Sears electronic typewriter types but no image on paper
Typewriter seems to be typing, good ribbon, but no letter appear on the page. Seems not to be striking hard enough.
  • 478 Answers
Depends on the model could be a cracked hammer or hammer driver
Posted on Oct 25, 2014
SOURCE: typing different letters than what i am striking
How do I set keyboard 1? I see 2 and 3 on the keyboard but I don't see 1. Where is it? What letter is it on it?
M
Posted on Dec 14, 2007
  • 3594 Answers
SOURCE: IBM Wheelwriter 3 not striking ribbon onto page
There is a plastic cap on the print solenoid plunger that is probably broken, they are available but a little tricky to install.
DickyO
Posted on Sep 29, 2008
  • 3594 Answers
SOURCE: Wheelwriter 5
You probably need the plastic cap that is on the proint solenoid, they are available but a little tricky to install.
DickyO
Posted on Oct 02, 2008
SOURCE: typing
Something else you might check, I was having same problem. Make sure the Daisy Wheel Lock Lever (check the description that comes in the guide) is locked in place, i.e., push it forward to lock. It is the black thing that sticks up on the right inside the correction tape. I did this and words started appearing. Hope it helps.
Posted on Feb 17, 2009
  • 215 Answers
SOURCE: My typewriter doesn't type..won't display letters, but keys work.
alot of the brother t/w's have 2 cam assemblies under ribbon holder. 1 operates the print hammer and 1 operates the correction ribbon lift. sometimes these will hang or lockup. sometimes turning on and off a few times will take care of it, but sometimes it needs to be worked on by a t/w tech. if you look when you type a character, most likely the print hammer is not firing or it is striking the correction ribbon instead of the black ribbon.
hth,
razors
Posted on Feb 27, 2009
My Remington Noiseless 1939 typewriter has ghosting on the letter keys. I have put on a new ribbon but this just shows up the ghosting of each letter more than ever. I notice when typing the carriage
Could also be that your paper is too fibrous of finish. I found this page because my typewriter was ghosting, too. I adjusted some of the settings and there was not a trace of ghosting. I put the settings back and still no trace of ghosting. Then I realized that I tested for ghosting on paper that has a much smoother finish. I was ghosting on cheap paper we use here at work. So, I don't blame the typewriter. I blame the cheap paper. My typewriter just likes good paper.
Nov 14, 2011 | Office Equipment & Supplies
When typing a few letters with be complete on the page, but then no letters are typed on the page. I have switched out typewriter ribbons and it does the same thing.
Type on a multi page form, if the carbons are good you have aribbon feed pr lift problem. If no good then the plastic print solenoid cap is broken. We sell them with instructions and shipping for 20.00.
DickyO
Cleveland business Machines
216-241-0027
Dec 30, 2010 | IBM Wheelwriter 30 Typewriter
What is tyyping capacity of SMC 17657 ribbon cartridge
The 17657 ribbon is the side loading "pork chop" ribbon is a fabric ribbon and it shoulden't run out just get lighter until you change it you may just have a bad ribbon.
DickyO
Apr 13, 2010 | Smith Corona Office Equipment & Supplies
Typewriter is working fine but won't type anything on the paper - new ribbon / new printwheel - no impression. Appears to be stuck on a
Try typing on a mulipart form. If it types on the copies and not the orinonal the ribbon is the problem. If it dosen't type on the copies then the plastic cap on the print solenoid is broken.
We sell the cap with installation instructions for 20.00 includes shipping.
DickyO
216-241-0027
Jun 02, 2009 | IBM Wheelwriter 30 Typewriter
Incomplete letters when typing
Ribbon not lifting high enough maybe because it is loose. check ribbon itself if you wind it up does it stay tight, if not bad ribbon.
Jun 17, 2008 | Brother GX-6750 Typewriter
IBM Wheelwriter 30 series II - prints only half a letter
If it types only the top half yhe platen is probably not all the way in. Make sure the 2 black latches are lined up with the side frames then press down firmly on both sides of the platen.
DickyO
Apr 14, 2008 | IBM Wheelwriter 30 Typewriter
Letter skipping
Take a look at the ribbon, making sure it is moving eack key stroke you should be able to read you typing thru the ribbon.
Jul 09, 2007 | Brother SX-4000 Typewriter
70 people viewed this question
k24674
jasbo
jasbo
