Question about Pitco Frialator Kitchen Appliances - Others
Power flush when I turn the pump on the oil dont go up to the frier
  • 23 Answers
You have a clogged filter, clogged lines or clogged pump. Did you try to do this with the oil cold? If so, the pump has to work MUCH harder and may not pump.
Clean out the oil from the entire system, looking for clogs. Manually filter the oil and pour it back into the system and try it again.
Posted on Apr 05, 2016
I have read the owners manual and it does not say how much water and oil to put in, need help?
You do not put water or oil in an air frier As the name suggests it uses hot air to cook food, If you cook home made fries then I suggest you boil the fries for a few minutes (depending on thickness ) then pat dry and put a light spray coating of oil on prior to Air frying.
Oct 13, 2017 | The Kitchen Appliances - Others
What temp and how long to cook a 10 lb ham in a turkey frier?
12-17 minutes per pound at 375 is recommended for an oven. I'm not sure of the difference between the frier and oven. Most prepared hams are fully cooked or smoked. Here's a link to check other info on cooking hams.
http://www.bettycrocker.com/how-to/tipslibrary/cooking-tips/how-to-cook-a-ham?utm_source=Email_newsletter&utm_medium=email&utm_campaign=BC_12_23_2016&vcode=AQAAAABFsdYhKGypebKYiGtyMEVUHdxcQGJZky68gCbk2ZRXpAh84Fo6UreMNu2noN699yr-uZMq-s5WshjGdi7heKqVYFWyADXTRxPbFUM4Wf8JXA
Dec 25, 2016 | Grilling
Peugeot 308 low oil pressure and loss some power
Low oil pressure starts from oil pump sounds like its blocked either in the pump filter or galleries in the enging. I would first call the dealer and check what filter system is on the pump which may require removal of the sump to replace or clean.
I would certainly not use a car with this problem as it could well cause engine failure. Try a good quality flush first and run the car for 20 minutes minimum on tick over. Remove and put a good quality oil in and do another oil change again if required a month later with a flush to make sure the gunge is out.
If this does not help do an oil pressure test and see what it comes out at checking the manufacturers recommended pressures. If you have changed the oil, pump filters and done a second oil change and still get low pressure then you may well have a faulty pump.
I would also check the oil pressure switch to make sure it s not giving a false reading. The loss of power sounds like Turbo failure and again dirty oil to the Turbo oil feed pipes could be restricitng flow, hence why regular flushing oil and filter change is important.
I would get the Turbo checked out same time as on this model it could well be a Turbo and engine change if its gone that far due to the metal particles contaminating the engine.
Jul 11, 2014 | 2010 Peugeot 308 HDi
Frier top blew off andhot oil flew every where
WOOOAAAA>. hope no one was hurt!!
Did you put frozen items directly into the HOT oil the close the top?.. the excess water (frozen particles) will melt and try to homogenize with the oil.. since water and oil don't mix,, the oil and water expand quickly... liquids cannot be compressed, so the excess pressure escapes at the path of least resistance - by blowing the top off..
Feb 12, 2014 | Bravetti Kitchen Appliances - Others
Sugar in a gas Tank
no you have to drop your gas tank clean it out. if you didn't start then just clean gas lines. if you started it then you need a new engine. the sugar gets in the engine and turns to syrup. bad engine.
Jan 28, 2013 | Ford Cars & Trucks
I have a 1997 Ford Escort 2.0L when my rpm gauge goes below 1500 the oil light comes on. When I step on the gas and it goes above 1500 it shuts off what can this be. I check for oil loss and there is none....
DONT overfill the oil..If its overfull,,DRAIN immediately..You WILL do damage if its 3 quarts over..Sounds like a possible oil pressure sensor..If it makes a ticking sound at idle or tries to overheat,,you may have a oil pressure problem..The suction screen on your pump could also be stopped up...I f you havent been changing the oil at the right intervals ,,try to run some engine flush and drain the oil and see if that helps..Follow the directions on the flush,,and do not drive it while flushing it,,this could also do damage..If the flush doesnt work,,and you cant check your oil pressure,,than i would try replacing the sensor..Worse case senerio your oil pump is bad...
Sep 27, 2011 | 1997 Ford Escort
Just had the fuel pump replaced in my 1997 buick lesabra. Yesterday the oil light started flashing but the car didn't run rough it is over full with oil by a quart. Today after driving the car about...
no reset button. If the oil is overfull FIX IT. find out why the oil light is flashing, and dont drive it until that is FIXED. if you dont have oil pressure you will destroy the engine. thats why its RED and FLASHES so you will see it and turn the engine off.
Aug 03, 2011 | 1997 Buick LeSabre
Replaced motor, 1st no oil pressure to guage, but motor seems to have pressure,2nd,replaced radiator, drove 6 miles round trip town and back, flushed radiator,then started and ran motor for couple min,...
As to the oil pressure check your oil pres. sending unit for power with a circuit tester while vehicle is running replace if necessary. First check the fuse for the fuel pump if it has powere on both sides when key is on check the fp relay (when you power a relay if you listen closely or put your finger on it you can normally hear or feel it click which is the equivalent of turning on a standard light switch) if none occur replace or if you can access your fuel pump check for power with key on if it has power but does nothing the pump needs to be replaced
Apr 23, 2011 | 1997 GMC Sierra
How can you flush the steering gear box after removing old power steering pump 98chevy C1500 silverado? I dont want any old fluid to get in the new power steering pump.
Leave the return line disconnected from the pump and run into a bucket. fill new pump and start engine have some one keep adding fluid until clean fluid is going into bucket. Caution make sure to secure hose to bucket or you will make a mess. Also turning the steering wheel about a half turn in each direction Will help it to flush out the gear box better.
Feb 17, 2011 | 1998 Chevrolet K1500
Kitchen Appliances - Others Logo
154 people viewed this question
Top Pitco Frialator Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Paul Carew
Treefrog15
Treefrog15
Are you a Pitco Frialator Kitchen Appliances - Other Expert? Answer questions, earn points and help others
