I have idesit wil 123 and easy iron light flashing and door lock flashing and will not spin any help out there please
  • sandra_crouc Jun 23, 2009
    thankyou i only got it sunday was washing fine the water is pumping out but when i put it on a program it fills then stops and lights start flashing the band is still on at the back but the motor is not turning
  • 57 Answers
It sounds like the brushes on the motor or the pump is blocked
Posted on Jun 23, 2009
  • Lidlicker Jun 23, 2009
    no problem happy washing
Lights flashing on indesit WIL123S
Hi, sounds like you need to change the door interlock located where the door catch pushes into.
Take the top off and undo the two screws with a tork screwdriver
and replace.
(Remember to turn off the supply and pull out the plug top)
May 09, 2009 | Indesit W 123 Front Load Washer
Indesit wil 103 door won't open...
Welcome to Fixya.
Try holding the Start/cancel button in for at least 2 seconds.
If there is another lamp flashing at the same time as the door lamp, then you will have to call an engineer.
Dec 18, 2008 | Indesit W 123 Front Load Washer
Indesit Standard WIL 123 (UK) Washing Machine
Had a similar problem ,flashing red led means door not locked, I removed door from machine removed front from door and found hinge pin for lock had come adrift, religned pin and chapped back into position .THen replaced door and door to machine .dor shut and lock worked perfectly, hope this helps
Jan 04, 2008 | Indesit W 123 Front Load Washer
WIDl126 - door lock and easy iron flash
worth trying this! make sure the drain hose is only down the waste pipe about 6 inchs, and up off ground level about 24 inchs ie. 2 feet.If that don't not work it could be faulty pcb board!let me know.bye,close,ire.
Dec 23, 2007 | Indesit W 123 Front Load Washer
Indesit WIL143S flashing lights
sounds like your power board is damaged. Did you get any washes out of it before it went wrong
Oct 08, 2007 | Washing Machines
Indesit WIL103 flashing lights problem
because of the short time this runs then stops, there could be maybe 3 faults, 1 check water inlet valves and supply for water flow 2 check for any motor action (use another programme) 3 check heater element for open circuit number 1 or number 3 sounds most likely hope i have helped, if so rate me please
Sep 25, 2007 | Indesit W 123 Front Load Washer
Washing Machines Logo
168 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
