Question about Polaris 3900 Sport Pool Cleaner ()
Where does the spring attach on the Polaris 3900 Sport
Sport 3900 is doing wheelies will not stay level to clean
1. Check the wheel RPM. If not in the 30-36 RPM range, refer to the manual for adjusting the wheel RPM.
2. Adjust the thrust jet downward.
3. Verify the backup valve is cycling. Lift the valve out of the water and watch the jet. It should come on and go off.
4. Check for water inside the head float.
5. Empty the filter bag.
You can download the 3900 Manual from the Polaris site
http://www.polarispool.com/Pressure/Polaris-3900.aspx
It will show you how to check the wheel rpm and how to adjust the thrust jet and check and adjust the float.
Jul 06, 2014 | Polaris 3900 Sport Pool Cleaner ()
Why does the valve at wall on polaris 3900 sport keep popping up
The mechanism of the polaris is driven by water pressure. If too much pressure gets to the drive mechanism, it will break. This valve allows extra water pressure to escape before it gets to the machine and rips the drive mechanism apart.
Jun 02, 2012 | Polaris 3900 Sport Pool Cleaner ()
What would cause the 3900 to run but the tail does not move?
Make sure that the feed hose floats are properly attached and spaced. Make sure that the opening at the end of the sweep hose is not blocked. You might also need to adjust the power to the pool cleaners sweep hose. To adjust the motion, turn off the booster pump and turn the sweep jet clockwise to increase motion.
Jun 24, 2011 | Polaris 3900 Sport Pool Cleaner ()
Hello. i have a Polaris 3900 Sport - 1 yr old. lately i notice that the drive chain is coming off of one of the sprockets, so that only the single wheel is driving and the cleaner just runs in circles. ...
Im trying to fix the similar problem...the sprocket on the gearbox is worn Part# 393-204. Unfortunately. u have to buy the whole gearbox. BS in my opinion. U should just be able to buy the sprocket...Im trying to figure how to do this with Polaris.
Apr 14, 2011 | Polaris 3900 Sport Pool Cleaner ()
Polaris 3900 Sport Pool Cleaner () Logo
Top Polaris Pool & Spa Experts
Jay Finke
Jay Finke
David Spradling
David Spradling
Michael Vincent Cruz
Are you a Polaris Pool and Spa Expert? Answer questions, earn points and help others
