Question about Haier 45-Pint Dehumidifier DE45EJ-L
What does E1 mean? - Haier 45-Pint Dehumidifier DE45EJ-L
What does error code E1 mean for an idylls dehumidifier?
You get that info from the mfg or manual.
Sep 08, 2017 | Dehumidifiers
What does E1 mean on the display of my dehumidifier
follow this steps and fix it. God bless you
E1 error code : Deshumidifier
indicates generally an issue with rh sensor on the back of the control. However, at this time we would like to gather further information relating to the application if possible.
Oct 29, 2013 | Haier DE65EK 65 Pints eco-Friendly...
Whar does the E1 code suggest I do?
E1 indicates that the filter needs to be removed and cleaned. Be sure to turn the unit OFF and plug it, before removing the filter. You can either vacuum the filter or if it's really dirty, wash it in warm water and dish washing liquid, rinse and thoroughly dry it, before reinstalling it. NEVER operate the dehumidifier without the filter installed. Doing so could cause damage to the unit.
Jul 04, 2011 | Dayton 1DGX4 Dehumidifier
Display lights up E 1 nothing else happens. What does the E 1 mean? Unit is 4-5 years old.
On models a lttle later than yours E1, indicates that the air intake filter needs to be removed and cleaned. Probably, the same thing as yours. Before doing so, turn the Master ON/OFF Switch to OFF and unplug the unit. If you wash the filter use warm water and dish washing liquid, Rinse thoroughly and allow to completely before reinstalling. DO NOT operate the unit without the air filter in place.
Hope this helps you to troubleshoot and solve the problem.
Jun 26, 2011 | Haier 45-Pint Dehumidifier
What does e1 mean
For many window air conditioners this code is simply a reminder to clean the air filter. After like 750 hours of run time this code pops up and you have to clean the filter and then reset the unit before it will work again. To reset the code you need to simply unplug the unit and then plug it back in again.
Hope this helps; good luck.
Jun 13, 2011 | Haier 45-Pint Dehumidifier
E1 CODE ERROR
E1 code for the primary humidity sensor behind right side grill. Unit MUST be unplugged from outlet. Take right side grill out, unplug sensor from wire socket and plug back. If no help, you need new sensor.
Dec 30, 2009 | Danby DDR451 Dehumidifier
My DANBY Dehumidifier model DDR4588EE has been working ok until it showed a E1 error code and since then it does not work properly. Any ideas please?
Dec 30, 2009 | Dehumidifiers
What does an E1 error message mean?
Water bucket full or switch is depressed under the bucket, check.
Dec 06, 2009 | Haier HDN655E Dehumidifier
Kenmore model # 25800-25801 Error code E1?
unit has a sealed system leak call sears for tech support 1-800-905-9505 it is under warranty
Apr 15, 2008 | Kenmore 53701 Dehumidifier
Haier 45-Pint Dehumidifier DE45EJ-L Logo
Top Haier Dehumidifiers Experts
Steve
Shawn DuRee
Michael Vincent Cruz
Are you a Haier Dehumidifier Expert? Answer questions, earn points and help others
