Question about Xerox Phaser 7760/YDX Laser Printer
Accumulator belt for Xerox Phaser 7760: can I refurbish this unit myself? If so where can I buy the parts to refurb the belt?
My email: ajames1992@aol.com Thanks,
  • iteminconline Sep 12, 2014
    064K91451 titeminconline they sell the belt only and also the home position sensor encase you have an error.
    sorry that was 064K91451 iteminconline
    Guru:
  • 110 Answers
064K91451 iteminconline they sell the belt only and also the home position sensor encase you have an error.
Posted on Sep 12, 2014
  • 18 Answers
SOURCE: Xerox phaser 7760 streaking
to fined out what the problem could be you need to open a word doc and sent a blank page to the printer. from this it will show where the problem is in the printer
if u still get streaking it couls be a faulty toner and it may not be the cyan toner either. i would give the fuser unit in the printer a check. if there marks on tthis unit i can cause this problem as well
Posted on Nov 23, 2007
  • 2072 Answers
SOURCE: Xerox Phaser 7760 Prints White Lines Diagonally Across Page
That is normally caused by a bad developer housing.
Posted on Jul 16, 2009
nakshatraipu
  • 241 Answers
SOURCE: Xerox Phaser 3100 Reset solutions, no need to
we have module to reset xerox 3100 permanently
www.nakshatraworld.com
Posted on Nov 26, 2009
SOURCE: i have blocked the fuser uit
All you have to do is open the fuser unit on the end (2 Screws) and you will find a fuse which has 3 strips (in a plastic casing with wires attached). You must the solder the strips so that they are joined, and that should reset the fuser.
Posted on Jan 13, 2010
  • 2072 Answers
SOURCE: how do i replace an accumulator belt on a Phaser
  1. Open the Front Cover.
  2. Release and move the IBT Cam Lever down.
  3. Open the Right Side Door.
  4. Removing the IBT Belt Assembly
  5. Lift the Accumulator Belt Locking Level and pull the Assembly out to remove.
  6. Use Handle to transport IBT Unit. Protect the IBT Belt Assembly from
  7. On the front, there will be 2 torx screws on a plastic strip. Remove those and the cleaning assembly.
  8. There are 2 spring loaded clips. One on front and one on back that release the spring tension on the roller. You have to press them in and press the locking tabs.
  9. Then go around the frame and remove the screws in order to "fold" the assembly and remove the belt.
  10. Be very careful not to bend the bracket near the bearings or you will have belt tracking faults after replacement.
  11. Be sure you install the belt in the correct direction. There is a silver patch on the belt that must be on the inside of the belt assembly when installing. Look at the old one before removing to determine the orientation of the belt.
Posted on Jan 14, 2010
The accumulator belt on my 7760 phaser is giving a past end of life message. How can I find out how many copies it has remaining?
Try printing the full status sheet. If you print out all the setting it should cover all the information you need to make your judgement.
Good luck.
Mar 26, 2015 | Xerox Phaser 7760 Laser Printer
Print Directly to 7760DN from iPad 3 iOS 5.1 ?
Hey I have a xerox wc7328 connected to my andriod. There is a app that is called "printback" from xerox. Follow the instructions in the website where you download the app and its easy. Good luck don't forget to visit us at iteminconline we have all your xerox parts that you need. New and refurb.
Mar 10, 2014 | Xerox Phaser 7760/YDX Laser Printer
OUR PHASER 6180 PRINTER IS SHOWING FUSER LIFE AND TRANSFER LIFE NEEDS REPACING SOON. WHAT ARE THEY AND WILL IT COST MORE TO REPLACE THAN BUY A NEW ONE
Go to this WEB site for fuser parts.
http://www.sparepartswarehouse.com/Xerox,Phaser,6180,6180N,Printer,Fusers.aspx
Go to this WEB site for transfer belt part.
http://www.fastprinters.com/ProductDetails.asp?PARTNO=XER-675K47088
May 16, 2011 | Xerox Phaser 6180N Laser Printer
Xerox phaser 7760 saying "non-phaser imaging unit"
There is a snippet on the Xerox website to solve imaging unit recognition problems, link below. http://www.support.xerox.com/support/phaser-7760/downloads/engb.html?operatingSystem=winxp&fileLanguage=en_GB Usually this problem only occurs if the NVRAM has been reset or the engine board has been replaced without backing up the NVRAM. You can download the snippet to your printer through Centreware or by downloading the 'File Downloader' utility from the same page above.
Hope this helps.
Jan 09, 2011 | Xerox Phaser 7760DN Laser Printer
Phaser 7760 Error message: "Imaging
The black image unit of your machine should be replaced soon. It is a maintenance item and is very easy to change. They cost about $350 new, but you can buy one much cheaper rebuilt. Here is a video I made to help explain what it is you need to change and how to do it. Good luck
Nov 16, 2010 | Xerox Phaser 7760/YDX Laser Printer
How do i replace an accumulator belt on a Phaser 7760
Jan 13, 2010 | Xerox Phaser 7760 Laser Printer
Hello i hope someone can help me with my problem i need reset the fuser uit xerox phaser 7760,because the rollers both(up,low) are like new condition thank you
You can get more life out of the fuser by removing one end and placing a piece of tin foil OVER the THREE FUSES, which are designed to blow at set times. Just tape it in place with some tape.
Good Luck
Oct 03, 2009 | Xerox Phaser 7760/YDX Laser Printer
Phaser 7700 Accumulator Belt Replaced, upon startup there is an error
POSSIBILITIES
Problem:
1st BTR Contact Failure or 1st BTR Retract Failure Message is displayed after replacing the Accumulator Belt Cause:
A Phaser 7700 Accumulator Belt was installed in a Phaser 7750. The Phaser 7700 Accumulator Belt does not have retractable 1st Bias Transfer Rollers; so these errors will be reported if one is installed in a Phaser 7750 printer. Solution: thumbsup.gif Fixed! thumbsdn.gif Did not fix. Remove the Phaser 7700 Accumulator Belt and install a Phaser 7750 Accumulator Belt. TRY FIRST (Solutions without parts):
1. Check that all shipping restraits have been removed.
TROUBLESHOOTING TIPS AND HINTS:
1. Test the 1st BTR motor in diagnostics to verify proper operation. 2. Test the 1st BTR sensor in diagnostics, then run the 1st BTR motor test and recheck the 1st BTR sensor. Sensor state should alternate between L and H. The sensor is part of the accumulator belt.
PARTS:Parts are listed in the order of highest probability for repair.
NUMBER QTY DESCRIPTION
116177400 1 *KIT IBT - UNIT
REPAIR/INSPECT/PREVENT PROCEDURE:
1. Clean feed rollers, exit rollers and guides; replace if
necessary.
2. Clean feed rollers and exit rollers only when dust or
debris is visible.
3. Remove and clean all paper trays.
4. Clean the Laser Scanner Unit window.
5. Inspect the image density sensors; clean if necessary.
6. Inspect the accumulator belt home sensor; clean if
necessary.
7. Inspect the fuser assembly; clean if necessary.
8. Print the Error Log, diagnose and repair any problems as
indicated.
9. Print the Usage Profile, diagnose and repair any
problems as indicated.
10. Check version of all installed firmware; as
appropriate, install the latest version of firmware.
11. Check cleanliness of interior and exterior of printer,
including fans; if necessary, clean (dust or vacuum) these
areas.
Problem:
Jan 25, 2008 | Tektronix Phaser 860DP Thermal Printer
Xerox Phaser 7760/YDX Laser Printer Logo
272 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
