Question about Craftsman 42 in. Deck 19.5hp Lawn Tractor
Mower has to be chocked to run
I have a 42" 19HP craftsman riding mower that requires the choke to be pulled out to run. I have changed the in-line fuel filter, removed the carberator bowl and cleaned it, replaced the air filter & pre-filter, blew out the fuel lines, drained the fuel tank and used fresh fuel. It runs great for a little bit( 10-15 min), then seems to load up and require more choke to keep it running.
Oftentimes, this problem is the result of mowers left outside in ambient air that is high humidity. This, in turn, allows algae to grow inside the carb fuel float bowl and/or inside the fuel tank if left out for extended periods (one month or longer). Also the same thing will cause air filters to clog rapidly with mold and mildew - slowly at first, then more rapidly as the mold continues to grow. Get out the carb cleaner in spray cans and go through every ported passagewway in the carb body then reassemble using CLEAN screws, gaskets and all interrior parts. Any residue mold or mildew will continue to grow - and it can grow in gasoline!! Imagine that!!
Posted on Oct 26, 2012
    Problem Solver:
  • 6 Answers
It still sounds as though there is a passage plugged in the carb or maybe a leaking gasket. The carb is obviously not pulling gas through as designed, which explains the need for choke. Try a rebuild kit, and blow carb cleaner through every tiny passage.
Posted on Jun 25, 2009
Engine acts like it is running out of fuel
Remove gas line from carb. Fuel should run out. A pluged fuel cap vent could the problem.
Nov 11, 2013 | Yard Machines 13AC762F000 38-Inch 344cc...
My craftsman riding lawn mower only runs with the choke pulled out
You have fuel restriction . Unhook the fuel line from carb. Should run out.
May 15, 2013 | Craftsman Garden
24 hp Briggs Stratton sears riding mower engine wont start unless you use start fluid cleaned filter have flow to engine
If the mower starts and continues to run after injecting, you may want to make sure the choke is working properly. If the choke plate is not closing all the way, it will make cold starts difficult.
Feb 12, 2011 | Craftsman YT 4000 42" Briggs Stratton 24...
Riding mower turns on when the choke is pulled but turns of when the choke is pushed back in. Sometimes it stays on but after a few minutes sounds like it is running out of gas and eventually turns off.
When were the air filter and fuel filter last replaced? Those are the two suspects to cause your problem and unless the mower is pretty new, or they were replace in the last year or two, start with those.
Aug 14, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Troy-bilt bronco riding lawn mower choke problem
Check your air cleaner...then check fuel line from pump. Pull fuel line off carb make sure fuel is present. :)
Sep 07, 2009 | Garden
Have to hold chocke out to keep it running
sounds like the needle and seat is dirty within the carb
Aug 11, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Engine problem
Most probably there is a restriction of gas flow in the carb from varnish, trash or rust. The carb need to be cleaned/repaired.
Jul 03, 2009 | Garden
Craftsman 16 hp 42 in. riding mower won't run when clutch is released
If the engine feels like it is being choked, then something might be catching or bound up...for example the blades may have been installed improperly and will not rotate. Make sure that you can rotate the blades by hand...if not they may have been tightened and are binding against the mower housing.
If there is no engine choking...then it may be electrical for example a bad fault switch...take it to your mower shop.
good luck
Sep 27, 2008 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 42 in. Deck 19.5hp Lawn Tractor Logo
461 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
