Question about Simpson Garden
No water pressure, but is does start
When I pull the Handel for water there is no pressure
2 Suggested Answers
  • 68 Answers
SOURCE: NO PRessure
Hi It sounds to me like your unloader valve is stuck, this is the thing that is meant to move up and down when pressing the trigger.Please remove the unloader valve assembly and check for damage. If no damage is found then grease and lubricate this part and replace and this should work ok again.
Posted on Jun 16, 2010
I need a handel for pressure cooker brand is jasi and the handel i need is for the pot thank you.
Fixya does not sell pressure cooker handles. Check with a local appliance parts supplier.
Nov 14, 2016 | Home
Cant pull start the pressure washer
Turn water off to the pressure washer, release pressure by applying hand pressure to sprayer. After water pressure is released, turn water back on (should not have motor running without water.) then try to pull start.
Jun 18, 2011 | Honda Karcher G2400HH-R Pressure Washer
When i pull in front brake handel the brake calipers push out but when i release brakes the brake handel still has presure on it it seems that the fuiled is not returning to master cylinder
Your brake hoses are collapsing internally and holding pressure. I've seen this multiple times, especially on Yamahas. Replace the brake hoses, flush the system and refill w/DOT 4 fluid, bleed the air and you'll be good to go. Good luck!
Jun 11, 2011 | 1982 Yamaha XJ 650
How do I backwash my sanddollar pool filter
Shut the pump off, then push down on the backwash (BW) handel turn it clockwise 180 degrees to BW and start pump again. Run pump till water coming from BW pipe runs from cloudy to clear. Shut the pump off and pushing down on the BW handel again turn it 180 degrees to filter and start pump again.
Oct 27, 2010 | Pentair Sand Dollar 19" Filter with 1 Hp...
NO PRessure
Jun 15, 2010 | Honda Pressure Washer PSI 3000
Low stream
these faucets have a single handel, and have a cartage that can be taken out and cleaned. Low water pressure is caused by minerals in the water to build up in the cartage and slow down water flow.
Mar 28, 2010 | Kohler K-10416-BN FortĀ½ Single Control...
Shower head has little preasure or water volume. is there a flow restrictor that can be removed?
their might be on the handel where the hose meets, but if really low water pressure then maybe more of a problem.
Mar 26, 2010 | Grohe Aquatower 3000 Shower Tower...
Where to load staples
If you have a internal finnisher,you open the front cover of the finnisher,remove the stapler cartrigde with it's green handel.Remove the paper cover of the previous cartridge.Insert the new staplers in the possition of the arrows.Remove red plastic.Reinsert cartridge back into machine.
Nov 19, 2008 | Canon imageRUNNER 2870 Copier
Garden Logo
Top Simpson Garden Experts
John Trevino
JOHN LAPIER
ray gallant
Are you a Simpson Garden Expert? Answer questions, earn points and help others
