Question about Scunci 52033 Canister Wet/Dry Vacuum
I have had the battery on charge for 24 H\hours. The charge light is on. The other light is off and the battery is still dead.
How long does it take to charge the cordless vac?
The basic rule of charging is "charge for 3 hours for every hour of use".
You won't hurt anything if you charge it overnight, but don't leave it charging for more then 24 hours.
If you wear the battery out eventually, Batteries Plus can re-pack the battery.
Nov 18, 2016 | Vacuums
Roomba 630 dead or other issue?
On your operators manual there is a number u can call for cust support. If not then take back for swap out.
Dec 12, 2014 | Roomba iRobot 630 Vacuum Cleaning Robot
Why doesn't my battery charge? Why doesn't the charger's light come on?
Hi Suzanne! Follow these steps to check that your charger and battery are working properly.
1. Unplug the charger for at least 30 seconds.
2. Plug the charger back in. The blue light on the charger should flash once.
If the blue light flashes once this is an indication that the charger is still functioning properly. If the blue light does not flash, the charger will need to be replaced. Follow this link to order a replacement charger. LiNX Battery Charger
3. Place the battery in the vacuum and turn it on for 30 seconds. (even if it does not turn on or powers off)
4. Turn the vacuum off.
5. Remove the battery and place it in the charger.
If the light on the charger is solid blue this is an indication that the battery has been reset. Allow 3-4 hours for the battery to fully charge. The blue light will start to blink slowly to indicate the battery is fully charged.
If the light on the charger is flashing blue or there is no light at all this can mean that your battery needs to be replaced. Follow the link to order a replacement battery. LiNX Lithium Ion Battery
Hope this helps!
Jul 28, 2014 | Hoover Platinum LiNX Cordless Stick Vacuum
My DD hand vac won't hold the charge for more than one minute and just fades away! It has been charged for 24 hours.
Hi there! Your battery may need to be reset. Try depleting the battery. Run the vacuum until it completely shuts off, then re-charge for a full 24 hours. Hope this helps out! If you still have questions you feel free to reach out to us here on Fixya, Facebook.com/dirtdevil, or Twitter @DirtDevil.
Jun 30, 2014 | Dirt Devil Vacuums
Flashing lights.
The Flashing lights indicate several different things. 1 flashing red light means its time to charge your unit. if it is still flashing after charging then you will more than likely need to change the battery. A flashing red and green light means that the unit is overheating which could happen if the filters need to be washed, or that there is a blockage or if your machine has been left in direct sunlight. Allow 1 hour for machine to cool down. 3 flashing lights indicated that the pre-filter has been put on incorrectly. I hope this helps. If you do decide to wash your filter dont use any type of soap it is not needed and allow fiter to dry for atleast 24 hours. putting a wet or damp filter in will damage your machine.
Sep 18, 2011 | Dyson DC16 Root 6 Bagless Handheld...
I HAVE A BLACK & DECKER DUST BUSTER CORDLESS VACUUM. I'VE HAD THE CHARGER PLUGGED IN FOR ALMOST 24 HOURS AND IT IS STILL DEAD. SHOULD THE SWITCH BE IN THE OFF POSITION OR THE MIDDLE POSITION. IT'S...
I am not certain about this specific battery, however, if many batteries are unused for a long period of time, they can not be rejuvenated.
Try the switch in each position for 24 hours and if there is no action, it is probably not worth repairing.
Gary
Feb 20, 2011 | Black & Decker AV1200 DustBuster Handheld...
Old or New battery not charging...or so it seems (Discovery 4XXX)
the charger is not charging its not putting any thing out into the batterys the charger clock is working but your not getting any charge from it
Mar 21, 2010 | iRobot Roomba 4210 Bagless Robotic Vacuum
Seems to charge but then wont come on
Sounds like you bought a defective battery
You can test for this by removing the battery and holding the power button for 15 seconds. This will restart the charging cycle as if the battery were new. If it still goes red get a refund and a new one.
Mar 07, 2010 | iRobot Roomba 4105 Bagless Robotic Vacuum
New battery. Charged for 24 hours. Light is green, but after 20 seconds light turns red and it stops.
There's a chance that the battery you bought is bad. There's a greater chance that the problem is with the charger. If you're using the dock to charge, try plugging the charger directly into the roomba just to rule that out. If that doesn't fix the problem, I would try borrowing or buying a new charger, and see if that works. If a new charger and new battery don't solve the problem, the problem must be with your roomba itself.
Sep 25, 2009 | Roomba Robotic Floor Bagless Vacuum
Scunci 52033 Canister Wet/Dry Vacuum Logo
48 people viewed this question
Top Scunci Vacuums Experts
Craig Butler
Craig Butler
Are you a Scunci Vacuum Expert? Answer questions, earn points and help others
