Question about MGE Computers & Internet
What is a CRUZ control card? - MGE Computers & Internet
PROBLEM WITH TABLET CRUZ READER R101
To update the firmware you can follow the directions here http://www.ehow.com/how_7890482_update-cruz-reader-firmware.html
I used a similar method when I had my Cruz Reader R101. This process is called "side-loading"
You will have to download a file to your computer (not your tablet), remove the SD media card from your cruz, then transfer the downloaded file from your computer to it, then replace the SD card to your cruz.
Also you can download the user manual here http://www.retrevo.com/support/Velocity-R101-Tablets-manual/id/23894dj696/t/2/ which shows how to remove the card, and this is a great reference to keep on your reader. For example, page 14 shows how to transfer files to and from your reader. Good luck!
Jul 21, 2012 | Velocity Micro Cruz Reader R101 Tablet PC
Velocity cruz tablet (R100 series) is frozen on startup screen that says
Give the thing to some one and purchase a new device. The processor is not operating the unit. I see no way to recover from this problem. If you remove rear cover and unplug battery you can try again and again. You can install os on micro card but it will not work. it makes a nice paper weight.
Gumper
May 13, 2012 | Velocity Micro Cruz Reader R103
My Android Cruz Reader R101 starts on the Cruz flash screen, skips then goes back to Cruz flash screen. I have reset it using the reset between the power and External SD card. I also removed the back and...
This sounds similar to something that happened when I tried rooting my android phone. If it's the same thing, that means you will need to go to recovery mode and install an update.zip package that you can find somewhere online for it. It's because the code for what's supposed to happen after that screen is overwritten and it doesn't know where to go.
May 06, 2011 | Velocity Micro Cruz Reader R101 Tablet PC
Hi, my reader is saying "android.process.acore has stopped" Force closing won't work. I know firmware update via zip file is available but it's midnight here and I don't have an sd card handy....
Sorry to hear your are having issues with your Cruz Reader. I have a Cruz Reader R101. Unfortunately you have to update via the SD card for the Cruz Reader. It doesn't do a firmware update from the USB cable.
If you don't want to try and update it now you could also try to just restart it. If you can't get it to restart normally you can remove the back cover and unplug the battery, then plug it back in.
Apr 25, 2011 | Velocity Micro Cruz Reader R101 Tablet PC
How do you restor you cruz r101 to factory default
The easiest way to restore the Cruz Reader to factory defaults is to update to the newest firmware which can be downloaded from here. The instructions for doing the upgrade are also explained on the link above.
This will revert everything back to original condition leaving any information on the internal and external memory cards intact. If you are looking to clear those as well you can do so by formatting the cards by going to Settings->Storage (might say SD card)->Unmount->Format. You can also take the cards out and put them in your computer and use the computer to format them.
The process is pretty of upgrading the firmware is pretty simple even though it might be intimidating. Let me know if you have any more questions
Hope this helps
Ray
Mar 12, 2011 | Velocity Micro Cruz Reader R101 Tablet PC
How do i get it to connect to my computer to get files from there?
Plug in the USB cable. My Vista machine recognized the Cruz as an external storage device (like a flash drive) and displayed a folder for the internal 4gb flash and another folder for the 2gb SD card I added. You can't access the folders from the Cruz while the PC is connected but you'll see any files you copy over once the cable is disconnected. (use Astro to view files in the folders)
Jan 05, 2011 | Velocity Micro Cruz Reader R101 Tablet PC
I turned the Cruz Reader off and I can not get it to turn back on. I tried to charge it but no light will come on. Any suggestions?
Taken from Velocity Micro Support Center:
What should I do if my Cruz device will not turn on?
If your Cruz device will not turn on or freezes, follow the steps below to resolve this:
  • Locate the Cruz RESET location between the Power Button and mini-USB port.
  • Using the straightened end of a small paperclip, insert it perpendicularly into the RESET hole and hold for 5 seconds.
  • Turn on your Cruz
If the steps above do not allow you to power on again, then continue with the steps below:
  • Remove the Cruz from the charger and eject the External SD card.
  • Place the Cruz face down on the desk, starting at the External SD slot, pull off the back cover of your Cruz.
  • In the lower left corner of the back of your Cruz, locate the battery power cable. Unplug the cable and replug it again.
  • Return the back cover to your Cruz and snap it into place.
  • Re-insert your External SD card and power on your Cruz.
Jan 02, 2011 | Velocity Micro Cruz Reader R101 Tablet PC
I forgot the pattern to unlock my cruz reader how do i fix it?
i forgot the pattern to my cruz tablet and i dont know how to unlock please help me!!!!!
Jan 01, 2011 | Velocity Micro Cruz Reader R101 Tablet PC
How to I sync my ebooks to my cruz reader
The easiest way, if you don't have CruzSync on your computer, is with an SD card. Copy the files onto it then put the SD card in your Cruz. Then open Astro from the home screen and find your new SD card and open that up. Or you can use the cradle to transfer files. Open one internal browser to the cruz and one to your e-books then copy and paste them over. You'll fill up your internal memory pretty quickly this way, though.
Dec 27, 2010 | Velocity Micro Cruz Reader R101 Tablet PC
Brake lights and cruise control are not working. Checked fuses and lamps all are ok.
sounds like a faulty brake light switch located down by the brake pedal
Nov 30, 2009 | 2005 Chevrolet Colorado
Computers & Internet Logo
Top MGE Computers & Internet Experts
Jax Planet
Jax Planet
Raj Patel
Are you a MGE Computer and Internet Expert? Answer questions, earn points and help others
