Question about Canon Computers & Internet
Canon irc1021i colour problem
E003
E003 Error code in canon ir2420 photocopier
Code E003-0000 Description Abnormally low temperature (detected by main thermistor)
After the temperature detected by the main thermistor has reached the specified value, it does not reach the specified value during initial rotation. Remedy - Check the connector of the fixing film unit. - Replace the fixing film unit. - Replace the DC controller PCB. Error Codes Canon iR2420 Code E003 0000
Oct 28, 2015 | Canon Office Equipment & Supplies
Canon irc1021i Error code= e000003
i can't see addition function button on my computer
Nov 05, 2012 | Canon Office Equipment & Supplies
Canon Image Class D860 - Error message E003. How do we correct?
Under service mode ( MENU and # ) find CLEAR, and select ERR ( if you cant find err, select ALL ), and OK.
Restart machine.
If that does not help change the whole fixing assy.
E003 means that you have temperature problems in fixing assy.
If clear does not help, that means that you have bad thermistor or fixing ceramics.
Jun 29, 2010 | Canon imageRUNNER 400S Copier
E003 Switch the power on and off again
check if thermistors are ok/or replace them
If the fixing heater fails to operate.
• E002 or E003 is indicated.
Mar 22, 2010 | Canon NP 6050 Copier
I have a problem with copier GP 225 it gives E003 how do I clear this code?
fuser temp not rising at correct pace. could be thermistor,thermal switch or fuser lamp
Oct 07, 2009 | Canon Office Equipment & Supplies
Canon NP-6612 copier Signal E003
E003 is fixing low temp error
please check thermistor and heater
Dec 04, 2008 | Sharp AL 1631 Copier
E003
problème d'installation d'une imprimante canon lbp 1000 laser son driver ne fonctinne pas
Feb 09, 2008 | Canon imageCLASS D860 All-In-One Laser...
Computers & Internet Logo
43 people viewed this question
Top Canon Computers & Internet Experts
Computer Links
Tony
old marine
old marine
Are you a Canon Computer and Internet Expert? Answer questions, earn points and help others
