Question about Dell UltraSharp 1504FP 15" Flat Panel LCD Monitor
Dell 1504FP hdmi
Is it possible to have a dvi to hdmi converter and connect the dvi port onto the screen and run and a hdmi to the PS3?
    Problem Solver:
  • 19 Answers
It doesnt matter how many different ways you connct the monitor it will only support one input at a time
Posted on Nov 23, 2014
4 Suggested Answers
Geekman
  • 32281 Answers
SOURCE: My Dell SP2208WFP will only display for 1 or 2
You could have a back light problem. this can be caused by a faulty inverter circuit board or a faulty CCFL lamp.
For LCD parts check out these WEB sites.
LCD screens and Inverters
www.lcdparts.net
http://www.yallstore.com http://www.shope2.com/ http://www.invertercentral.com/qrySearch.asp?Adword=1500&search=1500&Campaign=Google-Models-NA&gclid=CO3lg7HJlKMCFQcbewodZB2qoQ http://www.nylaptopparts.com/http://www.ccflwarehouse.com/
Posted on Nov 25, 2010
frankgilbert
  • 613 Answers
SOURCE: the image on my dell U2711 ultrasharp monitor
Well if you have a warranty please send it back before you damage it and then don't get anything. See if it has a screen reset button on the front or back such as factory reset. Hope this helps.
Posted on Jan 05, 2011
  • 51 Answers
SOURCE: If you add a DVI adapter to the the DVI cable
For the best results, you a straight DVI cable.
VGA is analog, while DVI is digital. The quality will not be as good a a regular DVI cable.
You can use a DVI to HDMI.
I use one going from my PC to TV and the quality is awesome.
Posted on Mar 03, 2011
Testimonial: "Excellent! Thank you for your quick response!"
My monitor(HPL1950) was working good until i unplugged it to play on PS3. When i connected the monitor to my PS3 with HDMI it showed black screen. There is photo showing the screen. Help please
If your cennecting using an hdmi to dvi then you might want to check that your ps3 is only sending video and not video and sound as not all screens have a dvi port that supports sound and dvi. Also it could just be a resolution issue. Try having the resolution of your ps3 to 720 or possibly lower and see what happens. Then if all good work your way up to find what your monitor can handle.
Nov 07, 2015 | Video Game Consoles & Games
I have a raspberry pi 2 and i want to connect it to this monitor emprex 1704 it doesn't have a dvi,hdmi port or a vga?
Wait, the monitor does not have a DVI port, an HDMI port, or a VGA port?
The only other option I think the monitor could have is S-Video or composite, which would be astounding if that's the case. You can use a HDMI-DVI converter from your RasPi to get out to DVI, then a DVI to VGA converter to get to VGA, but I'm not aware of a VGA to S-Video or composite converter.
Oct 01, 2015 | Emprex Computers & Internet
How can i watch tivo on my computer monitor
Sorry to say but no, your monitor only has VGA which is an analog signal and HDMI is a digital signal. A cable will not convert between the two. There are digital to analog converters available but they run more than a new monitor. You can use any monitor that has a DVI port with an adapter cable because the DVI port is digital just like the HDMI port so a cable can convert the plug between the two and the signal will then be the same.
Nov 16, 2012 | Computers & Internet
I need to connect a VGA dell monitor my Toshiba Laptop
HDMI is digital
VGA (the 15 pin connector) is analog.
If your connector has the digital to analog interface it should work, but likely it does not have that chip and thus will not work.
Your description of the problem tells me it may never work as you have it connected. Possibly it might be that the monitor is required to be powered on before the laptop is booted, but that only works in some cases.
I have also seen some work if a 2-step connector is used.
VGA to DVI connector, followed by DVI to HDMI connector.
DVI was the step toward digital that came before the HDMI standard was implemented and was only partially digital. DVI and VGA do not carry control signals nor audio. HDMI carries both those as well as the video.
YMMV but I think it would be cheaper and more efficient to actually purchase a monitor with a digital input (HDMI or DVI).
Without the digital/analog converter interface a digital output device (your laptop with HDMI out) can never operate an analog device (your Dell monitor with VGA input).
Mar 12, 2017 | Dell E193FPp 19" TFT LCD Flat Panel...
How can I connect PS3 to ACER X110P Projector
does the projector have an HDMI port?
i would buy the cable that is HDMI from the PS3 (unless it has HDMI already)
HDMI converter (HDMI to DVI or VGA) typically don't work well because you are changing the signal from digital to analog through a cable. you want to use a cable that is the same on both ends.
Nov 09, 2012 | Acer Computers & Internet
Can i play ps3 on Dell Ultrasharp 1504fp monitor?
