Question about Kodak EasyShare M1033 Digital Camera
When I power up camera it opens then shuts down
Camera is stuck in open position
Pull the battery out and put back in then power on the camera should stick out then when you turn it off should go back in.
Aug 28, 2012 | Olympus Cameras
The camera starts up and shows the blue sanyo screen. Then the screen turns black then shuts off. The lens doesn't even open. I've tried charging the battery and that is not the problem. What's...
Hello ..Yes please make sure your batteries are fully charged..If battery is charged and still shuts down..There is a good chance lens was hit or bumped.When lenses are bumped the camera will try to extend lens upon power up as part of cycle.If camera detect problem with lens not opening..Then it will shut down...
Sep 23, 2011 | Cameras
My kodak easyshare V1253 Powers up, then shuts off
You have damaged your lens. If the camera can not move the lens it goes through a built in diagnostics test and shuts down. Beyond repair as cost to replace is beyond the value of your camera.
Jul 03, 2009 | Cameras
When trying to power up hear 3 beeps and camera turns off.
Make sure the batteries are good and in right. If it keeps doing it you might be having a problem with your lens opening up and staying open, I had a camera that did that to me, and the lens had been knock and wouldnt open properly, check that out. The lens was out of range from normal and would automatically shut down
May 09, 2009 | Cameras
Opening the program my computer shuts down
This sounds like a power supply issue whereby your computer is not suppling enough current to the web cam for it work and therefore the power supply shuts down rather than harming your system.
Mar 07, 2009 | Cameras
Lens wont open
Lens mechanism isn't good to work properly so camera shut down the power. Try to tap the lens/ camera while power up.
If you have a memory card in the camera, take it out before turning the camera on
Aug 28, 2008 | Sony Cyber-shot DSC-S600 Digital Camera
Will not turn on
Sounds like your lens is stuck. Try a gentle tug and it should open all the way. Then you can power your camera down.
Nov 01, 2007 | Samsung Digimax S800 Digital Camera
Camera powers up but then shuts down
Check out this similar post - http://www.fixya.com/problems-solutions/t103765,p241282/Ricoh-Digital-Cameras.aspx In your case though, I would try to turn it on with playback mode selected on startup, to prevent the zoom from extending. This way you will know if the problem is connected to the zoom, or other mechanisms. In any case, if it's not a battery/battery door/card problem, you'll need to send it for repair, or find a shop that can handle it, and it's rarely a cheap repair. Good luck
Jun 19, 2006 | Olympus D-535 Zoom / C370 Zoom Digital...
Kodak EasyShare M1033 Digital Camera Logo
44 people viewed this question
Top Kodak Cameras Experts
Tony
Jerry Greenberg
Jerry Greenberg
Are you a Kodak Camera Expert? Answer questions, earn points and help others
