a tooth or two. Turning the distributor Will Not adjust the timing.
You will need to reinstall the distributor with every thing set to top dead center, then follow the steps below to set the proper cam retard offset.
Good Luck.
Ignition Timing: Adjustments
TEST PROCEDURE
The ignition timing cannot be adjusted. The distributor may need adjusting to prevent crossfire. To insure proper alignment of the distributor, perform the following:
1. With the ignition OFF, connect the scan tool.
2. Start the engine. Allow the engine to idle until the engine reaches normal operating temperature.
IMPORTANT: Cam retard Offset reading will not be accurate below 1,000 RPM.
3. Increase engine speed to 1,000 RPM while performing the following steps.
4. Use the scan tool in order to monitor the Cam retard Offset.
5. If the Cam retard indicates a value of 0 degrees, the distributor is properly adjusted.
6. If the Cam retard does not indicate 0 degrees, the distributor must be adjusted.
ADJUSTING PROCEDURE
1. With the engine OFF, slightly loosen the distributor hold down bolt.
2. Start the engine and raise the engine speed to 1,000 RPM.
3. Use the scan tool in order to monitor the Cam retard Offset.
4. Rotate the distributor as follows:
a. To compensate for a negative reading, rotate the distributor in the counterclockwise direction.
b. To compensate for a positive reading, rotate the distributor in the clockwise direction.
5. Repeat step 4 until 0 degrees is obtained.
6. Turn OFF the ignition.
NOTE: Refer to Fastener Notice in Cautions and Notices.
7. Tighten the distributor hold-down bolt to 3 N.M. (25 lb ft).
8. Start the engine.
9. Raise the engine speed to 1,000 RPM and with the scan tool view the Camshaft retard Offset to verify 0 degrees has been maintained.
Regards,
netvan
Apr 10, 2011 | 1999 Chevrolet Silverado 1500
When trans. is warm after extended driving the up shifts are very hard. This only happens during extended driving periods. Around town everything shifts fine.
Shift suddenly become very hard. When going from park to either reverse or drive it slams into gear. 1-2 and 2-3 shifts are also harsh. All gears seems to work. Problem may be intermittent: Check Throttle Position Sensor (TPS) for smooth electrical response. If the response is jumpy or erratic at all, replace TPS. Good luck Auto Zone or Parts Source has this part and can be replaced with in 20 min. Both parts store will have the step by step instructions and i believe the cost is around $65.00 for the TPS which is better then a transmission replacement.
Nov 30, 2009 | 2000 GMC Yukon XL
1993 build Audi 80-B4 2.6E ABC V6 engine. 1. Temp gauge intermittent - some say there was a generic problem with the contact on rear of instrument panel. Is this hard to access ? 2. Starts ,runs, travels...
Can you manually rock the engine by hand? If so then although the mounts look ok the rubber bushing are worn out. It is best to replace with factory ones as aftermarket polybushes will be too harsh for a car that is used as a daily driver.
Aug 16, 2009 | 1992 Audi 80
Clothing Accessories Logo
15 people viewed this question
Top Clothing Accessories Experts
Da Doc
ray gallant
Tom Chichester
Are you a Clothing Accessory Expert? Answer questions, earn points and help others
