Question about Kay Home Products Casita Square Screenhouse - 11 7" X 11 7" Free Standing Screen House
I need to order replacement parts for my 12 panel Casita screenhouse & can't find where to find that spot on your website. Can you direct me?
Instuctions for 13×9 cabin tent sleeps 6 wmt-1390 (not instant)
OWNER'S MANUAL WARNING: KEEP ALL FLAME AND HEAT
SOURCES AWAY FROM THIS TENT FABRIC.
This tent meets the flammability require-
ments of CPAI-84. The fabric may burn if left
in continuous contact with any flame source.
The application of any foreign substance to
the tent fabric may render the flame-resis-
tant properties ineffective.
DO NOT...
1. Do not pitch tent near an open flame.
2. Do not leave campfires unattended.
3. Do not allow CHILDREN or ADULTS
to use lighted candles, matches or
other flame sources in or near tents.
4. Do not use heating, lighting or
cooking equipment with open
flames in or near tents.
5. Do not use fuel burning/oxygen
consuming devices (i.e. heaters,
lanterns, or other flame sources)
inside your tent at any time.
6. Do not use other than recommended
water repellent compounds on your
tent.(See:"Seal the Seams")
7. Do not spray the tent with insecticide.
8. EXTREME CAUTION: Never use any
fuel burning/oxygen consuming
device, or any device that produces
fumes (including stoves, lanterns,
candles, hibachis, or heaters) in or
around your tent. Inhalation of fumes
may result in carbon monoxide
poisoning, injury and/or *****.
DO...
1. Always extinguish campfire before
leaving area.
2. Exercise care when using electricity
and lighting in and near tents.
3. Disassemble and store tent properly
after camping to ensure the tent's
longevity.
4. Always use a hammer/mallet when
driving stakes into the ground. CARE This recreational item is not intended for
use as a permanent structure, as fabric
will quickly degrade if exposed to UV
light. No (sun shelter, screenhouse, tent)
can withstand prolonged exposure to
sunlight. UV damage is not covered under
the limited 90 day warranty.
Structural Integrity
Although our tents and screenhouses are
constructed to rigid specifications, periods
of wind or rain soaking the ground may
loosen the stakes and cause the uprights to
sink into the ground. This will weaken the
rigidity of the overall structure. Water pock-
ets may also form in the roof if the unit is
not assembled taut, the weight of which
may cause broken frames and torn fabric
Storage
Tents/screenhouses must never be rolled
up or packed while damp, as mildew will
form within a few days. Allow tent to dry
completely before rolling and storing.
REPLACEMENT PARTS Always mention the Model number in all correspondence regarding your tent and when ordering
replacement parts. ASSEMBLY INSTRUCTIONS Lay Out the Screenhouse and Poles
Select a smooth, level site and spread out your
screenhouse.
Sort the poles by number and connect the
sections together. See diagrams below for
numbering
tep 2 - Install the Poles
Insert the ends of each of the three roof poles
into the 3-way hubs
Insert the four side roof poles into the 3-way
hubs. See Diagram 2 Insert the leg poles into the hubs to raise the
screenhouse frame. Make sure that the pole
end with the holes in the sides (
down. See Diagram 3
Secure the Screenhouse
Drape the screenhouse body over the frames.
Hook the S-Hooks
located at the bottom of the leg poles.
L
Wrap the velcro tape
screenhouse, around the poles to secure them.
When the screenhouse is in its proper location,
stake it down by driving stakes through the
four D-rings
Step 4 - Install the Guy Lines
Tie the loose end of a guy line through D-ring
Repeat for the other three guy lines.
1B
Make a loop at the end of the guy line with the
L
slider. Stake the looped end of the line out
about 3' from the base of the pole. Adjust the
slider until the line is taut
C
Sep 28, 2016 | Sport & Outdoor - Others
Lost the chuck for my master force 12" drill press where to get replacement part
[PDF]12" Drill Press - Menards
https://www.menards.com/main/store/...Tech.../240-0064.pdf
Menards12. REMOVE ADJUSTMENT TOOLS. Always make sure all adjustment tools are removed from ... Should any part of the drill press be missing, damaged, or any electrical component fail to ...... Use only MasterForce™ replacement parts. Use of ...
MasterForce 12" Drill Press Repair Questions, Solutions and ...
www.fixya.com > Forum > Drill Presses > MasterForce
Free expert DIY tips, support, troubleshooting help & repair advice for all Drill ... Lost the chuck for my master force 12" drill press where to get replacement part.
Lost the chuck for my master force 12" drill press where to ...
www.fixya.com/.../t23651560-lost_chuck_master_force_12_drill_press
Feb 24, 2014 - Lost the chuck for my master force 12" drill press where to get replacement part Where to get spare parts - MasterForce 12" Drill Press question.
Drill Press Parts & Coring Drill Parts ' Tool Parts Direct
Feb 24, 2014 | MasterForce 12" Drill Press
Steering is really loose.
old post
well there are many places for steering to go loose.
a mech finds that exact spot, first.
you didnt so there will be no answers
its a hands on deal.
when we find that SPOT
we replace the part that is bad.
even tilt steering parts
i count the spots.
over 12.
if you need training on suspension and steering inspection
i can direct you to ASE pages.
Feb 17, 2014 | 1991 Geo Tracker
Kohler 12 RES - Unit fails to start occasionally. Attempting a manual start by placing switch in run position, cause a loud click, but no cranking. The panel says CC. This morning I put a jump start...
I finally solved the intermittant starting problem on my Kohler 12 RES by replacing the strater and the starter relay. I was also experiencing the occassional OC indication, red blinking LEDs on the ATS, and intermittent non-starts during the weekly exercises. The problem happened during power outages a couple times also. If I flipped the start switch between auto and run quickly the generator would occasionally start. Once started, the generator runs fine. I ordered a new starter, which included the starter solenoid. By the way, don't worry about the genuine part thing..the old starter was a Delco made overseas. I ordered a new starter online for $85 (6744N) and it was indentical to the genuine Kohler starter. Replaced the starter and it improved the problem but did not totally solve the intermittent starting. Ordered the starter relay (GM49746) replaced it and the problem is solved.
May 09, 2012 | Kohler 12 kW Emergency Power System -...
Where is the thermal fuse located on the Follow Spot?
Follow the wires internally. Close to the lamp you will find part of the wire that looks covered in another shield or wrap. Usually the thermal fuse is soldered in-line there. Chauvet will supply parts directly. Per their website: Call our Customer Service Department at 800.762.1084 (press #4). Tell us what part you need, we will give you the part?s cost plus shipping. Then we request your credit card information, charge your credit card, place the order, and ship out the part to you. Hope this helps, Dan
May 19, 2010 | Chauvet Followspot 400g with Stand
Where can i get a replacement water tank? for model # F5906-900 series 12?
The replacement parts can be ordered from hoover or through any hoover dealer. thier info can be found through the Hoover website. If you are unable to obtain a direct match, there may be available ones in different color.
Oct 24, 2009 | Hoover F5906-900 Upright Steam Vacuum
Honda EU2000i with a washing machine
Yes - it will be a fine machine to have and do well.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Feb 10, 2009 | Kenmore Washing Machines
Need parts
Found the fuse at this website www.tiewraps.com ORder the AG-12
Jan 19, 2007 | Haier HDN655E Dehumidifier
Kay Home Products Casita Square Screenhouse - 11 7" X 11 7" Free Standing Screen House Logo
76 people viewed this question
Top Kay Home Products Garden Experts
Dennis Key
Dennis Key
john h
Are you a Kay Home Products Garden Expert? Answer questions, earn points and help others
