How do I fix sticky keyboard keys on logitech mk710?
4 Suggested Answers
EngineerGR
  • 119 Answers
SOURCE: sticky keys
Dear rwertheim
Try the following guide
http://www.laptoprepair101.com/laptop/2007/03/20/key-fell-off-keyboard/
There are no guides from Gateway for the keys available for the but this guide will be more than enough to help you through this one in order to remove them. Its should be completely the same principle.
Cleaning the keys should be done without alchohol based cleaners because the lettering might be erased. Use some soap and warm water instead and gently scrab with a soft brush the bottom of the keys.
Please remember to take out your laptop battery/ac adaptor in any case since you will be working at hardware level with your equipment.
Regards, and I wish you no more sticky keys!
Please dont forget to rate this solutin!
Posted on Apr 02, 2008
  • 45 Answers
SOURCE: Aspire 4720 PC Notebook: sticky keys, some liquid wet the keyboard...
Its hard to get them working again properly, i had to replace 4 sticky keys finally. I found this company who sell laptop keyboard keys at a very good rate, and even have tutorial's on how to fix the keys , that makes it really easy ...
www.laptopkey.com
Posted on Jul 21, 2010
SOURCE: instructions to remove keyboard from compaq laptop
Remove the Power Cord, Remove the Battery. Close the LCD Lid then turn the laptop over. Look inside the battery case to see if there are any screws in there, if so remove them. Sometimes the keyboard might have screws inside the battery case too. If that's the case normally you will see the keyboard icon next to the screw. The purpose of removing screws in the battery case is there might be some that hold the strip that is above the keyboard in place.
You can look at the rest of the screws on the bottom of the laptop to see if you see any that might have the keyboard icon next to it. if so remove that screw. Also sometimes there might be a screw that holds the keyboard inside the memory slot or any of the other slots so just look for them. If you'd like you could just remove all the screws from the bottom of the laptop.
Turn the laptop back over after the screws are removed, then take a small flat head screwdriver and pry the strip that is above the keyboard aloose. Normally this strip has the power button on it. Be careful removing this strip because there will probably be a cable attached underneath it.
Once the strip is removed there might be screws that hold the keyboard in place a the top of the keyboard, if so remove them. Now you can just lift the keyboard out but be careful because there is a keyboard cable underneath the keyboard that has to be removed. If the keyboard does not just come out then more than likely there are little catches that help hold it in place either at the top or on the sides, just work with one side to pry it from the catches then you will be able to get the keyboard out.
Posted on Apr 24, 2012
How do I disassemble a Logitech Alto keyboard?
Most Logitech keyboards have a series of series on the back panel. If you take a screwdriver and unscrew them all you should be able to dissemble it from there.
Dec 25, 2016 | Computers & Internet
How to unlock logitech keyboard foe Ipad
follow this steps and fix it. God bless you
Press the Windows logo key + U. This will open the ease of access center. Click on the keyboard icon. It will say, "make the keyboard easier to use" next to it. In some versions of Windows you will need to get to the option by pressing the left shift key five times rapidly.
  • 2 Select "turn on sticky keys" and "turn on filter keys." Select "save." Your computer will now only make sounds when the keyboard is hit.
  • Sponsored Links
  • 3
    Follow steps 1 and 2 to unlock your keyboard. Unselect the "sticky keys" and "filter keys" and click on "save."
  • 4
    Lock your workstation. Press Ctrl + Alt + Del. A blue screen or a box will pop up that has a variety of options, such as restart or shut down the computer. Click on "lock this computer."
  • 5
    Lock your workstation using the keyboard. Press the Windows key and the L key at the same time. This will lock the computer. To unlock press the combination again.
  • Read more: http://www.ehow.com/how_4925264_lock-keyboard.html#ixzz2aZv7Zmdg
    Jul 30, 2013 | Televison & Video
    Logitech wireless keyboards sticking keys
    I've tried to individually clean keys on a keyboard with sticky keys... It really depends on how many as to whether its worth the time investment.
    If its just one or two, I'd rip them off, (most will just detatch if you pull them straight up towards you), give the keys a good clean, clean the keyboard where the keys go into, allow all to dry,then reinstall them. this should fix them. If its spilt softdrink or the like across many keys, it will probably be easier to just replace it.
    generally, to clean, just use warm water, or very slightly soapy water, at most... and allow to fully dry. also, dont spill any inside the keyboard onto the contacts...
    hope this info helps.
