Question about HP LaserJet M1522nf Multifunction Printer (CC372A)
HP Laser Jet M2727nf - exclamation mark is lit and can't scan. Printer printer prints, but when we try to scan Error Message 5 Turn Off the On
Soulvisitor
  • 1113 Answers
SOURCE: Printer HP Laser Jet 7400
A critical firmware error has occurred that caused the processor on the formatter to abort the operation.
This type of error can be caused by invalid print commands, corrupt data, or invalid operations.
In some instances, electrical noise in the cable can corrupt data during transmission to the printer.
Other causes include poor quality parallel cables, poor connections, or specific software programs.
99 % of time it is a corrupt file or poor connection, I have also known it to be the firmware, dimm or formatter board on rare occasions.
Recommend check hp web for any firmware updates, check connections and that driver is installed impecablly and use known good files to test.
Posted on Dec 27, 2007
SOURCE: Can't print to a shared HP Laser Jet 2015 printer (Mac)
On the two non working computers...uninstall the printer drivers and uninstall any info about the printer reboot.reset up each indivual (the two non working ones)computer with new drivers from web.reboot and they should work.RICHARDM69
Posted on Dec 05, 2008
SOURCE: not printing in foxpro 2.6 dos to hp laser jet 1020
You write "type the above line at command prompt". I dont't know Where exactly to write? Can you tell me!
Posted on Dec 02, 2009
wheatlandsvc
  • 1110 Answers
SOURCE: HP Laser jet 4350 dtn printer gets 59.40 error. I
Print Cartridge Motor Error.
Try removing then re-installing the cartridge. If that does not work then you will need to try a different toner cartridge as the toner cartridge is "locked up". These are the most common solutions. If none of these work then you have a cartridge drive problem and will need to contact a service center.
Posted on Jan 05, 2010
Testimonial: "It worked. Thanks. I' just FIXYA again"
SOURCE: HP Color Laser Jet printer CM1312nfi: scanner no
Go to your network and sharing center. Choose homegroup and sharing options. Change advanced sharing settings. Under your home or work profile, scroll down to file sharing connections. Switch to enable file sharing for devices that use 40 or 56 bit encryption. If that does not work, under password protected sharing, select "turn off password protected sharing". This is not recommended if you use your computer in multiple locations (laptop). I have found that turning all of these features off, running a scan from the printer successfully and then turning them back on, Windows seems to be comfortable allowing the printer to connect to the computer.
Posted on Oct 17, 2010
I cannot print or copy with my HP LASERJET MFP M2727 NFS because the control panne show this error: SCANNER INITIALIZING ERROR 5. The only thing that is suggested is to turn on the device. When I turn on...
This sounds like a Scanner/Flatbed Problem. This series of printers have a known problem with this component. The scanner is failing to initialize itself. The scanner does need to be changed by an Authorized HP Warranty Repair Facility. It is possible that it may be covered under an HP Extended Warranty program. See repair information VIA posted Link.
M2727INFORMATION
Cheers!!
Jan 27, 2011 | HP Laserjet M2727nf Multifunction Printer
HP m2727nf scanner error 5
Hi Anataloi,
This is due to a hardware failure, the scanner assembly and the formatter board will need to be replaced.
Try doing a hard or reset or nvram:
1. Turn the printer off
2. Hold down the right arrow and the cancel button
3. Reboot the printer while holding the buttons and hold until permanent storage is displayed. Let go of the buttons and wait for the ready message on the display.
if this does not work contact hp 1800-334-5144 , if within 2 years from the purchase date ask for a case number to have the printer serviced under a service note.
Al
Eliteprintersolutions@gmail.com
Jun 25, 2010 | HP Laserjet M2727nf Multifunction Printer
Hp laserjet M2727nf scanner error 52
First, power the printer off, wait for about 30secs and power on. If problem persist replace the scanner.
Feb 23, 2010 | HP Laserjet M2727nf Multifunction Printer
My M2727nf doesn't coppy or scan. message displays " error 5 Turn off and turn on." After turning off and on, it keeps displaying the same message.
Hi this is def a hardware failure:
Try doing a nvram
if this does not work, have it serviced they will need to replace the formatter board as well as the scanner assembly.
If within 2 years from the purchase date contact HP and request for a case number the printer has a service note for a scanner error 5 or 8.
Al
Oct 10, 2009 | HP Laserjet M2727nf Multifunction Printer
HP 1000 Laser Jet Printer - error printing
Turn the printer off and then back on. Does it go to the ready state? or does it come up and error? If the error only comes up when asking the printer to print then the printer probably has a worn paper pickup roller. You can take the old roller out and rotate the rubber tyre a little.
Mar 26, 2009 | HP LaserJet 1000 Printer
HOW TO SCAN FROM SCAN TO BUTTON IN THE NETWORK FROM HP 2727MFP
You need to install the HP Scan software on each and every PC the MFP should scan to. In this software, you can create targets for the "Scan To" button. But: This is only useful when scanning with the ADF, because when scanning from the flatbed, you'd need for every page to hit the "Scan To"-button, press "Scan", wait for about a minute or two until the MFP has found the appropriate PC, and wait for the scan. So network scanning is unfortunately very limited with this machine.
Mar 12, 2009 | HP Laserjet M2727nf Multifunction Printer
Hp2300 laser printer
52.x PRINTER ERROR alternates with To continue turn off then on Possible printer control panel error messages 52.0 PRINTER ERROR 52.1 PRINTER ERROR 52.2 PRINTER ERROR Description A temporary printing error occurred. The x can equal one of the following: 0 = Scanner error 1 = Scanner startup error 2 = Scanner rotation error This error can also indicate a problem with the shutter tab on the print cartridge. Action
  1. Turn the printer power off, and then turn on the printer power.
  2. If the message persists, check the print cartridge for damage.
    1. Verify if the shutter tab on the cartridge is broken or damaged. click on the below link. Shutter tab on the print cartridge
  3. 1 - Shutter Tab
  4. Replace the cartridge if damaged.
If the message continues to persist, then download the printer software based on operating system and reinstall.
HP Laser-Jet 2300d Printer Software
Regards
Chittaranjan
Dec 11, 2008 | HP LaserJet 2300d Printer
Scanner error 5 turn off then on
Eva, This is a common problem with this machine and more than likely the scanner will need to be replaced. You should try calling HP and see if they will cover it since it is a common problem.
Nov 13, 2008 | HP Laserjet M2727nf Multifunction Printer
Cartridge error
Please first check whether there is paper jam in the printer roller or else please check the cartridges is fixed properly
Sep 24, 2008 | HP Officejet 4355 All-In-One InkJet...
HP LaserJet M1522nf Multifunction Printer (CC372A) Logo
Seeker5211
Seeker5211
