Question about Best Data Products Smart One 56k USB Windows Mode. (56USBSL) Modem
Best data 56usbsl win7 - Best Data Products Smart One 56k USB Windows Mode. (56USBSL) Modem
Am 81. Not computer savvy. Do e-mails and genealogy. Had XP, but now Windows 7. What laptop is best for an older, limited user. Have genealogy saved on 3.1 inch disks and FamilyTreeMaker progra
If you have Win7 Ultimate and access to an external floppy drive, it is possible, with some reconfiguration, to run Win7 Ultimate in XP mode. You need to employ the assistance of a computer savvy tech. It is not the easiest thing to set up and will not work on any other Win7 OS.
Jan 24, 2015 | Computers & Internet
How do I replace win 8.1 with win 7 enterprise
If you have the Win7 software discs and the product key you should be OK. I'd backup all of your data, then using the Win7 disc, full format the drive and install Win7. Be sure your BIOS is set to boot from the CD/DVD ROM.
Apr 30, 2014 | Dell Inspiron 1420 1520 1521 1525 1526...
Can I boot from a SATA drive and access pre-existing SCSI Drives?
You need to install the driver of your scsi controller for win7/64. Then you'll see your datas on win7.
Jul 08, 2012 | Dell Precision Workstation 670 PC Desktop
My volume and av mode touch pad do not work after i format and upgrade my laptop to window 7, vgn cs-16g
you will need the soundcard driver for Win7...for that you need to know the sound chip of the motherboard....if you Win7 is not original you can try the WinXP soundcard driver that came with your PC / motherboard
the best is to ....
if your Win7 is a valid original copy....!!!
go to MS website and register your Win7 copy and do an update....
the auto update will download the driver and install it
reg
kris
www.sureshayyar.110mb.com
May 08, 2011 | Computers & Internet
How to install the epson stylus TX100 scanner to my computer?
What OS does your computer have? Go to the Epson support site and download the software for your OS: http://tech.epson.com.au/downloads/category.asp?sCategory=Multi_Functional&id=StylusTX100&EmailAdd=&CanEmail=&SelOS=Y&MetricIDReturned=4036965&sCategory1=Multi_Functional and use the drop down menu to choose your OS. (With Windows 7, I know that the drivers are included in the OS so you can skip this step.)
For best results use a direct connection, with a USB cable that is 6' long or shorter.
Install the full software if it is available for your OS. Then when prompted to do so, make sure the printer is on and connect the USB cable between the printer and the computer. If needed, restart the computer.
In the case of Win7 or any other OS with these drivers included, just set up the printer and plug in the data cable. However, if the drivers are not included in the OS, then the printer may work after plugging in the data cable but the scanner probably won't. In that case, uninstall the generic driver, unplug the data cable. Then reboot the computer and install the one from the Epson site.
See the Epson support site for using the printer's software package. Please note that the buttons on the front of the unit will not work for initiating actions on the computer unless the full software is installed. Thus for Windows 7, you will need to launch your scans from the computer. Paint, Windows Fax and Scan and Photo Gallery (in Live Essentials) all can acquire scans. Some of these programs are also available for and will acquire scans in XP and Vista. (Paint is in XP, Vista and Win7; Photo Gallery comes with Vista and is available for XP and Win7; Fax and Scan is in some versions of Vista.)
I hope this helps.
Mar 16, 2011 | Office Equipment & Supplies
I BOUGHT TOSHIBA SATELLITE A-100---234 FROM SAUDIARB WITH WINDOWS XP,,,,,,,I CHANG ITS WITH WINDOW7 AND NOW SOUND QUALITY IS REALLY BAD PL. HELP ME
Win7 does not come will all rquired drivers as XP did
you need to register with MS wesbite and make your copy of Win7 legal only after authentication they will allow you update your copy of Win7...after all updatesa are loaded the system works perfectly
So if your Win7 copy is a leagal one go and register in MS webiste and download all updates...
all the best
Reg
Kris
Feb 08, 2011 | Toshiba Satellite L455D-S5976 Notebook
I upgraded computers and now have windows 7 so my printer will not work how can i get my printer to work with this new computer
You need the Win7 driver, available here: http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=&cc=us&product=2512008& . If your printer has been connected to the computer (data cable), you may need to uninstall the generic OS driver that was installed. Then unplug the data cable, if USB, and install the Win7 software. (A full software version is available and I recommend that since you will be able to use the Toolbox to check your ink levels among other features.)
If you use the generic driver, some of the printer features should still work. You need at least the basic HP driver to run the scanner.
I hope this helps.
Jul 21, 2010 | HP Officejet Pro L7580 All-In-One InkJet...
I have an issue with my Flatron the colors are different, what do i have to do. Im using windows 7
Win7 is still not fully compatible with many of the exisiting Hardwares....as most of them are old HWs that were mfgd some years ago, it will take a lot of time for Win7 to be fully compatible....
for most HWs it may require a new driver but many mfgrs are not making any new drivers as they plan to mfg new HWs for compatible with Win7.....
the best option is to have dual boot of both XP(C:) and Win7(D:)
that way...you always have the trusted XP to fall back if any issue with Win7...i am having dual boot....
May 05, 2010 | LG Flatron L1718S LCD Monitor
The os win7 is not compactible with my softwares
many softwares are still not compatible with Win7....
so the best is to have 3 partitions and use one partition for you safe keep of data and the rest of the 2 partition for XP and Win7...multi-boot....kee using Xp with the current softwares and have win7 for the fun of having it...and keep adding the softwares to Win7 as they keep comming up...
C: XP
D: Win7
E: your critical Data
F: CD/DVD drive
and etc
Apr 27, 2010 | Compaq Presario Notebook
I can't load Windows XP. Get this error with BLUE SCREEN of DEATH IRQL_NOT_LESS_OR_EQUAL I had windows 7 on it but not all of my devices would work. Win-7 loaded with no problem . So I put XP in format and...
Good day!That error used to be a non compatible with the hardware.I don't know this board,but i'll based my idea on your trouble..Mostly new hardwares today don't accept XP OS..Try to look the Motherboard's features..see if it is compatible with XP..
Ask me if you still don't get what I mean..
mastergani
Mar 21, 2010 | Intel DP45SG Motherboard
Computers & Internet Logo
47 people viewed this question
Top Best Data Products Computers & Internet Experts
David Payne
David Payne
Are you a Best Data Products Computer and Internet Expert? Answer questions, earn points and help others
