Question about Motorola Cell Phones
My motorola droid IHDP56KC1 front screen will not work and is calling people on its own, is this a malware issue or hardware?
The apps were all running, so I deleted the apps, when I powered the phone down and then restarted the phone the apps were still on the phone, now the front screen is possessed and acts like someone else is controlling it, calling people on its own and opening things on its own. Could this be a malware issue or is it hardware related
  • 641 Answers
I suggest to reset your device to its factory defaults, for you to check what is really happening.
How-To: Hard Reset your Motorola Droid To perform a hard reset on your Motorola Droid, perform the following steps.
  1. Turn off the Droid. If you are unable to turn off the Droid, remove the battery for 10 seconds, then replace it.
  2. Open the physical keyboard and press the X key while pressing and holding the Power Button. The device will turn on, keep holding these two buttons until a yellow triangle appears.
  3. Press the Volume Up and then the Camera button at the same time to get a menu to come up. You may have to press them more then once.
  4. You have now entered Recovery Mode.
  5. Use the Directional Pad on the Physical Keyboard to select theFormat option.
This should perform a factory reset of your device. You will of course lose all data. Please exercise caution before doing this without a backup.
* Note: Contacts, etc. should be backed up to the cloud, so you should be safe with your address book.
Posted on May 13, 2014
  • 5 Answers
SOURCE: Possesed Phone
you can fix it you self by downloading the update software to fix the glitch. you cam go to motorola.com and get it there
Posted on Oct 18, 2007
  • 378 Answers
SOURCE: blackberry doesn't show incoming calls on front screen
reset ur phone to company settings. Some prog malfunction and cause this problem.
Posted on Aug 19, 2009
  • 8404 Answers
SOURCE: my droid is running very slow
Hi there ... Have you inquired of Verizon as to a solution to this trouble? 1-800-2JOININ 24/7. They are the experts. My wife's Droid runs lile a Deere is chasing it.
Thanks for using FixYa.com
Posted on Jan 06, 2010
  • 3 Answers
SOURCE: iPhone camera shutter won't open! - 3Gs
I have had the same problem. I backed up all photos/videos from the phone and then deleted them, then rebooted the phone (off/on). The camera functioned after that. Then I restored the photos to the phone.
Posted on Jun 14, 2010
  • 22 Answers
SOURCE: My droid screen suddenly turned
You might want to try a hard reset on the phone, it should put your phone back to normal if its a software issue, if its a hardware issue you might have to take the phone apart or send it in for repairs or warranty return.
You can hard reset your Motorola Droid if you want clear all of the data off of the device and start fresh. Here’s how it’s done.
1. Turn the Droid off. If it won’t turn off, take the battery out then place it back in.
2. Open the keyboard and press the X key while pressing and holding Power. The device will power on. Keep holding the buttons down until a yellow triangle appers.
3. Press the Camera and Volume Up buttons at the same time to get to the menu. (I had to press them several times).
4. Use the direction pad to the right of the keyboard to select the Format option.
Posted on Aug 16, 2010
Tip
How to get 7 screens on Motorola Droid.
You'll want to get the application called "Helix Launcher" from the Apps Market. Once you have that, go into the menu button ( noted by four horizontal slashes) on your Droid (sitting between the back button and the home button) and go into 'configure". You'll then see a list of options for the Helix. You want to do the first one at the top. Keep in mind you can have 1-7 windows but if you have your Droid set up with the apps of your choice, they will be taken off the home screen if you increase or decrease the amount of windows you have.
Set to the quantity you want and there you go.
on May 14, 2010 | Motorola Mobility Droid (2 GB) Cell Phone
Apps have stopped working sys market feedback has stopped how do i fix problem
Is Google Play store the app that isn't working?
Go to Settings > Apps > All and locate the app you are having an issue with and then clear the app data. Reboot and try again.
Mark
Motorola Support
Mar 11, 2015 | Motorola DROID Turbo
My droid phone says face activity not working and wants to know if I want to wait or close it. What can be done to correct this?
It sounds like you may have third party apps affecting your device. It may be helpful to run is safe mode to temporarily disable those apps to see if symptoms disappear. Verizon Mobile Support
Mark
Motorola Support
Sep 16, 2014 | Motorola Mobility Droid Razor Xt912 Black...
How do i block calls on my droid razr?
Hi Anonymous,
To block calls you can download a App from the Google Play Store that enables the feature on your device or contact your carrier to add restriction on your service for outgoing/incoming calls.
Regards,
Gaby
Motorola Support
Jun 11, 2014 | Motorola Mobility DROID RAZR MAXX HD
Could be just moisture on the screen or a non Motorola Charger being plugged in. It could be a damaged screen or malware as well but is more likely one of the first two items.
Mark Motorola Support
May 13, 2014 | Motorola Mobility Droid (2 GB) Cell Phone
Hello.. used to be able to w/o any issue but now cannot instant upload pics to facebook... any ideas why not??
This is a problem many Motorola Droid users have been experiencing lately. Try uninstalling and reinstalling the facebook app on your Droid this has been known to fix the problem.
Mar 07, 2011 | Motorola Mobility Droid (2 GB) Cell Phone
My droid screen suddenly turned black but i could still use it, i tried resetting it by pulling the battery out but the same thing occurs. Whenever i would turn the droid back on, the Motorola symbol is no...
Aug 16, 2010 | Motorola Mobility Droid (2 GB) Cell Phone
How do I make the font larger on Motorola droid... the one app I tried, Spare Parts, as soon as I go a different screen it goes back to small fonts that I can't read.... help please.
try the user manual
copy this link
http://www.motorola.com/staticfiles/Support/US-EN/Mobile%20Phones/DROID-by-Motorola/US-EN/Documents/Static-Files/DROID_UG_Verizon_68000202474a.pdf
i not seeing it at all though.
Mar 01, 2010 | Motorola Mobility Droid (2 GB) Cell Phone
My droid gors to start up screen every 3 minutes
Try to do a firmware restore to make sure your system is 100% intact.Ifit still doesn't work, there may be an issue with your logic board.Ifyou're not covered under warranty there are Droid Repair guides that show how to open a droid.Watchout for the ribbon cables,those tear easily. Replacement parts areusually available on Ebay.There are third party services that can do itfor you Droid Repair.
Jan 01, 2010 | Motorola Mobility Droid (2 GB) Cell Phone
Cell Phones Logo
Top Motorola Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a Motorola Cell Phone Expert? Answer questions, earn points and help others
