Is sound a back and forth movement yes or no - Computers & Internet
Clunking noise when steering wheel is moved back and forth.
Sounds like you have ball joint or steering linkage problems..have some one set on the seat and make hard turns right and left while you watch for excessive movement " linkage or ball joint slap " before the wheels actually turn..or jack the front end up one side at a time and with the steering wheel strapped in place"bungee chord " move each wheel up and down and left to right..find the excess movement and go from there..good luck
Oct 22, 2014 | kawasaki 2008 Mule 610 4x4
Paper feed fault
Check the printer lens and make sure the paper is probely inserted. Hope this helps...
Jan 28, 2008 | Canon BJC 3000 InkJet Printer
Hub bearing
With the affected wheel in the air, one hand on the top of the tire, and one at the bottom, try to move the wheel back and forth towards you and away from you. If it's loose (more than an 1/8" of movement), yes you need a new wheel bearing hub assembly.
Mar 04, 2014 | 1999 GMC Jimmy
There is a wom wom sound and vibration coming from my 03 Trailblazer. I believe it's the wheel bearings. Are they easy to change myself?
yes, it is possible that the spindle bearings are bad. this is a sealed unit!!! have to buy whole spindle. easy to install by experienced mech.
just jack up each side and grab tire top and bottom and try to move back and forth!! any movement is bad!!! just look good and make sure the movement is coming from the spindle area and not the ball joints!!! hope nthis helps!!!
Nov 29, 2013 | Cars & Trucks
Squeaking serpentine belt
Sounds like a bad water pump. Loosen that belt and see if it has any back and forth movement.
Feb 18, 2013 | Cars & Trucks
1998 Acura CL 3.0,speedometer cable not indicating correctly
cable sounds to be broken by description given
Jun 02, 2012 | 1998 Acura CL
My truck sounds like its roaning when i drive
CHECK AND SEE IF THE FAN CLUTCH IS BAD SHUT OFF ENGINE AND OPEN HOOD GRAB THE FAN BLADE AND SEE IF IT TURN FREE OR HARD ALSO CHECK AND SEE IF IT HAS MOVEMENT BACK AND FORTH
Oct 16, 2010 | 2001 Dodge Ram 1500 Truck 2WD
Watch is new out of the box. Movement will not start. ???
mcdevito75 here, If your Wittnauer is a Quartz movement, look for a small piece of plastic, just under the crown (winder) remove this piece of plastic carefully and push the crown back down to start your watch, if it's an automatic movement, try to wind with the stem if you feel a resistance then winding will initially start yor watch by winding with 20--30 winds, if you feel no resistance when winding the simply rock your watch back and forth in your hand, you will detect something moveing inside the watch, this is the counter balance winding the watch, rock the watch back and forth for approx. 30 seconds to start an initial wind.
Jul 10, 2010 | Wittnauer Belasco 36 Diamond 27 Mm Watch...
ROBOT GOES BACK AND FORTH 2 FEET ONLY
There are several things to check for with these pool cleaners. First, make sure that there are not kinks or knots in the cable that would restrict movement. Make sure that there is not hair, fabric, or other debris in the impeller. This can also cause the back and forth movement. Check for debris or leaves caught in the axle bearings.
Aug 02, 2009 | Smartpool Dolphin Robo - Kleen Above...
Volume control for model TXD1972
This may sound stupid but try this turn the volume knob to high and low continously for a few seconds sometimes the contacts become dirty and just a little movement back and forth quickly repairs it. I said SOMETIMES.
Sep 04, 2008 | Samsung TXD1972 19" TV
Computers & Internet Logo
13 people viewed this question
David Payne
David Payne
