How can i reinstall windows in neoware ca21 - Computers & Internet
Cannot get to BIOS
When the Neoware Logo appears on the screen, press the Delete
key in order to enter the BIOS configuration.
Terry
Apr 16, 2014 | Neoware Ca21 Thinware Client. A Complete...
Cannot get to BIOS
If that's the one with the Phoenix Award BIOS, you should be able to enter the BIOS by hitting the DEL key when first booting up.
I have two Neoware CA21 Thin clients. They both have the same problem. When I turn them on they do not start up, but instead have a rapid beeping. One has not been used since I have had it, but the other...
is Neoware CA21 a Netware? I have not used Netware in awhile.
Anyway, if you are hearing beeping, that generally means you are having a hardware problem. Check all your connections. Pull the cables and make sure there is no debris and reinsert. Remove memory and clean contacts. Vacuum the inside, since you said it has not run for awhile. Check the harddrive(s) in another pc to be sure it will come up.
HTHs
Wayne
Sep 14, 2013 | Neoware Ca21 Thinware Client. A Complete...
Neo notebook
  1. REINSTALL YOUR WINDOW.
Aug 30, 2013 | Neoware m100 Notebook
Reset Neoware 608 CE password.
Neoware was acquired by HP in 2007 and they seem to have destroyed all Neoware references. That product was end of service in January 09. Their transition rules are at http://www.hp.com/sbso/busproducts_thinclient-HP-neoware-thinclient-migration.pdf, and the old manuals are at http://web.archive.org/web/*/http://www.neoware.com/support/documentation/manuals.html. HP also has manuals at http://h20180.www2.hp.com/apps/Lookup?h_lang=en&h_cc=us&cc=us&h_page=hpcom&lang=en&h_client=S-A-R163-1&h_pagetype=s-001&h_query=thin+client, ans specifically http://h20180.www2.hp.com/apps/Lookup?h_lang=en&h_cc=us&cc=us&h_page=hpcom&lang=en&h_client=S-A-R163-1&h_pagetype=s-001&h_query=thin+client looks promising.
Dec 19, 2009 | Computers & Internet
Thin client and signature pad
God, win ce 5. Hope its not all chinese make. I dont know about your neoware, but just google up how to install app on windows mobile or win ce5. Instructions are not dificult.
Feb 18, 2018 | Topaz Systems Computers & Internet
Low Disk space on Neoware e140 (Windows XP Embedded)
Yes, you can disable this message via the registry editor.
Click start, then Run. In the boxy type regedit. Press enter. (In Vista, click start, then in the search box, type regedit)
Navigate to the folder HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\
Explorer
Click on NoLowDiskSpaceChecks and change the value from 0 to 1. If the entry doesn't exist, click on new DWORD value, type in NoLowDiskSpaceChecks and enter 1.
Navigate to the folder HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Policies\
Explorer and do the same thing there.
Exit out of the registry. Your computer may need to be rebooted in order for the changes to take effect.
Thanks and please take a moment to rate this solution as fixya.
Mar 02, 2009 | Neoware Systems e140 Thin Client - Thin...
Neoware thin client password recovery Windows CE
OK first off I don't know anything about this device, But I can tell you most OS level passwords I have dealt with are stored in the OS by way of a battery on the main board. If you open the unit and remove the battery and wait about 15 minutes, then reinstall the battery and close everything back up. Then turn it on and see what you get.
Has worked for me in the past On laptops.
You may have to try and leave the battery out overnight and then try it.
wwiz
Oct 13, 2008 | Computers & Internet
Use Administrator The "A" is capitaized only....worked for me...administrator with Administrator for password!!!!
Drew
Apr 02, 2008 | Neoware CAPIO 620 (cp4h-bb-aa0) Network...
Computers & Internet Logo
99 people viewed this question
David Payne
David Payne
