My HP 3005n won't collate multiple copies - Office Equipment & Supplies
Cops
  • 64 Answers
SOURCE: HP 4250 DTN will not print multiple copies
if this is ran through a network which i would think most likely due to the machine then you will need to change the number of copies to be printed on the control panel on the fron of your machine as well as that will have the final say over what comes out of it.
i think it should be as follows:
press the green tick, press down, green tick on print quality.
i may be worng on where its located as not used one for a while.
if i am wrong on it the go into the information menu and print out a menu map. this will show you which sub-directory its in.
Hope this helps.
Pete
Posted on Nov 05, 2008
SOURCE: unable to store job at printer, printer not configured to collate
Problem -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-
Error “Unable to store Job at Printer”
Reason “Printer not configured to collate”
Solution “Install an EIO hard disk”
Usually when trying to print a multi page document.
Solution 1. Start > Control Panel > Printers
2. Locate the printer > Right Click > Properties.
3. Device Settings > Mopier Mode > Set to Disabled.
4. Apply OK
Posted on Mar 21, 2009
  • 20 Answers
SOURCE: HP 3055 printing black lines when using collate feature to copy
All you need to do is to clean the small wide glass (that at the LEFT of the main flat big class). The Auto Document Feeder (ADF) specifically uses this glass to scan for copy (and fax). When it is dirty (such as small dirt or particles on the surface which is easy to gain in long run), it will create thin vertical line(s) as the result.
Posted on Jul 07, 2009
SOURCE: My hp 1320 prints multiple copies instead of one copy
Go to "printers and faxes."
Right click on your printer and select "Printing preferences."
Select "Advanced" tab
Double click "paper output"
If "Copy count=2" then change to 1 and apply
IF IT ALREADY IS SET TO 1 THEN:
Set "copy count=2" then APPLY
Repeat the above and now set "copy count=1"
The process of setting and resetting the copy count fixed my issues.
Posted on Mar 01, 2010
  • 51 Answers
SOURCE: How do I print batches of multiple copies, so that
Can only do if you have a document feeder. Put in originals and pick the offset mode for x amount.
Posted on Apr 06, 2010
How can i print multiple copies of the same document with 3 pages and have the printer staple the copies in the correct groups?
In the print driver you should have the option to collate, you need to make sure that that option is on, and when you go to send the print job, you need to make sure that you adjust the finishing options in the driver to tell it to staple.
May 11, 2011 | HP LaserJet 4250 Printer
Why do multiple copies sometimes staple together as one set instead of multiple sets?
I don't know how/why, but if you set the Print settings (main print screen) to non-collate and the Printer Properties (clicking in to get to the staple option) to collate, it works correctly, stapling each set individually.
Oct 28, 2010 | Konica Minolta bizhub C450P Laser Printer
My HP C6380 won't print multiple copies of a page even though I select how many copies I want of the page . I have to keep printing each page individually which is very time consuming.
what is he OS ?........what connection USB/wireless ?..........From what application you are printing? ..........have you checked the printer printing properties and ticked of the collate check box where you have selected mutiple pages ?.....
Jul 15, 2010 | HP Photosmart C6380 All-In-One InkJet...
Printing page order
under print settings make you have "collate" option checked. There are different ways to find this depending on which operating system you are using.
May 26, 2009 | Brother HL 1440 Laser Printer
Unable to store job at printer, printer not configured to collate
4. Apply OK
Feb 25, 2009 | HP LaserJet 2300L Printer
Quark 6.5 printing problem
Just update to QuarkXPress 6.52 and it would work
Dec 13, 2008 | QuarkXPress 6.0 for Mac
Multiple copies
Look for a small "Collate" box and make sure it is checked. That way it will print each set in order.
Sep 26, 2008 | HP DeskJet 5550 InkJet Printer
I am running Microsoft Word 2003 and have an HP 1320n printer. My problem is that when I print more than 1 copy the pages do not collate even if the collate box is ticked in the print dialogue book and so...
HP 1320 print driver is a universal print driver covering several printer models.  Collating only works on HP printers if you have a multiple exit tray system for commercial based laser printers similar to finishers on a copier.  They have to have room to keep the copier together before they can be collated.  On a standard configured 1320 there lacks any space for finishing tasks.
This support bulletin on hp.com can provide you the answer:
http://bizsupport.austin.hp.com/bc/docs/support/SupportManual/c01366409/c01366409.pdf
Sep 10, 2008 | HP Computers & Internet
KONICA MINOLTA C450 VXL Printer - When stapling multiple copies it staples all the copies together rather than each one separately as required. I use vista operating system.
There is an issue with the Konica Print Driver and the MS Print Driver. If Collate is turned on in both the drivers, you will get this problem.
The solution is to turn off Collate on one of the Drivers. Usually you will have an initial Print Dialog window that pops up when you can select your printer, how many copies and if to collate or not. De-select Collate. Then you should also see Preferences Tab. If you select that tab, select Collate and Staple, your print jobs should now Collate and Staple correctly.
Jul 23, 2008 | Office Equipment & Supplies
11 people viewed this question
jasbo
jasbo
