Led keyboard w9868
Is there a substitute driver mine keep popping up errors with a Keyboard (?) Beside it
sandrew
  • 2961 Answers
SOURCE: Sony vaio VGN-FS640/W Keyboard Error
Check the key isn't stuck down first, if not you may have a corupt driver, go to my computer< right click>properties>hardware tab>device manager and then in the next window, go down to keyboards, click on the'+' sign and right click on the line and select uninstall. Restart you pc and the keyboard will be re installed automatically and the driver loaded. Try again.
Posted on Apr 28, 2007
  • 38 Answers
SOURCE: Keyboard worked Friday, now doesn't work
if it is new & under warranty, best bet is Acer service center.
Posted on Sep 24, 2007
IB4G2008
  • 3587 Answers
SOURCE: Need to disassemble keyboard
well..there's a small panel, usually just above keyboard, with a slot on end. Take a small blade screwdriver, and open that up GENTLY>
then, there should be two or three screws holding down the keyboard..remove them, and lift the keyboard CAREFULLY, so that the connection cable underneath doesn't get tweaked.
then, place the keyboard, face down, on a paper towel to drip dry, then you can air blow it out. Hopefully, the pop won't have compromised the keypads underneath. But don't be surprised if some of them are no longer usable.
got backup for your Acer?
Posted on Feb 12, 2008
Nick_Savage
  • 45 Answers
SOURCE: key popped off keyboard
On the Keyboard, There should be a small little clamp housing. On the back of the key you should see a piece of metal that is sort of Staple shaped (A non bent staple) Just try and put the ends of the metal into the housing, Then apply a little amount of force onto the key to pop it back in.
Before applying pressure, Make sure that both ends are properly in place.
Hope this helps!
Posted on Jan 05, 2009
Geekman
  • 32281 Answers
SOURCE: substitute keyboard for t30
Replacement keyboards for laptops are available on the Internet.
I purchased one from Yall Store
Use this link :-
http://www.yallstore.com/index.php?main_page=advanced_search_result&search_in_description=1&zenid=1lrjst3ncshlb4c7frn9bev3c3&keyword=keyboards
Posted on Jul 25, 2009
My keybord is not working
Keyboards fail sometimes and it pays to have a spare - I have a dozen...
As the computer boots some of the keyboard leds blink and there should be a beep from the computer showing there should be no problems. Substituting a know good keyboard is the quickest and easiest method.
Oct 30, 2016 | Computers & Internet
MY DELL PC BEEPS 6 TIME, SHOW AND KEYBOARD ERROR AND DISPLAY A ORANGE LED AT THE MOTHER BOARD
The Dell user manual has the beep codes, which usually are in sequences with short pauses between. To figure out the problem one needs to know the spacing of the codes. Is it 1-2-3, or 2-2-2, or 3-1-2 or what? The first thing I would check is the RAM - make sure it is seated correctly, and try removing all but one stick.
Jun 24, 2014 | Dell OptiPlex GX620 PC Desktop
No fn key on my inland pro usb keyboard what is the fn key substitute
Reference to a Fn key means any function (F) key. For example, Fn = F8 where n=8
Feb 25, 2013 | Inland Pro Usb Keyboard
Just a quick question, I need to replace my keyboard on my acer 5534 laptop, found a new one, have it ordered, how easy is it to replace the keyboard or should I let someone else do it?
pretty simple turn off the pc flip it over take ur battery out then there will be holes with screws with little keyboards beside them indicating the mounting screws positions remove them open the laptop pop the key board out some models will need another piece of the bezel to be removed to achieve this if it seems to daunting get some help and good luck with this
Dec 19, 2010 | Acer Aspire 5500 5570-2609 Laptop
Where on keyboard is indicator to show caps lock on or off?
it is not on the keyboard, but on a LED light on the panel, on the hinge cover.
Oct 26, 2009 | Dell 0Y3740 Keyboard
Keyboard stopped working
Have you tried cleaning out the keyboard?
Dust can get in there & play havoc on the plastic board inside of it.
I take mine apart every 9mos to a year, completely.
Jan 05, 2009 | Logitech Elite 967234-0403 Keyboard
Wireless keyboard keys sticking
on most keyboad you can take of each key. Try to get a flat head screw driver and pop it of with some force. You then can clean the keys. If this does not work you might need a new keyboard. Do not use water (or very little)
Sep 20, 2008 | Dell Latitude C640 Notebook
Keyboard problem
First off try a friends keyboard if that works OK then yours has a high probability of being stuffed Buy new one
If friends plays up you have a registry or system fault
Go to windows explorer c:\ right click/properties/tools/check now a box will popup tick the square to automatically fix errorrs reboot when windows reboots it will scan for error and fix them when done will automatically retart check if keyboard is OK
Jul 27, 2008 | Compaq Keyboard
Keyboard not functioning
key board dead , correct. ? even the caps lock key will not toggle its led.
my guess is you bought a clone keyboard from china, on fleabay
and its dead. as many are, some are wired wrong.
the ribbon cable on mine fits to a special connector that likes to break easy, is your broken this locking jack there?
is it plugged in upside down?
why did you buy a keyboard. was the other dead.
when did the keyboard fail. list week last year, or never
i bought it for cheap with dead kbd....
there is no HP drivers, HP retired this old PC, after 10 years.
so what makes you sure your non HP drivers are any good.?
NO OS stated, not even a clue. XP?
what I'd do , us boot to a Knoppix v7 live boot(dvd/usbstic)(linux)
if the keyboard fails NOW, then its bad KBD. or the jack cable or connector there, (or inserted wrong) or damage. there.
buffer chip is blown up with ESD events. (electrostatic discharges)
is the keyboard dead in BIOS
on ours we hit ESC or F10 and BIOS screens pop
power on hammer ESC or F10 or what the screen tells you to hit.
the go in to BIOS screens, now test the keyboard.
using say the arrow keys to navigate the BIOS menus
if the ESC and F10 key are dead that is a bad keyboard.
what must work here is the electronics.
  1. correct keyboard, some clones will never work.
  2. cable not damaged
  3. cable not upside down
  4. connector there not damage the lock not broken,(easy)
  5. the MOBO buffer chip not ESD damaged.
  6. BINGO BIOS now works by key commands
Aug 08, 2017 | Compaq Presario Laptop
ASUS keyboard
if your phone is under its warranty you can have it fixed on the service providers. if not, the whole flip cover needs to be replaced. i had mine fixed by the asus service center.
Oct 16, 2007 | ASUS P505 Pocket PC
Computers & Internet Logo
12 people viewed this question
David Payne
David Payne
