Question about American Standard Plumbing
American Standard loose gooseneck from base no placement
    Top Expert:
  • American Sta... Master
  • 46,177 Answers
It can be snugged down
Posted on Jan 24, 2015
  • 297 Answers
SOURCE: American Standard Colony Soft gooseneck kitchen faucet leaks base
at the spout near the base is an echeion ring. turn this counterclock wise then pull up ring to expose the neck,pull spout straight up.this echeion cap holds on the spout to the base there are plastic parts inside so be careful when pulling apart.
Posted on Jul 22, 2009
  • 54 Answers
SOURCE: my american standard kitchen fasset is leaking at
You will need to replace the o rings. Buy the proper kit from your local hardware store. Turn the water off. Remove the handle (screw under top cap0 and the spout will slide up and off. Replace o rings and lube them with plumbers grease or Vaseline.
Posted on Sep 14, 2009
  • 102 Answers
SOURCE: When I tgurn on the hot water on our American Stan...
Without seeing it I have to go by your descrption and my first guess would be the diverter. I would replace it and see if that does the trick.
Posted on May 22, 2010
packrat1948
  • 528 Answers
SOURCE: base of faucet leaks- cannot remove set screw at
if you are having trouble removing the set screw make sure you are using the correct size allen wrench and confirm that it is a allen screw and not a trox screw. After doing this try tighten the screw slightly before loosening it. This should break it loose.
Posted on Feb 25, 2011
  • 207 Answers
SOURCE: American Standard Jasmine 3821.834 leaking where
How long have you had this? is everythign tight? check underneath the sink to ensure all connections are tight. The spout may have came loose, and it may not be able to be fixed, may need to be replaced.
Posted on Mar 29, 2011
American standard fairbury 4500 Series swivelling problem
Pull up on gooseneck and turn counter clockwise until you feel gooseneck thread into the housing a couple of turns
Jun 02, 2012 | American Standard Plumbing
When dishwasher is running, water leaks under base of our American Standard Colony model soft two-handle kitchen faucet into cabinet beneath sink
Is there an air gap next to the faucet that is leaking. If so, it is probably clogged. Pull the cap off of it and clean it out. This is what it may look like before you take the cap off.
b7ookdehz3uf293omx2ye0fveemyn-clsycdlpsjpi2zdtnzgmj_hhepw5uyprhfsmyzy7tnfmt6uzrk1edu-duydxm839afzrsaplofdfdjymmjvj8xncabtrcoevtu5jguw1elsvyttyypguy-89xi_btsfhkvzgvdbfbda26sii9hwd8sgq
Jan 16, 2011 | American Standard 4275.550.002 ColonySoft...
When I tgurn on the hot water on our American Standard Gooseneck Cadet with sprayer it sclunks and then shuts off. Is this diverter problem or do i need a new cartridge?
May 19, 2010 | American Standard 4275.550.002 ColonySoft...
Jul 13, 2009 | American Standard 4275.550.002 ColonySoft...
How to replace sprout seal kit in american standard faucet ?
just pull straight up,wiggle back and forth,the o-rings are holding it on .
Jun 05, 2009 | American Standard 4275.550.002 ColonySoft...
Leaking at base of spigot
duh....replace the o ring or the packing.
Mar 08, 2009 | American Standard 4275.550.002 ColonySoft...
Plumbing Logo
212 people viewed this question
Top American Standard Plumbing Experts
Donni Steen
john h
TED
Level 1 Expert
Are you an American Standard Plumbing Expert? Answer questions, earn points and help others
