Question about Weslo Cadence Dl15 Treadmill Walking Belt For Model Number: Wltl41584
How to replace the walk belt on a sports art 1060
Can I fix a NB1500 treadmill belt that is bowing in the middle? I've tried adjusting the tighteners on the back and cannot eliminate the bowing in the middle.
No, you need a new belt as it is stretched because that is where it gets pounded all the time. $50 to $100 depending on the quality you choose.
New Balance 1500 Treadmill Walking Belt 20 x 119 - Treadmill Doctor
https://www.treadmilldoctor.com/new-balance-walking-belt-1500
Replacement Walking Belt For The New Balance 1500 Treadmill. Belt size 20" X 119".
New Balance 1500 Treadmill Walking Belt - eBay
www.ebay.com > ... > Fitness Equipment & Gear > Other Fitness Equipment & Gear US$94.99 - ‎In stock
New Balance 1500 Treadmill Walking Belt in Sporting Goods, Fitness, Running & Yoga, Fitness Equipment & Gear, Other Fitness Equipment & Gear ' eBay.
Amazon.com : New Balance Treadmill Running Belt Model 1500 ...
https://www.amazon.com/Balance-Treadmill-Running-Belt-Model/.../B00H4QKAOO Rating: 5 - ‎1 review
This is a 1-ply Residential walking belt, some sellers will try to sell you a 2-ply belt (claiming better quality) for your treadmill, which is not recommended for ...
Amazon.com : Treadmill Doctor Newbalance Treadmill Running Belt ...
https://www.amazon.com/Newbalance-Treadmill-Running-Belt-Model/.../B008EYOF... Amazon.com : Treadmill Doctor Newbalance Treadmill Running Belt Model 1500 : Exercise Treadmill Belts : Sports & Outdoors.
NB1500 treadmill belt Google Search
Aug 14, 2017 | Exercise & Fitness
Sports art 1060 not working
please adjust the REED switch, clean it, test it, and tight the wires connector, see the diagram attached.
2) tight the ribbon cables from keypads switchs, and clean it.
3) tight wires connector from display board vs lower board see the block too.
4) replace the batteries by new ones, and clean contacts batteries with contacts cleaners
God bless you.
Jul 29, 2012 | Sportsart Exercise & Fitness
My sports art 1060 when give it power the screen power on but not work
1) adjust the Reed switch, clean, and tight the connector very well.see the diagram attached.
2) Tight the ribbon cable from keypads, very well, and clean.
3) Tight the connectors from display board vs lower board.
See the diagrams. God bless you
Jun 02, 2012 | Sportsart 6300 Treadmill
Program of 1060 sports art
Dear Sir:
Please read your instruction manual, if you do not have. go for free:
www.fitness.manualsonline. com or www.iconservice. com
sincerely. God bless you
Apr 21, 2012 | Sportsart 6300 Treadmill
When i am running the belt seems to stop for a split second causing me to stumble and then goes normally
If the walking belt slips when walked on, first remove the key and UNPLUG THE POWER CORD. Using the allen wrench, turn both rear roller bolts clockwise 1/4 of a turn. When the walking belt is correctly tightened, you should be able to lift each edge of the walking belt 3 to 4 inches off the walking platform. Be careful to keep the walking belt centered. Then, plug in the power cord, insert the key, and walk on the treadmill for a few minutes. Repeat until the walking belt is properly tightened.
Jun 10, 2010 | Proform Sport 1000 Folding Treadmill...
Belt problem
f the walking belt slips when walked on, first remove the key and UNPLUG THE POWER CORD.Using the hex key, turn both idler roller bolts clockwise,1/4 of a turn. When the walking belt is correctly tightened, you should be able to lift each edge of the walking belt 2 to 3 in. (5 to 7 cm) off the walking platform. Be careful to keep the walking belt centered. Then, plug in the power cord, insert the key, and carefully walk on the treadmill for a few minutes. Repeat until the walking belt is properly tightened.
May 14, 2010 | Proform Sport 1000 Folding Treadmill...
We have a Proform Sport 1000 treadmill which when you get on it the belt slips badly and it hardly moves. The belt doesn't seem loose so is the motor failing?
There is a belt between the front roller and the motor (drive belt) that is under the motor hood. The trick is to watch the front roller when you get on the walking belt. If the front roller stops with the walking belt, then the drive belt is loose and needs to be replaced or tightened. If you have already adjusted the walking belt, and you can hear the motor, it's the drive belt. There will be 3 screw on the front of the machine, and a couple of screws under the main frame. Tip the unit over to find the screws, and take off the cover. You'll be able to see where the slip is.
Mar 06, 2010 | Proform Sport 1000 Folding Treadmill...
Running belt slips om treadmill Sports Art 1060 model
Either the belt has stretched (normal wear over time) or the tension needs to be readjusted to tighten it. Every treadmill is different, and some can't be adjusted, so I can't really help with particulars, but if you get down and look really carefully, you'll be able to find the tension adjustment mechanism if it exists. Good Luck.
Dec 06, 2009 | Exercise & Fitness
Weslo Cadence Dl15 Treadmill Walking Belt For Model Number: Wltl41584 Logo
139 people viewed this question
Top Weslo Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
Jim London
Jim London
Are you a Weslo Exercise and Fitnes Expert? Answer questions, earn points and help others