The PS3 cannot connect to a monitor because it does not have a VGA output or a DVI output for a monitor
Feb 13, 2011 | Computers & Internet
I am trying to connect my macbook pro computer to my Panasonic Viera using a VGA > HDMI converter, connected through to the HDMI port on the TV. The TV screen remains black on the HDMI setting. I...
On the MacBook, check the Displays pane in System Preferences to make sure the settings for the external monitor are correct. It's possible that the system is not recognizing the adapter or it has the wrong resolution setting, so it's not sending out any signal that the adapter can use.
Many of the better DVD players and high-end video game consoles use HDMI. You can use one of those as a test signal generator to check the TV.
You may get better results if you use a DVI-HDMI converter, although you would need to get the DisplayPort to DVI cable. This will avoid converting to analog VGA signals and back to digital again.
Oct 13, 2010 | Panasonic TH-42PD50U 42 in. Plasma EDTV
How do I connect my dell laptop to my LG LCD TV
1. S-Video – This is probably the most common method out there currently because an S-Video cable is cheap as heck and just about every TV under the sun has a S-Video port. You’ll have to make sure you laptop is equipped with this port. Remember, there are two types of S-Video cables: 4-pin and 7-pin. Most laptops and PC’s are equipped with a 7-pin port, so if your TV only has a 4-pin S-Video port, then this method will not work.
2. VGA – If you have a HDTV, then you will be better off connecting using a VGA cable. It gives much better quality than S-Video and as with S-Video, the cable is very cheap. You usually won’t find a VGA port on regular TV’s though, so this option is if you have an HDTV.
3. DVI - DVI stands for Digital Visual Interface with “digital” being the key word there. The digital signal will give a higher quality picture than either S-Video or VGA. Of course, your computer will need to have a DVI connection and your TV will need to be an HDTV. This cord is definitely not cheap, it ranges anywhere from $40 to $80.
4. HDMI – Using HDMI will give you the best quality by far. No computers that I know of yet have HDMI ports, but you can get a DVI to HDMI cable to connect it to your HDTV. HDMI is compatible with DVI.
5. Scan Converter Box – This is the last method that I could think of and it involves using a scan converter box, which takes a VGA signal and converts it into S-Video or component video.
Here’s a graphic I created with some pictures of the various cables:
May 30, 2010 | Dell Latitude E6500 Laptop
What cables do I need to connect my toshiba satellite m55 laptop to my hi def tv?
This really depends on the connectsionon your hi def TV. The laptop doesn't have an HDMI port (these ports carry sound and video in one cable), but it does have a VGA out port as well as a s-video out.
You can connect an s-video cable from your laptop to your hi-def TV, if the TV has an s-video input port.
You can also purchase a VGA to Component converter if your hi-def TV has component inputs, these are the Red, Green, Blue inputs. Amazon sells these, here is a link: http://www.amazon.com/Premium-VGA-Component-Cable-Black/dp/B000RJLSZU
If you have a DVI input you can purchase a VGA to DVI converter as well. These are very inexpensive and you can find a wide selection on Amazon, here: http://www.amazon.com/s/ref=nb_ss?url=search-alias%3Delectronics&field-keywords=vga+to+dvi
Finally, you can also purchase a VGA to HDMI converter. This would be the most expensive option, but you can use this box to put both sound and video from the laptop onto the HDMI cable. YOu would need both the converter and cable for this to work. Converter is here: http://www.amazon.com/VGA-Audio-HDMI-Converter-Adapter/dp/B0015YWV1G/ref=sr_1_3?ie=UTF8&s=electronics&qid=1263068538&sr=1-3
Cable is here: http://www.amazon.com/HDMI-meter-foot-cable-1080P/dp/B0002L5R78/ref=pd_bxgy_e_img_b
Jan 09, 2010 | Toshiba Satellite M55-S325 Notebook
Dell w3000 & PS3
This may not be DVI issue.
I connected DVD player HDMI ----> DVI ( Dell W3000) LCD TV.
Later I found that Dell TV version of DVI does not support HDCP protocol ( High Definition Content Protection protocol). So I could not play HDMI to DVI movies from my DVD player instead I use Y Pb Pr -- this works ok.
Hope this helps... I am not use PS3 enforces HDCP - I assume Sony linked with Sony Pictures would enforce HDCP on HDMI cable.
Dec 27, 2007 | Dell W3000 30 in. HD-Ready LCD Television
Dell UltraSharp 1504FP 15" Flat Panel LCD Monitor Logo
mukhtar21 shaikh
mukhtar21 shaikh
