Question about Vehicle Parts & Accessories
Where are timing marks on 1998 nissan path finder timing belt
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 189 Answers
Marks are never on the belt they are always on the pulleys
Posted on Sep 06, 2014
Hi i have a 1991 Nissan path finder i went out mudding and it just turned off it sparks and wen i try to turn it on the rmps are working but the car is off help plzz!..
Greetings
I, feel sorry for you, after reading your problem, but don't worry you visit the Reliable-Store they will help you for sure.
Nissan
Mar 15, 2016 | Nissan Cars & Trucks
Where are the timing marks for a 1998 Nissan sentra gxe
most vehicles have a crank timing mark which sit on the crank pulley,its the big pulley at the bottom of the motor
the cam pulley should also have a mark on the pulley if its belt driven that should line up with a notch on the head or tappet cover
if its chain driven you will need to remove the tappet cover and your cam sprockets will have marks on them that must line up facing each other or facing level with the sides of the head
Mar 25, 2015 | 1998 Nissan Sentra
1998 nissan pathfinder 3.3 timing marks for camshafts and crankshaft
It is normal to have to set the timing marks a couple of times before you can say they are right. If at first they don't pass the 2 turn roll around, then redo it. By the third time, you will have it right, and when you close it up, you will know its right. The car will start and you will be good for it. Patience. close isn't good enough.
Jan 21, 2013 | Nissan Cars & Trucks
FIRING ORDER 94 6 CYLINDER PATH FINDER
hi try this site its awsome for what you need here is the link hope this helps
http://autorepair.about.com/library/firing_orders/bl-fo-7474.htm
May 10, 2010 | 1994 Nissan Pathfinder
Timming marks on pathfinder 1998
Click on the following free direct Link. It has the Timing: Belt and Mark Diagrams for your 1998 Nissan Pathfinder. Plus additional Instructional and Directional Diagrams.
Let me know if this helped, or if you have additional information or questions. Feel Free to contact me at FixYa.com!
http://www.2carpros.com/car_repair_information/year/1998/make/nissan/model/pathfinder/1998_nissan_pathfinder_timing_belt_diagram_marks.htm
Mar 29, 2010 | 1998 Nissan Pathfinder
Replacing the timing belt on a 1998 Nissan Quest and need to know cam shaft and crank shaft positions.
go here for expert help on Villager & Quest
http://groups.yahoo.com/group/villagerquest/
Item Part Number Description 1 — 40 Timing Chain/Belt Teeth 2 6256 Camshaft Sprocket , Front 3 — 43 Timing Chain/Belt Teeth 4 6306 Crankshaft Sprocket 5 6268 Timing Chain/Belt 6 6256 Camshaft Sprocket , Rear
Removal
  1. Drain the cooling system. Refer to Section 03-03 for the procedure.
  1. Disconnect the battery ground cable (14301) .
  1. Remove the generator drive belt, water pump and power steering pump drive belt, and the A/C compressor drive belt (if equipped). Refer to Section 03-05 for the removal procedure.
  1. If equipped, remove the three A/C compressor drive belt idler pulley bolts and the A/C compressor drive belt idler pulley.
  1. Remove the upper radiator hose bracket bolt.
  1. Loosen the two upper radiator hose clamps and remove the radiator hose bracket bolt. Remove the upper radiator hose (8260) and the upper radiator hose bracket from the vehicle.
  1. Remove the water bypass hose (8597) from between the thermostat housing and the water hose connection (8592) .
  1. Remove the main wiring harness from the upper engine front cover (6019) .
  1. Remove the eight upper engine front cover bolts and the upper engine front cover .
  1. Raise and support the vehicle.
  1. Remove the RH front wheel and tire assembly.
  1. Remove the four RH outer engine and transmission splash shield bolts and two screws and remove the RH outer engine and transmission splash shield (6775) .
  1. Use Strap Wrench 303-D055 (D85L-6000-A) or equivalent to hold the water pump pulley (8509) while removing the four water pump pulley bolts.
  1. Remove the water pump pulley from the water pump (8501) .
  1. Remove the crankshaft pulley (6312) . Refer to the procedure in this section.
  1. Remove the five lower engine front cover bolts and the lower engine front cover .
  2. Ensure that the timing marks between the crankshaft sprocket (6306) and the oil pump housing line up.
  3. NOTE: The directional arrow is necessary to ensure that the timing chain/belt (6268) can be reinstalled in the same direction.
  4. Loosen the timing chain/belt tensioner nut.
  5. Remove the timing chain/belt .
  6. Installation
    NOTE: Ensure that the timing marks on the camshaft sprockets (6256) and the seal plate are properly aligned. Ensure that the timing marks on the crankshaft sprocket and the oil pump housing are still aligned. NOTE: A new timing chain/belt has three white timing marks that indicate the correct timing positions of the camshafts (6250) and the crankshaft (6303) . These marks will help ensure that the engine (6007) is timed properly. When the engine is properly timed each white timing mark on the timing chain/belt will be aligned with the corresponding camshaft and crankshaft timing mark on the sprocket. Because the white timing marks are not evenly spaced you will need to refer to the following illustration for proper timing chain/belt placement. There should be 40 timing belt teeth between the timing marks of the front and rear camshaft sprockets and 43 teeth between the timing mark on the front camshaft sprocket and the timing mark on the crankshaft sprocket .
    NOTE: Verify that the camshaft timing marks are aligned with the timing marks on the seal plate, and that the crankshaft sprocket timing mark is aligned with the timing mark on the oil pump (6600) .
    Install the timing chain/belt starting at the crankshaft sprocket and moving around to the camshaft sprocket following a counterclockwise path. Do not allow any slack in the timing chain/belt between the timing sprockets. After all of the timing marks are matched up with the timing chain/belt installed, slip the timing chain/belt onto the timing chain/belt tensioner .
Sep 20, 2009 | 1998 Nissan Quest
How do I change timing belt on 1998 nissan sentra gxe?
this is a long answer to type out suggest you buy a chilton or haynes manual at locale auto parts store.they give a good step by step with pictures. you will need for the timing marks
Aug 05, 2009 | 1998 Nissan Sentra
1998 Nissan Pathfinder timing belt replacment
go to autozone.com - they have online repair guides for most vehicles and I must say they are great.
Aug 11, 2008 | 1998 Nissan Pathfinder
Vehicle Parts & Accessories Logo
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
