Question about Philips 42TA648BX 42 in. LCD TV
Why does my Philips 42ta648bx screen goes black but the sound stays on?
3 Suggested Answers
SOURCE: Philips 30PF9946 D/37
You have sound but no picture. Green power light is on and NOT flashing. You get a screen flash or flicker on power-up or even a minute of screen before going all black. It is your inverter board. Common problem on LCDs (maybe more so on Phillips?). They are easy to replace (unplug-plug) and are available on the net.
Veritas
Posted on Dec 09, 2008
spr1949
  • 1182 Answers
SOURCE: MY philips 42 inch plasma TV model 42pf3320/10 screen goes black after a few mins sometimes. what can i do to fix it???
Try changing the input device to something you are sure, works such as a DVD player.
Switch off TV manually, switch off power, remove plug and retry after 48 hours.
If problem persists, please refer it to a qualified service technician.
Posted on Aug 02, 2012
Television stuck on black philips screen will not do anything except flash off and back on to same black philips screen.
Sounds like the media/main board is going out. You can change those out really easy with just a screw driver.
Check ebay with your part number off the board. Start with you tv model number and the the BOARD part number. Alot of board look alike but there aren't.
Also..
shopjimmy.com is a good place.
Good Luck.
Sep 11, 2015 | Philips Televison & Video
Blinking color on screen no picture
Sounds like a panel fault. Contact the authorized service center for Philips to confirm.
Gopakumar Gopalan Google
Apr 17, 2014 | Philips 42TA648BX 42 in. LCD TV
I have a Philips 42'' it works fine. But lately i been having trouble turning it on. When i try turning it on it does not shows the Philips sign its like purple then it turns off or its black complete
Main board fault. Contact the authorized service centre for Philips. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience.
http://electronicshelponline.blogspot.com/ Pull up older posts there.
Mar 28, 2014 | Philips 42TA648BX 42 in. LCD TV
I bought a 42TA648BX philips and now I want to use it out of the country with PAL system - how can I do so?
You can't.You can't used NTSC tv frequencies on PAL system.U should of bought a tv call regions free tv than u can used is on NTSC or PAL frequencies systems.
Sep 16, 2011 | Philips 42TA648BX 42 in. LCD TV
Where can i get a tv stand for a Phillips 42ta648bx?
The original stand is part number 313912879601 ; this part doesn't seem to be available. Partstore.com has a substitute stand available: http://www.partstore.com/Part/Royal+Philips+Electronics/Philips/42TA648BX/Royal+Philips+Electronics/Philips/313912879272/New.aspx . (They list it as limited quantities.)
I hope this helps.
Sep 04, 2011 | Philips Televison & Video
I have a Philpis 42" LCD TV Model # 42TA648BX/F7. Basically, I know the Power supply board is bad (it was not functional when I aquired)). Obviously someone previously had it diagnosed and got sticker...
Appears that the only other major component is the Servkit assembly
http://www.partstore.com/Model/Royal+Philips+Electronics/Philips/42TA648BXF7.aspx?SearchTerm=True
Sep 28, 2010 | Philips 42TA648BX 42 in. LCD TV
Every so often, the screen on my philips 42TA648BX/37 tv jumps.
I have the same tv 42TA648BX-37 and it does adjust because not all channels and comercials are widescreen so it adjusts so the picture doesnt look "fat" if you know what I mean. I also recommend checking your software version to se if you need an update.
May 28, 2008 | Philips Televison & Video
Philips 42TA648BX 42 in. LCD TV Logo
59 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
