Question about Science & Laboratory
Composition of mercury - Science & Laboratory
What does composite
Composite video is three plugs, one for Left Audio, one for Right Audio, and one for Video.
Oct 23, 2017 | Televison & Video
Which site is the best site for ACP aluminium composite panels?
There are many websites for ACP aluminium composite panels. Among them, Deltyn is the best site for ACP aluminium composite panels. Because this site is the good provider for ACP aluminium composite panels. Deltyn Aluminium Composite Panel Manufactures Suppliers ACP Cladding ACP...
Apr 06, 2016 | Building Materials
Which site is suitable for composite panels?
There are many sites which are suitable for composite panels. Among them, deltyn is the best site. This site is the leading site for providing aluminium composite panels. Deltyn Aluminium Composite Panel Manufactures Suppliers ACP Cladding ACP...
ELMO Visual Presenter (Model EV-2000AF) does NOT display COLOR properly onto HDTV monitor. (Appears Bluish or Reddish w/ 2 Composite Cables connected)
Those jacks you are plugging into on the HDTV are not composite inputs. They are component. The reason the color is not right is, you have to have a Red, Green and Blue connection.
The black and white picture from the 1 cable is because you are using a composite signal into a component green.
Big difference between a composite and a component signal. I hope this helps.
Apr 10, 2012 | Televison & Video
HOW TO SLOVE THE ERCORE OF 000064 PLESES TELL ME SIR
composit power supply or DC controller pcb was faulty please check it.
or check all this connector on DC controller
PCB (J301), composite power supply PCB (J136), primary charging roller,
developing assembly, transfer charging roller?
DC controller PCB (J301) <-> composite power supply PCB (J136)
composite power supply PCB (J130-7) <-> primary charging roller contact
composite power supply PCB (J130-1) <-> developing assembly contact
composite power supply PCB (FT133) <-> transfer roller contact
if all this are corrcet then you have to replace these pcb
Apr 06, 2011 | Canon imageRUNNER 3300 All-In-One Laser...
Errore000064 occured
Power supply voltage error (high-voltage error)
The presence of a high-voltage error is communicated by the composite
power supply PCB. (The output for primary charging, developing, or transfer
has deviated from a specific level of voltage.)
Main cause: The contact has poor connection. The wiring is faulty. The composite power
supply PCB is faulty. The DC controller PCB is faulty.
Action
1. Contact
Is any of the contacts of the primary charging roller, developing assembly,
or transfer charging roller soiled? Or, is there poor contact?
YES: Clean the contact, and set it once again.
2. Wiring
Is the wiring between the contacts for the following normal: DC controller
a. DC controller PCB (J301) <-> composite power supply PCB (J136)
b. composite power supply PCB (J130-7) <-> primary charging roller contact
c. composite power supply PCB (J130-1) <-> developing assembly contact
d. composite power supply PCB (FT133) <-> transfer roller contact
NO: Correct the connection.
3. Composite power supply PCB, DC controller PCB
Try replacing the composite power supply PCB. Is the problem corrected?
YES: Yes.
NO: Replace the DC controller PCB.
Jan 19, 2011 | Canon imageRUNNER 3300 All-In-One Laser...
2002 mercury cougar vacuum line off the top of transmission
The hose connects to the top of the transmission, underneath the car's battery (you'll have to remove the battery to see the connection site). It's important that this hose, once reconnected, does not does not get crimped. If the hose is not free to "breathe" pressure buildup in the transmission can cause fluid to pour out of the fill point (where the dip-stick goes).
Apr 11, 2010 | 2002 Mercury Cougar
How to clear E000064 problem in ir3300 model
E064
0000 The presence of a high-voltage error is communicated by the composite
Main cause The contact has poor connection. The wiring is faulty. The composite power
Action
1. Contact
2. Wiring
YES: Yes.
Feb 26, 2009 | Canon imageRUNNER 3300 All-In-One Laser...
Canon ir 2200 Error code E000064-0000
E064 The presence of a high-voltage error is communicated by the composite power supply PCB. (The output for primary charging, developing, or transfer
Main cause The contact has poor connection. The wiring is faulty. The composite power supply PCB is faulty. The DC controller PCB is faulty.
Action
1. Contact
Is any of the contacts of the primary charging roller, developing assembly, or transfer charging roller soiled? Or, is there poor contact?
2. Wiring
PCB (J301), composite power supply PCB (J136), primary charging roller, developing assembly, transfer charging roller?
YES: Yes.
Feb 24, 2009 | Canon imageRUNNER 3300 All-In-One Laser...
My LCD TV has a red background instead of black. Everything is red, even when I disconnect all cables. It used to be black, and now, whatever source I use (component, composite, whatever), the images are...
Backlight bulbs turn red when they go bad. They are hard to replace, and require soldering. They contain mercury vapor, so I would be careful not to break them. Bulbs cost about 20 each usually. Could be 2-4 bulbs to replace. It is a pretty difficult repair, good luck.
Dec 06, 2008 | Samsung LN-T4665F 46 in. LCD Television
Science & Laboratory Logo
136 people viewed this question
Top Science & Laboratory Experts
Gareth Cockram
Gareth Cockram
William McMath
ray gallant
Are you a Science and Laboratory Expert? Answer questions, earn points and help others
