Question about 5.11 Tactical 5.11 59245-120 Field Ops Watch, Coyote Brown
How to reset a 5.11 tactical watch coyote 59245
How to change battery on H3 Tactical HTTH3.15111 watch
  • Remove back
  • Find battery holder
  • Identify type
  • Obtain replacement
  • Remove old battery; install new
  • Check operation
  • Reinstall back
  • Set time, etc.
OR,
Take your watch to a jeweler who, for a reasonable sum, will replace the battery.
OROO
Nov 21, 2016 | Watches
Tip
5.11 TACTICAL watch manuals.
Follow this link, click on the watch model, then click on MORE INFORMATION tab: http://www.511tactical.com/browse/Home/Law-Enforcement/Accessories/Watches/D/30000/P/1:100:10000:10900:10903 There you can download manual for your 5.11 TACTICAL watch.
on Feb 20, 2010 | Watches
How do I set the date?
I did it the long and slow way! I did search again and found this answer after the long haul!
When you pull out the stem, there are two clicks. Do it gently and you will notice when the first click is engaged (by sound or feeling with your fingers). The first click position is exactly for the date adjustment.
For me the click was very faint! Good luck! Now I have the watch with the three interchangeable bands!
Aug 06, 2014 | Smith & Wesson Watches
Watch is frozen, will not reset or change modes
you will need to press the reset or a/c button located usually near the battery well with a pin and a magnifying glass
May 06, 2014 | Mio 0021usblk2 Drive Petite Hrm Black...
5 11 tactical series 59235 watch instructions
is this 511 watch 59235 original or is just a copy? can i put normal battery replacement or it need a 511 battery? thank you
Feb 10, 2014 | 511 Tactical Watches
Date does not set will rotate to next day before it should?
I am not quite sure of your problem but mechanical watches can be 12 hours out and still give the correct time but when it is indicating (say) 9 o'clock, it means 9 a.m. when it is 9 p.m.
If this is the problem you have, then wind the watch forward 12 hours and it will change overnight instead of at noon.
I hope this helps.
Aug 21, 2011 | H3 Tactical H3.15222 Blue Shadow 1 Watch...
Howe do I reset the stop watch. It will not reset
I went to the lorus web site which has user manuals for all their watches. Went through the relivent manual whcih gave details on how to reset the stop watch facility.
Nov 06, 2009 | Seiko Lorus LO111 Watch
How can I use this and reset it ???
there should be a reset button on the watch have a good look closer but u will have to have something to reset it with you cant use your fingers
Apr 17, 2009 | Timex T42351 watch
Hi folks i have 2stanles steel 4"357 and they both miss i of the
You submitted your questin into the wron topic (watches).
Resubmit into the appropriate one.
Dec 21, 2008 | Smith and Wesson Security Products Smith &...
5.11 Tactical 5.11 59245-120 Field Ops Watch, Coyote Brown Logo
19 people viewed this question
Top 5.11 Tactical 5.11 Watches Experts
Jimmy Accardi
Are you a 5.11 Tactical 5.11 Watch Expert? Answer questions, earn points and help others
