Question about OKI C5100n Laser Printer
Oki c5500 replace image drum - OKI C5100n Laser Printer
SOURCE: reset drums for c5500
I have the same problems many of you have with the Toner and drum error on my C5500N. I have not had much luck with Okidata support. I have had success replacing the chips in the toner cartridges. The replacement chips can be obtained from www.printerdoctor.com. They sell toner refill kits for the printer as well as chips for the toner cartridge and replacement fuses and rebuild kits for the drums.
Posted on Nov 22, 2008
copiersplusw
  • 136 Answers
SOURCE: fatal error 928 Oki C5500
Open the Unit Up, the Button on the Side opens the Printer. In the rear of the Printer you will notice the Element in the rear of the Printer.
It is usually hot. Well there is latches
as an Authorized Okidata Service Provider I believe these "TABS" should be the color of BLUE. release the tabs and the entire fuser come out just grab the handle that usually comes equipped with the fuser , it is usuallyon top just grap ir and lift it out. Install the New One and your Done.
Posted on Sep 13, 2009
  • 73 Answers
SOURCE: How do you rest an OKI c3530 image drum
Turn off the printer
Turn the printer on whilst holding down Menu button. (Display says user maintenance.)
Press the menu button three times. (The display will say drum counter reset.)
Press enter key. The system should go back on line, if not press on-line key.
You can just put a new fuse on the drum.
When you insert the drum the machine resets the counter and then blows the fuse. So if the unit is ok and you just wish to run it through another cycle just change the fuse.
This means you cannot just put a full unit in from another machine as it will not reset the counter until you put a new fuse in it as you found out.
This applies to drums transfer belt etc.
Note with regard to refilling the toner, some printers have 2 sections. 1 where you put the fresh toner and an after collection section in the same unit. You must empty the 2nd section if you refill it more than 2 or 3 times
Posted on Oct 07, 2009
Testimonial: "Great fast response."
SOURCE: resetting image drum after replacing for oki b4600
On the printer press the menu button until you reach MAINT.Then press the item + button until you reach DRUM CT RESET. Then press select.YOUR DONE
Posted on Oct 30, 2009
SOURCE: fatal error 980 OKI C5500 printer
I had a paper jam and removed the jammed papers. The paper jam cleared and then the Fatal Error 980 appeared. OKI C5500 printer
Posted on Feb 25, 2010
I HAVE C5500 OKI PRINTER AND THE ERROR SAYS REPLACE IMAGE DRUM 561:M DRUM LIFE I PUT IN NEW MAGELN AND STILL HAS THAT MESSAGE
oki printer c5950 fix new cartridge & drum coming error replace image drum 561:m drum life
Jan 15, 2013 | OKI C5500n Printer
Oki C5500 dont have TC/IP menu, do you help me.
Symptom:
Unable to reach Printer from local network or Printer falling off network and needs to be rebooted before being able to print
Cause:
ecblank.gif ecblank.gif ecblank.gif Resolution:
Install OkiLAN8300e Firmware 4.06 (C5500/C5800) or 4.55 (C6100) update using Oki LPR Utility
Are you on a Mac?
Mar 10, 2010 | OKI C5500n Laser Printer
Getting error 142 fatal error
unplug the unit then clean the printer and all drum units and etc with compressed air. Replace the drums and replug should solve the problem.
Dec 10, 2009 | OKI C5500n Printer
OKI C5500 PRINT IS UNCLEAR ON METALLIC PAPER\
try cleaning the LED heads. These are located in the lid of the printer, they are facing you when you lift the lid up. They form the latent image on the drums and any dirt on them will give the symptoms you describe.
Aug 22, 2009 | OKI C5400tn Laser Printer
I need to replace the belt on an OKI C5500 printer
pull out the drums, there are two tabs (blue or green) on the left of the belt and a handle on the right. belt should pop out (some models have a plastic piece that the drums sit in, which comes out freely) insert belt on left end notches first then everything else in reverse. should do it for you
Aug 04, 2009 | OKI C5500n Printer
Black Laser Drum
I just end of ordering it and it should be here first thing this morning. Thank you.
Mar 19, 2009 | OKI C5500n Printer
Fatal error 980 OKI C5500 printer
Mar 15, 2009 | OKI C5100n Laser Printer
Reset drums for c5500
Oct 06, 2008 | OKI C5500n Printer
OKI C5100n Laser Printer Logo
Top OKI Office Equipment & Supplies Experts
WTF Chuck.....
WTF Chuck.....
Jimbras
Level 1 Expert
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
