Question about Mitsubishi WD-65738 DLP TV
Mitsubishi wd-65738 screen bent outwards - Mitsubishi WD-65738 DLP TV
5 Suggested Answers
gopakumarg43
  • 74383 Answers
SOURCE: I have a mitsubishi wd
Hello
Its bulb has got traoubled or its control circuit has some faut with it. it is not a user serviceable item. Replacing bulb can be done by the user according to the instructions in its user manual. But trouble shooting its control section must be done be any experienced service technician. OK.
Posted on May 27, 2011
  • 8457 Answers
SOURCE: I have the Mitsubishi WD-65738
Tv "LAMP" LED light indication on the tv frame word light up or blinking LED light.Check the tv projection Lamp first.The tv projection Lamp might litterly broken into glasses sharts itself.The tv projection lamp still intact,still should be change too though.After the tv projection lamp has been change the tv should work now.If still have problems the board that call the Balast board probally dead too.Becauuse this Ballast board only jobs are to help to ignite and keep tv projetion lamp light up and to work only.
Posted on Sep 01, 2011
SD Tech
  • 14553 Answers
SOURCE: I have a mitsubishi wd 65738 and peoples faces appear smudged on the cheeks. Almost like a 5 o clock shadow. I have seen this before on other DLP tvs as well. Is this a light engine or main board?
I have in the shop also seen this issue on a few Mitsubishi sets, you may want to search for the service manual but I worked for a authorized service center for this brand and they had all kinds of issues--one was when the Optical engine was replaced there was a procedure done with the remote to mate it to the main chassis (set had reddish smearing--not extreme but noticeable. the procedure cured that.
These sets had so many digital issues with dozens of surface mounted caps on several boards failing that a few years ago they offered an entire signal chassis on an exchange basis.
The engine as you may (from the tone of your question) be aware is in constant communication with the main signal chassis---not very helpful I admit but it could be either----if that chassis is still available it wholesaled for about 250 and the engine might be more than 500---they are nice guys as the engine does not come with some mounting brackets etc that have to be removed from old one.
Good luck and see if you can find (I have seen some on the internet) a free download of that which may or may not help.
Posted on Dec 04, 2012
SD Tech
  • 14553 Answers
SOURCE: make computer display fit tv screen mitsubishi wd 65738
If you are only going to use the set with the laptop here is a link to the service manual with electrical adjustments for height, width and other things---"enter at your own risk.'
http://www.scribd.com/doc/52160908/27/Service-Menu
Posted on Dec 15, 2012
I have wd 65738 Mitsubishi tv that has a problem can you help ME?
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Oct 17, 2016 | Mitsubishi WD-65738 DLP TV
Have blk an whte dots on screen.problem began after lamp replacement
will need the DMD chip replaced pt#:
1910-6143W http://www.tvserviceparts.com/1910-6143W.html $270.00
http://www.shopjimmy.com/catalogsearch/result/?q=1910-6143W
$189.99
This is critical part & requires a thorough knowledge of TV servicing to correctly install
Dec 27, 2014 | Mitsubishi WD-65738 DLP TV
65738 colors flickering after bulb replacement
check the colour wheel in the light engine most likely bearings are worn needs replacement and the colors will stabilize need to open the light engine and replace with a new one
Mar 08, 2013 | Mitsubishi WD-65738 DLP TV
Make computer display fit tv screen mitsubishi wd 65738
Dec 15, 2012 | Mitsubishi WD-65738 DLP TV
Mitsubihi WD-65738 no power, no lights. Is there a fuse I can check? Maybe by the plug?
Follow the power cord inside to the power board--line fuse will be there--have fun and patience as a lot of screws to remove to get there---as seen from rear power board should be to far left side.
Dec 03, 2012 | Mitsubishi WD-65738 DLP TV
Wd 65 733 I have read the posts arounf the white spots on screen. I currently have just a small amount popping up. Looking for cheap price on parts and labor. Thx Will in atlanta, ga
normally white spots are whithin the screen. it is also called "panel". it is the most costly part in the tv. but one need to inspect the tv first before making sure it need to be replace. try to disconnect all cables inside the tv by opening the back cover & fix them again.
Sep 22, 2011 | Mitsubishi WD-65738 DLP TV
I have a mitsubishi wd 65738. My picture suddenly went dim. I can still see a picture but the room has to be very dark and its still hard to see. Do I just need to replace a bulb?
Hello
May 27, 2011 | Mitsubishi WD-65738 DLP TV
I have a mitsubishi 65"
its auto sensing optimal format from the input used u can try to go into your settings to force it full screen possibly with remote
Nov 17, 2010 | Mitsubishi WD-65738 DLP TV
Mitsubishi WD-65738 DLP TV Logo
12 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
