Question about 2009 Mercedes-Benz GL-Class - GL450 - Sportz SUV & Minivan Tents
Changing tail light
How to change a bulb in the tail light
    Sergeant:
  • 462 Answers
Most you access through the trunk some you have to replace the whole light like gfs 2010 accent
Posted on Sep 07, 2014
How to change a taillight bulb on a 1986 dodge aries station wagon
Tail light problem '1986 Dodge Aries 4 Door - faqqq
www.faqqq.com/.../tail-light-problem-1986-dodge-aries-4-door-123242...
Question Product: 1986 Dodge Aries 4 Door Question Details: Tail light problem I ...Most people suspect a bad bulb and when they go to change it, it lights up.
Oct 16, 2015 | Dodge Cars & Trucks
How to replace, step by step, the rear brake light bulb on hyundai atos 1999?
How Do You Change Tail Light Bulb
Remove the wiring harness from the tail light lens assembly. Disconnect tail light bulb from the wiring harness socket. Reconnect the wiring harness to the tail light lens assembly. To confirm proper installation of the new tail light bulb, place the key in the on position.
IT IS VERY SIMPLE OR GO TO AUTOZONE AND HAVE THEM CHANGE IT OUT FOR YOU AND WATCH THEM ONCE. GOOD LUCK.
Jul 01, 2015 | Hyundai Cars & Trucks
2009 hertiage can u just change the tail light bulb not the harness
This is what your tail light bulb looks like:
http://img.jpcycles.com/product/3400560_A.jpg
The only difference is, it might be clear, or red.
Check it out before buying a new one.
It just pulls out of the socket, new on pushes in.
Mar 16, 2014 | Harley Davidson FLSTC Heritage Softail...
Changing tail light bulb
http://www.bikerhiway.com/images/large/bikerschoice/49-0288_LRG.jpg
If you mean like the tail light in the above picture, most of them it's just the same bulb that lights the tail light/brake light functions (dual element bulb).
Remove the lens (usually two screws), lightly push as you turn counter-clockwise (about 1/4 turn).
Reinstall in reverse.
NOTE: If you can't get the new bulb to turn and lock into place, remove it, turn it 180 degrees, and reinstall.
On a dual element bulb, the two nubs at the end of the base are offset, so it can only go in one way.
Feb 04, 2014 | Harley Davidson Motorcycles
How to change back brake light bulb n/s
Access to the tail light cluster should be through panels in the rear corners of the vehicle. Remove the panel and you can remove the tail light cluster to replace the bulbs. This is the position on most sedans, unless, like on pick-ups, the tail light lenses have screws which allow the lenses to be removed to change the bulbs.
Apr 30, 2011 | Volkswagen Golf Cars & Trucks
How do I replace a rear turn signal bulb?
Some bulbs can be changed without removing the tail light. First check to see if there is an access panel in the trunk trim near the tail light. If there is, you can twist the turn signal socket counter-clockwise to remove it from the unit. If there is no access panel you will have to remove the portion of trim blocking the tail light. This is usually held in by a few small clips. After it is removed you can follow the directions above.
Lastly, some models have to have the tail light removed to change a bulb. The bolts will either be behind the trunk trim or on the inside edge of the tail light.
Once the bulb is changed just reverse the steps to put it back together.
Good Luck!!
Mar 04, 2011 | 2000 Buick LeSabre
How do I change a brake light bulb in a 1999 c70 volvo?
Welcome to FixYa.com
Brake Lamp Replacement
Location of the lights
The illustration shows the locations of the lights on the RH side. The LH side is the same but
mirror-reversed.
The lights have the following functions:
- 1 +1 = Parking light Fail light
- 2 = Reversing light
- 3 = Fog light LH side only (LHD cars)
- 5 = Direction indicator
- 6 = Brake light
Tail light changing bulbs
Ignition off.
Open the cover in front of the tail light
Undo the wing nut and take out the lamp holder.
Change the defective bulb.
Fit in reverse order.
Check that all bulbs lamps are intact and in working order.
Replacement of tail light cluster
Note! If a new tail light is to be fitted, the sleeves must be ground down 1.5 mm.
Open the cover in front of the tail light Undo the panel partly in front of the tail light Unplug the
connector for the tail light Undo the four nuts securing the tail light see illustration.
Pull the tail light straight out. Fit in reverse order
Note! check the sealing and fit on reassembly.
Check that all bulbs lamps are intact and in working order.Thank you for Using FixYa.comKind Regards, LeeYour FixYa Expert and Master Technician
Jan 27, 2011 | 1999 Volvo C70
Change out a taillight
You want to change the tail light bulb?
The process for replacing tail light bulbs is the same in all models. If you have a burnt-out tail light bulb, you may need to replace the brake light, the reverse light or the turn signal. The procedure to replace each of the bulbs is the same.
    Instructions
    1. Open the Hummer's rear swing gate. This will expose the edge of the vehicle's tail light assembly. You'll see two small Phillips head screws that hold the tail light assembly in place. Put on your gloves.
    2. Remove the two screws from the tail light assembly. Pull the tail light out and inspect the back for two bulbs. The top bulb is the brake light and turn signal. The bottom bulb is the reverse bulb. Determine which bulb you need to replace.
    3Rotate the bulb's socket counterclockwise to disconnect it. Unplug the bulb from its socket.
    4Push the replacement bulb into its socket firmly. Insert the socket back into the tail light. Turn it clockwise to secure it in place.
    5Place the tail light into its cradle. Hold it with one hand and replace the Phillips head screws with the other.
Dec 03, 2010 | 2008 Hummer H3
How do i change the tail light on a 2004 tahoe
Open rear hatch. Remove two mounting screws at the side corner which mount the tail light assy to the body. The whole tail light assy can now be removed. Twist desired bulb holder counterclock wise to remove, then pull bulb to remove. Reinstall in reverse order.
May 19, 2010 | 2004 Chevrolet Tahoe
2009 Mercedes-Benz GL-Class - GL450 - Sportz SUV & Minivan Tents Logo
63 people viewed this question
Top Napier Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Napier Vehicle Part and Accessory Expert? Answer questions, earn points and help others
