Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Stanley 1/2 hp model 3220.50 seiral number 90456 wont pr making noise
Manuals knowledge center
Bostitch nailers are usually stamped with model number on the lower body just above the nose piece on the left side (holding gun with right hand). Sometimes this stamping is covered with paint or the number was so lightly stamped that it is hard to see. Good luck
Dec 20, 2013 | Stanley Bostitch N80s Nailer -rebuild...
Model 28441. How do I program?
I have instructions for model 28442 which I think I found by searching on line. You might try customer service phone number: 1-800-730-3707. Stanley (Timeit) distributor website is www.thencc.com.
Jan 31, 2012 | Stanley Hardware & Accessories
How do i check the warranty expiration date
write down the seiral number and make and model and look up the makers phone number
Sep 18, 2011 | Heating & Cooling
Nail driver slide wont retract
You have worn o-rings. You can go to www.bostitch.com and find a breakdown of your nailer. On the left side of the page go to 'Schematics and Parts', find your model number and a parts list will come up. Unfortunately Bostitch doesn't make many repair kits for their guns, you have to order all of the o-rings individually. Replace all of them, if one or two are worn the rest are not far behind. You can order them from Stanley Bostitch or get the part numbers and find another vendor.
Sep 02, 2010 | Stanley Bostitch N88rh Framing Nailer...
Where do i find parts for my stanley mower?
Stanley Mowers were made by Murray. Most Lawn mower repair / parts stores have replacement parts for these mowers.
Even if you do not have a model number you can probably use this link (left side of page) to find your part.
http://www.outdoordistributors.com/Murray/Murray_Pushmower/Murray_Pushmower.html
If it is just an engine part that you need mose of these had Briggs and Stratton engines onthem and the engine model number and type code are on the air shroud just above the spark plug for engines 4 HP or less.
Jun 13, 2010 | Garden
My dryer is squeaky. it's a GE model number DVL223EYOWW. how do I fix a squeaky dryer?
It depends on what is making the squeaking noise. Could be drum bearing, drum slides, tensioner pulley, pr even the leveling legs sometimes squeak.
Jan 10, 2010 | GE Dryers
I was wondering where to find the seiral number of my watch or how to identify what model number it is
The model sometimes is on the case back or inside the case back and the serial number inside on the movement. Therefore you would have to remove the case back. Be careful if you do this so you do not damage the case. Maybe better to have a shop do this for you.
Nov 20, 2009 | Bulova Millennia With Vibra-Alarm 98A48...
Programming my 98 blazers Garage door button on dash to a stanley
Here is some programming info for the Stanley.
http://www.aaaremotes.com/standualcodl.html
The programming information for your Blazer should be in the owners manual.
Aug 18, 2009 | Sears Craftsman LiftMaster Chamberlain...
How do the staples stay in place in my stanley 1/4" stapler? They slide back and forth and therefore aren't in place for the stapler to work?
There should be a pusher that is attached to a spring. If the spring broke, or the pusher is missing the staples will not stay in place.
If you can locate a model number on the tool, you go to bostitch.com to find the parts you may need
Apr 18, 2009 | Stanley Tools Staple/Brad Nail Gun
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
46 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
