Question about Whirlpool 24 in. DU1100XTPS Built-in Dishwasher
Loud humming when started - Whirlpool 24 in. DU1100XTPS Built-in Dishwasher
Loud clunk when i try to start truck
Turn the headlights on, and try it. Do they get real dim while try ing to crank it?
Feb 29, 2016 | 2003 Chevrolet S-10
High pitched humm
Need more info on the vehicle please.
May 13, 2013 | Cars & Trucks
Loud hum
hi,
Sorry, a load humm is indicatrive of blown output transistors. If it is still playing, but have a load humm, there is a PSU problem. Haver it fixed or the probem will get MUCH bigger!
Sep 04, 2011 | Koss KS3151 System
My microwave makes a loud humm when turned on and does not heat the food. If I put in another mode, Meat, it sounds normal but after a mmin it starts to make the same humm. ???
You most likely have a bad high voltage diode. (Item F1 of link but labeled rectifier)
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5154395
However... there are two other possibilties those being the High Voltage Capacitor (F2 of link above)
and the Magnetron istelf. (F7 of the link above)
More often than not the diode / rectifier is the problem.
Thanks for using FixYa.
Kelly
Mar 19, 2010 | Frigidaire PLMV169DC Microwave Oven
No heat when Microoven is turn on. GE XL1800 Spacemaker
If there is a loud humm the magnatron tube has gone bad. and some times there is no humm at all but i would say its the mag tube has gone out.
Jun 13, 2009 | GE JVM1850 1000 Watts Microwave Oven
Whirlpool Inglis washer super capacity, 8 cycles, 2 speeds. Bought in May 2008. Works well and washes well, but it is VERY loud and seems to be getting louder and now there is a faint rubbery smell when it...
I received an Inglis Washing machine from soneone on freecycle. They thought the belt had broken, doesn't have a belt, it's gear driven. I'd bet the noise you hear is the coupling going out, (rubber). Good luck.
Jun 11, 2009 | Amana 3.2 cu. ft. Top-Load Washer
Loud humming noise
The power steering pump humms when it has gone bad.
You need to replace or service it incase there is a blockage due to dirt in the transmission oil compartment.
Costs not so much.
Rate this please.
May 23, 2009 | 2003 Chevrolet Trailblazer Ext
I have a loud humm in my bose lifestyle 28 system
Turn on your bose so you can hear it hum. Go to the back of your cable box and remove the co ax cable connected to "cable in". If the humming stops, the sheilding on your cable is no longer grounded. Purchase MPAV800 or similar surge protector to run cable line through it and get it grounded.
Feb 02, 2009 | Bose Lifestyle 28 System
Microwave no heat
The "HUMM" indicates a breakdown in the High Voltage Side. The loud "POP" was the breakdown. You have only four Components in the High Voltage side.
1. High Voltage Transformer. You can eliminate this as the problem. Why? If it was the problem it would have blown the line fuse, and would have given off a burned transformer smell.
2. High Voltage Diode. Usually will Burn or Pop when shorted, but will then OPEN the Circuit and there is no "HUMM".
3. High Voltage Capacitor.This is the Silver Can with the two terminals on top. It can SHORT internaly between the plates (the two terminals) and give the "HUMM".
4. Magnetron. This is my number one suspect. A SHORTED Magnetron.
Feb 03, 2008 | Kenmore 63652 Microwave Oven
HUMM in phone line(modem)
turn off the mic or the extrernal speaker if this dosent work there might be a problem with the phone cord or your house wires
Dec 25, 2007 | HP Pavilion dv1000 Notebook
Whirlpool 24 in. DU1100XTPS Built-in Dishwasher Logo
13 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
