Question about Ames 225ft. ReelEasy Hose Reel Cart 2386275
Rankam Purchased a hose reel cart Model #GN2136701-MM and have two tires that are flat. Tried to repair but the tubes have slits in the seams. Can you replace them. Ernest N Casey 2307 Steeplechase DR Louisville, KY E-Mail(ernest.casey@aol.com)
    Scholar:
  • 186 Answers
You can get 10" never flat tires with 5/8" hubs that will work. Home Depot has 4 for $59 online.
Posted on Oct 10, 2015
Leaking brass fitting on hose reel cart model MI4030-013755. can it be repaired
yes
pull it apart and replace the worn rubber "O" ring
Mar 18, 2017 | Garden
Hot water pipe connectors
You can buy and apply a rubber clamp repair kit. There is a flat piece of 2mm thick rubber which you place over the slit and then clamp on tightly with a worm drive hose clip. It is only intended to be an emergency temporary repair but works well.
Dec 30, 2014 | Water Water Heaters
How to change rear tire ?
Remove rear wheel with either a 15 mm or a 17 mm wrench. Take the tire off the wheel. If you are replacing a tire, reverse procedure. If you have a flat, replace inner tube, then reverse procedure
Aug 14, 2014 | Huffy Cranbrook 26" Mens Cruiser Bike
Callaway crosstrax push cart front flat repair
I too searched the internet. I have Calloway Crosstrax push cart. I put too much air in front tires and it blew. Be sure to put only 28psi of pressure in that front tire. These tubes cost at least $10. I Finally figured it out how to take this darn wheel off to replace tube. After 2 hours and revisiting after having a beer it came to me. Remove the two screws on each side of the wheel. Unloosen hex screw at bottom of fork. You don't have to remove the hex screw and not sure if it has to be unloosened. The key is to get pair of grip plyers and pull those black end caps out. A little on each side at a time. The tire assembly comes right out. Don't forget to release brake from closed position. Hope this helps.
May 06, 2014 | Optics
I have had five flats in rapid sequence. None are punctures. The first three were slow leaks but no one could find the leak. Even placed the hyperinflated tube in soapy water. Nothing. Next morning it was...
Hi. It could be you're puting in too much air. Check pressures. 2) check valve that it is tight in and sealing properly. Note: When you travel on hot pavement the pressure will rise so put the proper air in. It maybe written on tire sidewall. Max PSI ..... Good luck.
Jun 14, 2011 | Sunlite Cycling
Hello there, I've purchased on eBay my Sony TC-200 Reel to Reel recorder. I've opened and cleaned it to best of my knoweldge and ability. I am able to hear sounds on both speakers when I connect my...
http://freeservicemanuals.info/en/servicemanuals/viewmanual/Sony/TC200 Go here. when the page opens, click on the TC200 to download the service manual. There are 3 tubes and one transistor in each channel. Test the tubes first. They fail with age. You can still get tubes. You just have to google the tube number to find a seller.
May 15, 2017 | Quantegy 456 Reel-To-Reel Recording Tape
Flat rear tire
A bike shop may be able to help you. Maybe you could just repair the tube with a tube repair kit, available anywhere bicycle accessories are sold.
May 04, 2010 | Schwinn 12" Roadster Tricycle
One of my tire is usually flat and since I bought stroller I can't pump just this one tire because I like this stroller tell me how I can sole this problem? It's like impposible for pump it.
You need to either have a new inner tube put in it or you can try adding a flat repair gel in the tube to fix the leak. You can get what they call "Green Slime" their are other brands also available under different names but this is most common. It can be purchased at Walmart, Home Depot, Ace Hardware and Auto Parts Stores. This is easy to pump into the tube valve stem without removing the tube or wheel and should fix any holes or leaks on it. Then just pump it up and you should be ready to go.
Nov 02, 2009 | Quinny Buzz Jogger
One of my Quinny Buzz Tires are flat. It is
Hopes this was helpful, DutchTexan
Oct 15, 2009 | Quinny Buzz Jogger
Baby Tend Jogger model 9118A needs new wheels
Go to any Auto Parts store or Wal MArt Auto center etc. and buy a can of "Flat Fixer" and fill the tires with it. Problem solved :-)
Jul 27, 2008 | Baby Trend Expedition LE Jogger
Ames 225ft. ReelEasy Hose Reel Cart 2386275 Logo
834 people viewed this question
Top Ames Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you an Ames Garden Expert? Answer questions, earn points and help others
