Question about Rheem 22v50f1 Natural Gas Water Heater 50 Gallon
Water heater leaking from the top - Rheem 22v50f1 Natural Gas Water Heater 50 Gallon
  • 40 Answers
If its leaking from the top it is possible that it just needs tightening but it is probably that the tank is failing. but to check out the first possibility turn off the water and drain off the pressure if you do not have 2 valves . one on each line you will have to drain the system. then remove the leaking side. in fact remove both sides apply pipe compound or teflon tape and retighten and reconnect all unions .if that solves the problem good if not its time to replace the tank
Posted on Jan 03, 2015
2 Suggested Answers
  • 102 Answers
SOURCE: RHEEM 40 Gallon FVR NATGAS Low WATER HEATER 6YR 22V40SF: water leaking from top of water heater how can i f...
If water is leaking from a pipe. then replace or repair the pipe or fitting. If the leak is coming from the unit itself, then replace the unit. Hope this helps.
Posted on May 20, 2010
Why is rust-colored slime leaking out of top of water heater?
The water heater needs to be replaced. The rust-colored slime indicates that the water heater has a leak.
Sep 17, 2015 | Water Water Heaters
Rheem 81v40d
Copy following links to identify and troubleshoot leaking water heater:
http://waterheatertimer.org/Leaking-water-heater.html
http://waterheatertimer.org/How-to-install-gas-water-heater.html
When tank rusts out, it will get pin holes, and water will leak out of top.
Replace water heater.
http://waterheatertimer.org/How-to-maintain-water-heater.html
Add a comment
May 11, 2013 | Rheem Water Heaters
Leaking water from top
1) Copy following link for troubleshooting leaking water heater:
2) After opening link to identify problem, add a comment and give brand, type and approx age of waTer heater for more possible help.
Feb 19, 2013 | Water Heaters
Rheemglas water heater leakage from the top seal
1) You have leaking water heater.
2) I do not know what is meant by 'top seal' since that is not typical water heater part.
Does you product manual show a top seal?
Add comment and describe the top seal and add what it does.
3) Attach a photo.
Dec 31, 2012 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Water is over flowing and coming out over the top of my hot water heater, i shut the water off and turned the temp down and turned the water back on after a few hours and water still is over flowing over...
If pipes are leaking, then that can be repaired.
If tank is rusted out and water escaping from the tank, then turn off the water plus power to the heater for safety, and then replace water heater.
Rusted water heater can be welded for repair, but remember that hot water is under pressure and tank can rupture any time.
Safest course if to replace heater.
Open following link for leaking water heater checklist:
Jul 27, 2011 | Whirlpool Water Heaters
Water seems to be leaking from the top lid of my ge water heater
Make sure any water valves (Cold or Hot) for water heater are not leaking first. Gate valves may leak at the packing nut over time and drip on top of tank. If water is leaking from the top of the water heater itself the tank is corroded and water heater will need to be replaced.
RJ
Jul 16, 2011 | General Electric GE SmartWater Household...
May 17, 2010 | Rheem 40 Gallon FVR NATGAS Low WATER...
GE Profile Smart Water Heater leaking at top/no hot water
could be pressure relife valve as well- you need to tell us where water is comig from exactly in order to solve
Nov 09, 2008 | Water Heaters
Rheem 22v50f1 Natural Gas Water Heater 50 Gallon Logo
41 people viewed this question
Top Rheem Water Heaters Experts
Donni Steen
gizmonix
Level 1 Expert
Jim Goldsmith
Jim Goldsmith
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
