Question about Bona Hardwood Floor Spray Mop W/ Refillable Cartridge
Bona spray mop clogs after a few sprays - Bona Hardwood Floor Spray Mop W/ Refillable Cartridge
How can I refill cartridge on mop?
The cartridge has a screw cap that you can open. Buy a gallon Bona floor cleaner and refill it.
Feb 17, 2016 | Bona Hardwood Floor Spray Mop W/...
Model sk410. how do I disassemble it?
Shark Steam & Spray Mop: How to Assemble - YouTube
? 1:27
https://www.youtube.com/watch?v=iH2NVXVA4-U
Sep 6, 2013 - Uploaded by Shark Cleaning
Assembling the Shark Steam & Spray Mop is easy. You'll ...Shark Steam & Spray Pro Mop: Using Steam and Spray Mode - Duration: 5:34. ... Shark Steam & Spray: How Do I Use My Mop In Steam Only Mode - Duration: 3:45.
Shark Steam & Spray Pro Mop: How to Assemble - YouTube
? 1:31
https://www.youtube.com/watch?v=I3thGlk2GdU
Assembling the Shark Steam & Spray Pro Mop is a breeze. ...Shark Steam & Spray: How Do I Use My Mop In Steam Only Mode - Duration: ...
Shark steam mop S3601 disassembly. - YouTube
? 3:38
https://www.youtube.com/watch?v=zq07GHhbJkI
Jan 07, 2016 | Shark Professional Steam and Spray Mop
Not spraying water
I have sk460 spray mop and the 6 volt spray motor rusted up.
Looking for motor now.
Dec 09, 2015 | Vacuums
Detergent will not spray out
It must be blocked by minerals use CLR repeat process if needed leave it plugged in
Mar 09, 2014 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Rubbermaid Reveal mop trigger sticking
I bought 2 rubbermaid reveal spray mops before I figured this out. You'll need a Phillips and flat head screwdriver & a can of WD40. On the compartment that holds the liquid cleaner bottle there are 2 screws and 1 screw on the connector piece to the mop head. Unscrew all three. The one by the mop head came out and the other two stayed in their holes. Then with a flathead screwdriver gently pull the seam along the side apart. You only need 1/2-1 inch of a gap. If you pull it open all the way you'll pop a few other pieces out of place and have to piece them all back together- so gently! Then spray some WD40 in along the exposed spring using the red straw that comes with the can. Close the gap, hold it together and try the trigger a few times. If the trigger is still sticking spray more WD40 in until it frees up. Then screw your screws back in and it's as good as new!
Dec 03, 2013 | Rubbermaid Reveal Spray Mop Kit,...
MY LIBMAN SPRAY MOP WON'T SPRAY AND ITS BRAND NEW. i FILLED THE CUP UP AND PRIMED THE HANDLE AND STILL NOTHING.
Did you ever get a solution? I just bought it today, and am having the same problem. I also sent an email to Libman.
Oct 11, 2011 | Euro-Pro Shark Steam Mop - Gray/ Purple...
I was using my shark steam pocket mop without any trouble for about 5 minutes & all of a sudden it stopped steaming. i tried unplugging it & starting over but when i did this the water chamber...
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it maynot be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
Here also is a link to get any of the Shark Manuals that you need.
heatman101
[]0-0-
Jun 17, 2011 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Steam coming out of relief valve
Check for clogs at the spray tip. With the unit unplugged, remove the mop head by taking out the single screw at the base of the unit. CAUTION: The spray tip may be hot. Using a paper clip clear any clogs from the spray tip.
The filter may also may need to be replaced if it is blue in color.
Sep 26, 2010 | Bissell 1867 steamMOP Stick Vacuum
Not spraying
• tanks are not sealed into receivers
• faulty auto load receiver
• pinched/clogged line
• defective component allowing air into system
• pump not mounted so it can move freely
• defective bridge rectifier
• clogged heater
• defective pump
• defective circuit board
another is the spray nozzles are clogged.
Jun 08, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bona Hardwood Floor Spray Mop W/ Refillable Cartridge Logo
46 people viewed this question
Top Bona Vacuums Experts
Are you a Bona Vacuum Expert? Answer questions, earn points and help others
