Question about HP LaserJet P3005 Printer
HP Laser P3005dn having paper jams more and more
I have a similar problem with our printer starting to jam and it is getting worse. We use it in a shipping department where it gets alot of use. The enviorment is clean to a degree but somewhat dusty at times, can anyone help?
  • 4 Answers
If it gets a lot of use and the pickup rollers has not been changed, i would start by that and keep cleaning it sinse dust gets on it and makes it slippery.....to clean either run a test page or print something and use a moistened rag so the roller cleans itself as it rotates (of course remove the paper cassette)
Posted on Aug 20, 2009
How to clear a paper jam in my printer?
  1. Turn off the machine, and unplug the power cord of the machine from the power supply.
  2. Open the paper output cover. ...
  3. Make sure that the jammed paper is not under the FINE cartridge holder. ...
  4. Hold the jammed paper with your hands.
  5. Pull the paper slowly not to tear it, then pull the paper out.
to know info SAF 2507 pipe fittings
May 20, 2016 | HP PSC 950 All-In-One InkJet Printer
My HP color Laser Jet 2600 printer has a paper jam
Jul 21, 2014 | HP Office Equipment & Supplies
Take apart hp3005dn
Analyse what type of jam it is...based on that we can shoot the trouble.1. Paper is jamming before entry in fuser and its folds like curl in the cartridge area.. A. Fuser Teflon sleeve not rotating or slow rotation results media(paper)unable to reached the destination in specified interval. Replace fuser assm or Teflon sleeve.2. Paper jamming after fuser assembly crossed little bit ( approx 1-2 inch).A. Clean fuser out paper sensor, check sensor flag & flag spring located in fuser assm.3. Paper jammed after fuser crossed more than 6 inches..A. Check paper pick up roller warn out(tray1 or 2), check registration sensor located under registration assm.How to remove fuser assm: remove back door, see the snap shot...
Registration sensor location:
Pick roller roller tray 2 :
1_9_2012_3_54_49_pm.jpgPl try it carefully..Best of luck...
Jan 09, 2012 | HP LaserJet P3005n Printer
Repetitive paper jam in the fuser area in a LaserJet P3005dn
Your lower press roller in the fuser may not be turning all of the time since it is driven by the upper film. Rough them up with Scotch Brite Pads
Happened a lot on hp 4000's
Jun 03, 2009 | HP LaserJet P3005 Printer
Error 13.10 paer jam in HP laser jet 5100 DTN
HI ayyasamyr:
This your problem.
13.10 PAPER JAM The event log message for a paper-delay jam in the duplexer is 13.10.
1. Check the duplexer and the rear area of the printer for obstructions or damage.
2. Check PS1701 and PS1703 in the duplexer for correct operation. Replace the
duplexer if a sensor is defective.
Hope this helps
May 21, 2009 | HP Office Equipment & Supplies
Paper jam in hp photosmart c4280
What have you got to loose, get in there and try!
Mar 27, 2009 | HP PhotoSmart C4280 Laser Printer
HP Laserjet P3005dn Printer Jam with no real jam
Check to make sure the paper tray is properly adjusted. All the stops should be against the paper and there should be no space for the paper to move around.
Nov 07, 2008 | HP LaserJet P3005n Printer
Dell 1700n Laser Printer paper jams
Some questions first: -Where in the paper path is it jamming? -Is it always in the same spot or does it vary? -Roughly how many pages have you printed with this printer? -Did anything lead up to this or has it progressively gotten worse?
Feb 20, 2007 | Dell 1700n Laser Printer
HP LaserJet P3005 Printer Logo
315 people viewed this question
Seeker5211
Seeker5211
