Question about BEGO Gelovit 200 BEGO
Code e9 flashing on bego 200 - BEGO Gelovit 200 BEGO
    New Friend:
Did you ever figure out what the code was for? I just experienced the same thing.
Posted on Jun 18, 2016
Error code e9 on hob aeg hk85440075
From another Post from Daniel T:
E9 on this hob means a user interface control board fault. This is the touch control board which you press to turn on.
What the service manual says is disconnect the hob from the mains connection and leave for 60 seconds. Then wire it back up and turn back on and see what happens.
If still the same then the user control board needs to be replaced.
To access this you need to remove the hob from the work top and remove the screws holding the glass on all 4 sides of the hob.
Then you can lift the glass top off.
From there you will see the user board in the front its the smaller board.
Replace this and that should cure the fault here.
If you need anymore info just get back to me.
My Zanussi induction hob flashes an error code E9 when try
Oct 30, 2015 | AEG Washing Machines
Bloomberg freezer error code e9
Error Code E9 ' Appliance Video
www.appliancevideo.com/repair-help/question/error-code-e9
The unit keeps getting a low water error and everything I could think of checks out: inlet valves, w. ... Error Code E9 ' Appliance Video .... Ice on bottom of freezer
Jul 23, 2015 | Blomberg BRFB1150 | 11.7 cu. ft....
E9 code error pops out and flashes.. what does it mean and how to fix this? Since it came on,cooktop not working at all.. Hope to get some help
I had a look and all I found was for a Prestige cooktop?? E9 apparently means a failure of one of the temperature sensors but not sure which one... Sorry.
Jan 05, 2015 | Cooktops
Error problem e9 in onida 5star split ac
what means of e9 error code in onida split ac ?
Mar 13, 2013 | Heating & Cooling
How do i fix code E9 on midea air conditioner
I have a problem with Midea Brand Aircondition .display shows E9 code error,what is a solution
Dec 22, 2012 | Midea Heating & Cooling
The flash isn't working and the screen reads E9:01
error code is displayed that is failure of flash capacitor charging so replace it
Mar 01, 2010 | Sony Cyber-Shot DSC-S40 Digital Camera
GE JGBP85WEB5WW - F7 / E9 Error codes
Well first of all you determine if problem is with the Key Panel or Control by-
1. Pushing CLEAR/OFF pad.
2. Disconnecting Ribbon Cable from control and waiting at least 32 seconds to see if Code recurs
If code recurs, problem is in the control. Replace control.
If code does not recur, problem is with the Key Panel.
This error code means Function pad button stuck or Bad clock: Unstick button or Replace Electronic Range Control (ERC).
Post comments for more help or information........
Good Luck!!
Aug 31, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Panasonic Kx-TG2432 Displays E9
Same here on KX-TG2248:
"Answer on" is flashing rapidly.
"Message/Slow Talk" is flashing rapidly.
"In Use/Charge" is flashing irregularly.
LED displays "E3" (and "set clock" symbol is flashing).
Removing and restoring power, many times,
produced one "spontaneous remission"
(it worked fine for several hours)
but next time moved (having to disconnect power),
it's now quite "committed" to remaining "insane" as above.
Jul 28, 2009 | Panasonic KX TG5100M Cordless Phone
Codes
0= 98 BO BA 52 D3 21 08 B4
1= D2 EA 29 B7 B5 52 E9 AD
29TH NOV GOOD LUCK
Nov 29, 2008 | StarTech.com StarView SV211K 2-port KVM...
New codes
telepest codes 29TH NOVEMBER 2008
00=98 B0 BA 52 D3 21 08 B4
01=D2 EA 29 B7 B5 52 E9 AD
BEGO Gelovit 200 BEGO Logo
440 people viewed this question
Top BEGO Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a BEGO Toy Expert? Answer questions, earn points and help others