    May 18, 2012 | IBM Lotus Organizer 6.1 for PC
    I recently purchased a Logitech MK710, but I use the Divorak keyboard layout, not the traditional "QWERTY" layout. Consequently I need to physically remove many key covers and rearrange the...
    no no no
    you go to keyboard possibile properties ) click on orientation, click on american or english or what ever you want , click apply and it changes the keys correctly for you
    qwerty is american and what you have is probably english as they are different in layout
    Apr 03, 2017 | Logitech Wireless Keyboard and Optical...
    www.laptopkey.com
    May 17, 2010 | Acer Aspire 4720 Notebook
    Whenm I hit the bn i get bn, whenm i hit the nm i get nm - this is terribnle also whenm i type .com, i get a comma after the com,
    I had the same problem, when I typed "b", the keyboard returned "bn", typed "n" and returned "nm". I fixed the problem by replacing a new batteries.
    Hope it helps in your case.
    Aug 10, 2009 | Microsoft Wireless Desktop 3000 Keyboard
    Logitech S 510 keys quit working
    The SUGAR causes a very sticky effect to the electronic contacts. The keyboard wil eventually eiter TOTALLY stop working or u will always have a few ones that wont work. .... Not rerally repairable
    Jul 08, 2009 | Logitech S 510 (967555) (DH967555)...
    Keyboard doesnt type correctly
    try this steps...
    Check this --
    Start> Control Panel> "...Language...Options">
    Regional and Language Options>
    Advanced tab,
    Change language to "English (United States)"
    Could it be the "sticky keys" option is switched on? When you hit the E key does an explorer window open?
    Tap the shift key 5 times and have a look. If sticky keys comes up as turned on, turn it off.
    or
    Could be a stuck key. Try another keyboard.
    Jun 23, 2009 | Logitech S 510 (967555) (DH967555)...
    I accidently locked my keyboard while holding down the shift key,
    it sounds like you have sticky keys on.
    this would come on by pressing the shift key 5 times.
    press any two keys at the same time and the control panel will come up.
    Feb 25, 2009 | Logitech Cordless Desktop EX110
    Keyboard click
    i think u will hear the noise whn u pressing shift ,ctrl,and alt keys continusly na..these keys r called sticky keys.....pls press these keys 5 times continusly thn one window will come in that window thr is a option called turn off sticky keys pls tick the box u can remove the noise k
    Sep 19, 2008 | Logitech 967437-0403 Keyboard
    Open Questions:
    Toshiba Laptop doesn't start up. Black screen [Solved] -Dataalign Toshiba as a brand has continued living up to the expectations of its customer for nearly three decades now, by maintaining the high quality of its products with the help of delivering a combination of useful software and attractive hardware in a package, which is required for providing the needed technological expertise. With laptops becoming an indispensable and integral parts of our lives, it is important that companies today equip their laptops with all the advanced technologies along with a sleek and stylish design for that attractive feature that would add to its plus point. Our Toshiba technical support team members are available all the time on our Toshiba Support number +1 888 784-9316 and are highly adequate in resolving issues related to Toshiba printers. The fact that everyone today knows about Toshiba Support brand and most people who have tried Toshiba products like them, makes them one of the most reliable in case of printers especially. Toshiba makes business portable laptops, with highly durable features of being sturdy and long- lasting for use in all walks of life. Most laptop owners would agree to the fact that Toshiba products are designed to provide quality portable solutions and highly acclaimed for their bullet-proof build value. But with time, users might face issues with Toshiba Customer Care like any other laptop band and these issues can be prevented from causing any severe damage to the laptop by accessing resolution from our technically specialized team members, who are available on our +1 888 784-9316. Issues faced by Toshiba customers: Toshiba Backup BIOS update issues Slow Performance Office and outlook setup Wifi and Internet Issues Audio & Video Issues Startup and Boot problems Windows updates Windows 10 upgrade issues Computer Tune-up Issues Virus Removal Issues Data Backup, Transfer and retention issues All these issues and many more, concerning Toshiba users are directly and efficiently resolved by our technically knowledgeable team who can be Reached 24/7 on our Toshiba Contact- +1 888 784-9316.
    Jun 23, 2018 | Toshiba Computers & Internet
    Computers & Internet Logo
    239 people viewed this question
    David Payne
    David Payne
