Question about Faber TEND30SS300 Decorative Collection 30" Tender 300 CFM Wall Hood -
Second Fan Speed Not Working
The lights, lowest fan speed, highest fan speed all work properly. The middle fan speed does not work is not illuminated when pressed.
2 Suggested Answers
  • 46 Answers
SOURCE: I HAVE A FABER RANGE HOOD AND THE FAN IS NOT WORKING
sounds like motor is burned up! I have never seen that brand myself? hoods cab be relitivaly cheap i would leave out the service man and replace the hood...just check pricing then make up your mind! but if you found someone really willing to, what you have can be fixed!!!
Posted on May 26, 2009
Medium Fan Speed not working
Switch is probably faulty, or wire / connection to switch. If switch and wiring test ok trace wire from that button back to wherever it goes and look there for fault.
May 12, 2014 | Faber TEND30SS300 Decorative Collection...
Where is the high speed fan relay on a 95 lumina apv?
The photo I have shows the high speed relay on the firewall or on the heater box in the engine compartment. It should be near the blower motor.
Jul 10, 2013 | Cars & Trucks
When using the fan, we epxerience smike and burning smell on medium speed setting, but not the highest or lowest. Light have been removed to isolate where the problem comes from. Fan blades still turn,...
My concern hear is for your safety. Repairing something like this is not worth the risk of a fire breaking out or the cost of a repairing the unit. Because the problem is now in the medium setting it could go to the others as well.
Keep the light kit, but replace the fan.
Jul 02, 2011 | Oasis Hunter 54' Ceiling Fan
I have 2 Remote Control Model UC7848T units. Unit #1 Lowest speed doesn't work at all, middle speed and high speed still working. Light control work fine. Unit #2 Great difficulty in turning on or...
You need to completely disassemble the hand held remote unit, remove the rubber push buttons and clean the contacts. Mine do this frequently. The contacts are black and will be slimey. I just use soapy water and a soft cloth to gently clean them. Be sure to dry them completely before reassembling. Also be sure you dont get any of the electronics wet.
Sep 15, 2010 | Hunter 52" Ceiling Fan With Light And...
The blower fan cuts out intermitently regardless of fan speed when I go over a bump or take a corner. The dash had been removed to replace the evaporator and this is when the problem started. When the fan...
From what you said I would think you have a bad/loose connection. I have never had to change the fan resistor but from what I under stand usually when the resistor is bad the fan only run with the fan speed on the highest setting. If the fan quits working try putting the fan on the highest speed setting, see if fan starts working. Sorry but that all I got for now.
Sep 10, 2017 | 1999 Buick Century
Overheating cadillac
YOU CANT BYPASS THE COOLANT FANS TO OPERATE FULL SPEED.IF YOU TRY YOU ARE GOING TO HAVE HEAD ACHES AND PCM TROUBLES.YOUR THREE COOLANT FAN SPEED IS CONTROL BY THE POWER MODULE IT ASSISTS THE COMPUTER SWITCHING FAN SPEEDS AND CLIMATE CONTROL FUNCTION.CHECK ALL 3 FANS RELAYS ONE OF THEM IS NOT WORKING.IT WILL CAUSE FAN SPEED PROBLEMS.DONT BYPASS OR OVERRIDE FANS.IF SO.YOU ARE GOING TO HAVE PCM AND CLIMATE CONTROL PROBLEMS.IF YOU HAVE ALREADY CHECK 3 FAN RELAYS.THEY ARE GOOD LET THE CADILLAC DEALERSHIP CHECK IT OUT.
Oct 04, 2009 | 2000 Cadillac Seville
My Air conditioner only works on high
The switch that runs the blower motor for air and heat sends the DC voltage through some big resisters when it isn't set on high. (On high it sends all the power to the motor.)
If the lowest speed doesn't work then one of the resisters has gone bad, or come disconnected. If more than 1 speed doesn't work then a differant resister has gone bad or disconnected. The power runs through each resister in series so the most common one to go bad is the second to highest speed. when this resister is bad thaen it will only work on the highest setting. Replacing the switch won't fix it. You will have to find the resister that is bad and replace it.
The resister bank is usually tucked up behind the dash where only a kid can focus his eyes, and contort himself enough to see it.
Once the resister is replaced it should run perfectly.
Presto.
Aug 26, 2009 | 1998 Mercury Mountaineer
2002 Honda Odyssey fan only works at high speed. The A/C compress
Usually when the blower fan only operates on hi speed, its because of a failed blower motor resistor. You still have hi speed because on hi, the power going to the blower motor goes directly to it, as opposed to the lower speeds, when the power is routed through the resistor, thus lowering the voltage, which in turn lowers the speed of the fan. The resistor is usually located near the blower motor itself, under the hood back near the firewall.
Aug 15, 2009 | 2002 Honda Odyssey
2000 grand prix fan speed
i have been having that same exact problem with my 2002 grand prix for over a year now, and when my ac is on the lower setting the it doesnt work plus the headlights and lights on my dash go out. On Max everything works. i changed the blower resistor(about $35), still doesnt work. i changed all relays and fuses related to the ac, still doesnt work. i changed out the actual ac control switch in the dash, still doesnt work. i have changed everything but the blower motor and have asked every mechanic and auto parts retailer i come across and no one knows the answer. The best answer i got is that it is probably a wiring problem like a short somewhere.
May 28, 2009 | 2000 Pontiac Grand Prix
Range Hood Issue
Definetly need a new motor control.
Nov 26, 2008 | Kitchen Ranges
Faber TEND30SS300 Decorative Collection 30" Tender 300 CFM Wall Hood - Logo
57 people viewed this question
Top Faber Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Faber Kitchen Range Expert? Answer questions, earn points and help others
