Unprotect imation lock - Computers & Internet
What is the password for the new kingston USB DT109?
It is true that locking mobile storage devices, such as USB drives, with Imation Lock is an excellent way to protect your data.
However, using Imation Lock with a Kingston USB drive can create problems.
Learn how to unlock your Kingston USB drive so you can use it once again.
Ensure that your Kingston USB drive has been removed from your computer's USB port.
Start the Imation Lock software by double clicking the Imation Lock.
Plug in the Kingston USB into a USB port immediately after the "Please Insert the Device or Run This Utility as Privileged User" message appears.
Access your Kingston USB drive by clicking Start > Computer.
Double click on the device.
Start the Imation Lock software again by double clicking the Imation Lock.
Disable the password protection by clicking the open lock icon.
or
If you have password protected a USB drive or partition on your computer and have since forgotten the password, you will need to completely erase the drive.
Erasing and reformatting the drive will remove any password protection, software and data on the drive preventing you from accessing the drive.
The process is simple using Window's Disk Management utility.
Log into the computer as the administrator.
Open the Windows Start menu, select "Run," type "Compmgmt.msc" and click "OK." In Windows Vista and Windows 7, simply type the command into the "Search" field.
Select "Disk Management."
Locate the password-protected drive.
Right-click it and select "Delete." Confirm the action.
The drive will be erased and become unallocated free space.
Hope this helps.
Nov 28, 2012 | Kingston Ultra Thin DataTraveler DT 109...
My new imation 2.27 flash drive is write protected. How can I unprotect it?
click start click to open on my computer you should see your usb drive E: right click select properties there will be an array of options
select the sharing tab option then advanced sharing make sure you have a tick in the share this folder box
then click permissions make sure you have all 3 boxes ticked full control changes and read in windows 7
click start control panel user accounts click on the administrators account if you have made one or you will have to create one in windows XP
click start right click on my computer select open
Right click the icon of your usb drive (It should be E:/ or something)
Click Properties in the menu that comes up
Click the Sharing tab
Click permissions
And finally, click Allow next to Full Control.
hope this helps you
Mar 25, 2012 | Imation 27126 DEFENDER F50 PIVOT FLASH...
How do you unprotect pictures to delete
While viewing the particular locked photo, press the Menu button and select Lock/Unlock to toggle. Your camera's menu might also call it Protect/Unprotect. Hope this helps!
Mar 02, 2011 | Kodak EasyShare V1073 Digital Camera
I forgot my password in Imation lock.
(assuming you're using Microsoft xp): drop into the DOS shell and force a format of the flash drive. This'll clear everything off it, including any locking mechanisms.
Jul 25, 2009 | iLO (2 GB) MP3 Player
Key lock imate sp5
Press the power button on top, and select '3' Key Lock.
Unlock using (Left-Menu)button & *
You can setup a timed lock, but this requires a 4-digit PIN to unlock which is a hassle for normal use.
Jun 26, 2009 | i-mate SP5 Smartphone
I had problem with imation lock
how format flash imation 8 gb write protected
Mar 25, 2009 | Electronics - Others
How to unlock imation lock software in a not imation flash drive?
http://www.fixya.com/support/t845221-run_imation_lock_kingston_4_gb_now_its
Oct 14, 2008 | iLO (2 GB) MP3 Player
I had run imation lock on kingston 4 gb and now its says "Please insert the device or run this"
its a little tricky, just try it
  1. unplug ur usb drive
  2. double click the imation lock
  3. when the message appear "Please insert the device or run this utility as privileged user" plug the flash/usb drive quickly
  4. USB will start working
  5. run the imation lock again and disable the password protection
  6. delete the ugly imation lock from ur system
i hope u find it use full, plz give ur feed back at: masood@inbox.com
Jul 28, 2008 | Computers & Internet
Computers & Internet Logo
70 people viewed this question
David Payne
David Payne
