Question about JVC AM FM CD DET FACE CAR STEREO
Tractor tunes cuts out when turned up - JVC AM FM CD DET FACE CAR STEREO
Mower runs fine turn on blades it will die
MikeMake sure that the blades will turn by hand (key out of switch- unplug the sparkplug wires!!!!) there could be a dirt mound or rock jammed in there. OR-
if you\'re in the seat and the engine dies just as soon as the blades are engaged, the engine may need a tune-up. It sounds like it starves for fuel or air under load.
May 04, 2014 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
My model Husqvarna CTH 171 does a great job as a tractor, hauling stone, wood etc. Recently it does less well at grass cutting. It cuts at the highest setting, but as soon as I lower the deck the engine...
It sounds like when the unit is under more load it stalls out. It could be that bearings on mower need to be greased or replaced. Or it could be something internal. I would personally check compression with a compression tester. They are fairly cheap and easy to use. They simply thread in spark plug hole, you turn unit over and observe gauge. Probably a good tune up with valve setting checked/adjusted would be a good idea too.
Oct 18, 2013 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
I have a 21 HP Kohler engine in my 2007 Sears 42 " lawn tractor. I did the 100 hour tune up last year. It's been fine up until this week when I would notice a puff of white smoke towards front, possibly...
Oil will be drawn into the engine under heavy acceleration, irrespective of load. Check this before you worry! You might also check for any external leaks of oil or hydraulic fluids around the exhaust area which could cause white smoke at odd intervals.
Good luck
Aug 27, 2013 | Husqvarna Riding Lawn Mower 46 Cut Kohler...
I have a model # 917.289720 mower. It dies while cutting. Just did a tune up, fresh gas, new fuel fiter, spark plugs, air filter. HELP !
Take off carb and clean it assuring ports and orifices are not plugged, its starving for gas ! Main jet. Water bubbles in gas? in bowl? Drain.
Apr 10, 2013 | Craftsman 26 hp 54 in. Deck Deluxe Yard...
When engaging the blades tractor turns off. Belt
sounds like you have a safety switch problem,, check the one to the under seat make sure it is pressed in,, if it is broke cut and splice wires together,, ( but when you do this the cut off wont work when you get up off tractor,if you want the switch to work get a new one) hope this help you,, good luck
Aug 14, 2009 | Garden
Mower is 7 years old and never been adj. mower wants to die out at slow speed while cutting at idle it sounds like its missing.
Sounds like it needs a tune up. Do you have the service guide for it? Try changing the oil and the plug/plugs and clean the carb. that will undoubtedly make it run better.
Aug 10, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Craftsman Lawn Tractor/ hard start/ whitish smoke
does it turn over slow or fast if it turns slowly thats the problem so it could be battery or starter they have to have a good amount of rpms to burn fuel right when starting if not it floods out the engine with gas hope this helps thanks wade
Jul 05, 2009 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
TURNING RIGHT ENGINE WANT TO CUT OUT
sounds like the operator presence control switch needs adjusting.
Under seat.
Apr 01, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Tractor?troy bilt/mtd 2002
the electric clutch that operates the blades needs replaced
Sep 22, 2008 | Garden
JVC AM FM CD DET FACE CAR STEREO Logo
15 people viewed this question
Top JVC Car Audio & Video Experts
Radames Pagan
Radames Pagan
xxxxxx xxx
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
