Question about Just Wireless Bluetooth Headset - BT-38
I do'nt remember my pin number to pair my BT-38k1 to my phone
The phone that I am useing is a blackberry
  • 4 Answers
Try 0000
Posted on Jun 25, 2014
2 Suggested Answers
SOURCE: My BT-10K pairs and operates in phone mode with a
CANT CONNECT TO PS3
Posted on Aug 06, 2010
How you play music on jabara bt 2050 0n phone
first you have to pair your blue tooth device to your phone,first you turn the bt power to on on your phone menu,next you have to put your blue tooth device headphones into discovery mode,now most bt manufactures use the power button for this feature,by holding the power button down for 6 to 10 seconds when you turn the bt device on it usually puts the bt intodiscovery mode.a solid light usually remains on on your blue tooth device,then you can search or add new device from your phone menu.once they have paired or recognized you will need a pin pairing code.Most manufactures of blue tooth devices use a factory 4 digit pin pairing code ,they are as follows0000,1234,9999,or1111 i hope this helps
Feb 25, 2011 | Samsung Radio Communications
Can't remember how to pair my LG HBM-710 to my new phone - Samsung Fascinate. Can you help?
to pair a blue tooth device to a phone first you must turn the bt power on the phone to on,then you have to put your blue tooth device into discovery mode,now most manufactures use the power button for thisw feature.By holding down the power button on your device when turning it on for 6 to 10 seconds it usually puts the device into discovery mode.there should be a light that stays on on your blue tooth device.once you have the bt device into discovery mode you will be able to pair the device to your phone by search or add new device,once it pairs it will ask for a pin or pairing code.most manufactures of blue tooth devices use a 4 digit factory pin pairing code they aare as follows 0000,1234,9999,or 1111 once youve put tjhe pin code on they will pair ,i hope this helps
Feb 25, 2011 | LG HBM-710 Wireless Headset
I cant get my blue tooth to connect to my blackberry
MAKE SURE THE BLUE TOOTH HANDS FREE OR ANY OTHER DEVICE IS IN PAIRING MODE. ( THE PIN TO PAIR A BT HANDSFREE LL BE 0000 )
ALSO FOR INCOMING BT BEEP RECEVING
FROM MEDIA. CLICK MENU AND SELECT. RECEIVE VIA BLUE TOOTH.
Feb 24, 2010 | Cell Phones
Im unable to pair my H700 to my BlackBerry 8300
1.)Turn on your BT on the 8300,
2.)Press and hold the button on your H700, flip open the boom when the light turns blue.
3.)On Blackberry go to BT setup and select search, it should find it.
4.) when it askes for the PIN enter "0000" and OK
it should then be connected.
Jan 08, 2010 | RIM BlackBerry 8300 Smartphone
When trying to connect my mobile via bluetooth to my car phone it says sim rejected why ?
We suggest you to reinsert the sim once again and check for the same. And try to perform the following steps: Apply the Bluetooth Pairing Helper application to your BlackBerry smartphone. Download the Bluetooth Pairing Helper application file using your BlackBerry smartphone browser Note: The Bluetooth Pairing Helper is available for BlackBerry smartphones running BlackBerry Device Software 4.2 and later. Complete the following steps for the Bluetooth Pairing Helper software. The following steps use the Land Rover as an example. Place the vehicle into pairing mode. For instructions, see the vehicle user manual. Start the Bluetooth Pairing Helper application. See links above. The following message appears on the BlackBerry smartphone: Please initiate the pairing process on your car. Click ?Done? when pairing is complete On the vehicle, press the Dial button. The following message appears on the Land Rover, and the progress bar on the Bluetooth Pairing Helper Application begins to advance: Searching The Land Rover display lists the name of the BlackBerry smartphone (and any other Bluetooth devices found within range). This may take one or two minutes. On the vehicle display, use the dial to highlight and then select the BlackBerry smartphone. The vehicle displays a random personal identification number (PIN) to pair. When the BlackBerry smartphone prompts for a PIN, type the PIN shown on the vehicle display in step 8 and press Enter. The BlackBerry smartphone displays Pairing complete. Connect to and press Yes. Pairing completes and an Connection to vehicle succeeded should appear on the BlackBerry smartphone. If the Bluetooth Pairing Helper application does not close, click Done to close the application. If you find the same error as sim rejected even after performing the steps, you need to check with the service provider relavent to the sim problem.
Oct 18, 2009 | RIM Blackberry 8310 8320 8330 Curve 8100...
I can't remember the pin number to my BT Granite phone. How can I retreive this
I phoned BT and was told no way to retrieve the pin number. So-I did it the old fashioed way and finally remembered it.
Thanks for you interest.
Mike Scott.
Sep 18, 2009 | Lands Phones
Parrot 3100 pairing with blackberry 8310
You have too many phones paired in the Parrot. Delete some of the phones from your parrot and you will be fixed. I had same issue
Apr 19, 2008 | Lands Phones
Need PIN for Just wireless bluetooth
I threw away my instructions for my bluetooth just wireless model #bt-5 and I cannot find the pin number i need to add to sinc up my phone, can you help?
Sep 23, 2007 | Just Wireless HandsFree Earboom Silver...
Just Wireless Bluetooth Headset - BT-38 Logo
146 people viewed this question
Top Just Wireless Radio Communications Experts
Rocketmanusa
Level 1 Expert
robert
Are you a Just Wireless Radio Communication Expert? Answer questions, earn points and help others
