Question about Frigidaire Washing Machines
How do you replace a kenmore 70 series lid switch?
  • Frigidaire Master
  • 5,323 Answers
SORRY BUT U HAVE TO REMOVE THE WHOLE BODY CABINET, IT COMES OUT AND PULLS FORWARD AFTER REMOVING SIDE PANELS AND 2 SCREWS AND 2 CLIPS
Posted on Mar 31, 2015
jsrock516
  • 5911 Answers
SOURCE: Kenmore 80 series lid switch
First of all, unplug your washer. You will need to remove the console in order to get to the lid switch. I believe your washer has release tabs under the console at each front corner. Simply slide a putty knife straight in from the front at each corner and push in while lifting up. You should feel the release tabs push in and the console will pop up. Or, you may have a console that has removable end caps. They can be removed by gently prying up on the top of them from the rear on each side. You may have to use a small screwdriver for this. The caps should pop right off. Once removed, you will need to loosen a screw under each cap. Once you have the console loosned, carefully lift it up and lay it back over the rear panel of the washer in its resting position. Be careful not to damage the small plastic hinges that hold it in place. Now you will need to perform the following steps:
1. Under the console you will find the lid switch connector. Unplug the switch from the connector.
2. There will be two brass colored clips. You will need to remove these to remove the machine casing. Place a flat blade screwdriver straight down into the opening on top of the washer and into the groove of the clip. Push the screwdriver away from you while holding into the groove and the clip will release.
3. Open the lid of the washer and place your hand under the front rim of the opening (DO NOT grab the wash tub). Now pull the case from the frame by lifting from the back first.
You do not have to remove it all the way from the frame. Just enough to gain access to the switch. All there is to the switch is a couple of screws holding it in and a ground wire. It's a pretty easy repair job.
Once you've completed your switch installation, make sure you get the case back on the frame correctly by following these steps:
1. While looking down through the lid opening, place the front lip of the machine case UNDER the washer frame and start leaning it back onto the frame. There are four small cleats that must fit into four slots on the case or the washer will vibrate. Make sure the frame is seated properly, lean forward from the front of the washer, grasp both sides of the rear panel and pull towards the case. The rear panel should be seated and flush with the casing before inserting the retaining clips.
2. Insert the brass-colored clips into the slot on the washer rear panel first, then push straight down into the opening on the top of the washer with some force. If you have the case seated correctly, the clips will snap back in.
3. Make sure you plug the connector from the console back into the lid switch receptacle and close the console.
I hope you find this helpful. If you have any questions please let me know by posting comments.
Posted on Nov 02, 2007
mikedurland
  • 481 Answers
SOURCE: Accessing and replacing the lid
  • unplug the washer
  • depending on its age this description should be accurate.
  •  lift the lid and you should see 2 screws on the right of the tub.
  • these are the screws that hold the lid switch assembly.
  •  you can reach between the case and tub to get it out.
Posted on Jun 29, 2008
SearsTechToo
  • 261 Answers
SOURCE: Kenmore 70 series washer
Does it hum or click? If it clicks your coupler is out or a hum could be a faulted gearcase.
Posted on Aug 28, 2008
  • 11 Answers
SOURCE: how to take the top off of a kenmore 70 series
http://www.youtube.com/watch?v=6XIsK3W_Qcg go here and watch this
Posted on Mar 24, 2009
jsrock516
  • 5911 Answers
The following link explains how to replace one:
http://www.fixya.com/support/r385198-replacing_lid_switch
If the switch DOES require replacement, a new one can be purchased on line at searspartsdirect.com, repairclinic.com or appliancepartspros.com. Just use your model number as your search criteria. All three sites offer competitive pricing, so shop all three for the best price. If you still need assistance, please contact me and let me know. If my diagnosis is not correct, please post back and elaborate a bit more so I can assist you further. If your washer is not configured this way, or if you still have questions, please let me know.
Posted on May 11, 2009
Kenmore Washer 70 series Model #110.22722100 won't spin
Check door switch: If the lid switch is bad it will not drain or spin. Try this test: With lid open let it finish wash cycle. Press lid switch down with screwdriver. Washer should begin draining. Release switch. Motor should stop. Press switch a second time. Washer should start spinning as it continues to drain. If motor doesn't come on while lid switch is pressed, replace the switch. OR
http://www.youtube.com/watch?v=q942xn_2VXY
Click if helped.
Feb 25, 2013 | Washing Machines
I have a Kenmore 70 Series Washer. The lid switch
Bob your an the right track.. remove the two screws ( unplug washer ) pull sw from mount and the wires will folow. they are hooked to a wire clip . with it in hand you can see if sw is cracked or broken .. the new sw will come wire& plug/ you can splice it or remove wire harness and reinstall as you took it appart . the 70 series has a lift up top / two clip in front / use a putty knife . ..mm
Dec 04, 2009 | Kenmore Elite HE4 Electric Dryer
I got kenmore 70 series. it doesnot spin but it
You have a bad lid switch . This is the piece , the lid actuator piece , goes down onto , in the hole on the top . Try putting a screwdriver into the hole , to activate the switch , to drain the water and to spin the clothes dry enough to remove , until the switch can be replaced .
Nov 26, 2009 | Kenmore Washing Machines
Kenmore 70 series filled and stopped...
Lid switch problem. Press down on lid and try to start machine. Reply.
Jun 15, 2009 | Kenmore 22422 Top Load Washer
My kenmore top loading washer 70 series wont go into spin cycle
check the lid switch some washers will fill and was with the lid open but will not spin, if the lid is closed manually actuate the lid switch or bypass it electrically, or replace it.
Apr 07, 2009 | Kenmore 22422 Top Load Washer
Kenmore 70 series will not drain or spin
It sounds like the lid switch. If it ws the coupler the water would drain. Check to see if the lid switch is clicking when you put the lid down. replace the lid switch. You have a great washer. Fairly cheap fix.
Nov 20, 2008 | Kenmore 20722
Washing Machines Logo
13 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
