Question about Dell Latitude D810 Notebook
Why have I only been able to power up my Dell Latitude d810 by removing the power adapter cable and then pushing power switch. After it boots up everything seems normal while running on AC. The battery shows 100% charge. Wierd?
    Top Expert:
  • Dell Master
  • 8,248 Answers
Could be a faulty power cable
Posted on Apr 06, 2015
Pyrhyc
  • 2028 Answers
SOURCE: Dell Inspirion 1526 Laptop Battery is not charging
Sound like the battery. Take the battery out and there should be a power meter on it, press it, if there are three lights that flash, the battery is shot. Not all batteries will flash if they are worn out, but they are supposed to. Try a new battery, I believe this will coorect the issue.
Posted on Jun 21, 2008
daryn720
  • 113 Answers
SOURCE: dell inspiron 1525 will not charge the battery
CHECK IN YOUR BIOS AND MAKE SURE ANY SETTINGS FOR POWER ARE ALL CORRECT ...SO THAT WOULD BE A F2 FUNCTION IF THE ABOVE IS CORRECT ...SEE IF THAT SOLVES THE ISSUE .
Posted on Jun 02, 2009
This problem has arised because your motherboard hasn't identified your battery. So, this is motherboard problem.
next time when you chat with the dell representatives, tell them that your motherboard is not recognizing your battery. They would arrange a pickup and would have it repaired in their center.
Good luck,
~regards,
Jegan
Posted on Jun 03, 2009
  • 3940 Answers
SOURCE: i had the battery not recognized on boot up. then
the Dell AC adapter has a sensing pin so the bios can determine the wattage of the adapter. If the system cannot ID the adapter, the battery charger circuit is disabled. You'll need a functional DELL ac adapter to get the battery to charge
Posted on Sep 26, 2009
Testimonial: "thanks for the prompt response."
  • 177 Answers
SOURCE: My dell D810 won't power up.
Please try the following troubleshooting steps:
1 Disconnect the battery and the charger
2 Let it sit for 1-2 minutes.
3 Press and hold down the power button for 30 seconds.
4 Connect the charger (don't connect the battery yet) and try to start by pressing the power button.
Let me know if everything remain same.
Posted on Feb 18, 2010
Why does my latitude d810 say there are no wireless networks available?
Have you rebooted your machine? shut down, unplug from AC remove battery, plug in, reboot. Try to connect. Is the wireless adapter enabled? Have you tried a Ethernet cable? Have you rebooted the wireless device?
Dec 17, 2012 | Dell Latitude D810 PC Notebook
Dell D810 Laptop wont power on. Have brought 2 new ac power adapters. They work (led light on power adaper goes on), but when I plug them into the computer the led light on the adapters go off. Computer...
HELLO FRIEND, THE PROBLEM WITH THE LAPTOP IS QUIT A MINOR ISSUE BUT YOU HAVE TO DO SOME SOLDERING WORK ON THE COMPUTER. THERE'S A POWER SUNG ON THE COMPUTER WHICH HAS TO BE SOLVED BEFORE IT CAN WORK WELL, AND STOP THE LIGHT OFF PROBLEM.
Jul 30, 2011 | Dell Latitude D810 Notebook
I have DELL LATITUDE D810 I am having an issue charging it`s battery, when the AC Power adapter is connected the notebook works fine, but the battery does not charge, as soon as I disconnect the power cord...
Yo! i think you should try something.get a friend that uses your type of adapter, try charge it with that and see if it responds.if it doesn't charge, you will have to replace your battery which means its spoilt.
Jul 24, 2011 | Dell Latitude D810 PC Notebook
My Dell Latitude D810 won't even start up. All I have is the bluetooth light. Can you please help?
1. Take the battery out of the laptop & try to turn on the laptop using power adapter only. If the computer turns on, then the battery is defective & needs to be replaced.
2. Make sure the power adapter is not defective. Test the output voltage of the power adapter using a voltmeter. Compare the voltmeter reading to the nominal value written on the adapter or the laptop.
3. Make sure the DC jack is not loose or broken. A loose DC jack will need to be re-soldered. A broken one will need to be replaced.
4. If you have another processor which is compatible with your laptop's model, try swapping processors & test to see if the laptop will work.
5. The power button could be bad.
6. The motherboard could be defective & needs to be replaced.
Sep 11, 2010 | Dell Latitude D810 Notebook
Dell d810 will not power on
You said you tried another power cord, but what about another power adapter? Try jiggling the cord around and manipulating it back and forth a little and see if the led on your computer lights up. This type of problem is usually the power adapter and/or cord. What about your battery - does it boot with your battery?
Mar 21, 2010 | Dell Latitude D810 Notebook
Have a Dell D810. Battery at 75% charge. When I
Get a 90w adapter is the only resolution. The D810 on a 65w adapter will:
  1. Disable the battery charger
  2. Run slower due to throttling
The 65w adapter MAY charge the battery if the computer is not running (Not sure on that)
Jan 25, 2010 | Dell Latitude D810 Notebook
Dell latitude d810 will not boot up; stuck after dell logo.
boot file is corrupt...
re-install OS
visit my site
http://www.sureshayyar.110mb.com/
FormatDisk page has all resloution of problem
Jan 16, 2010 | Computers & Internet
Computer will not turn on
Do you hear the hard disk spin up? is there a hard disk boot password configured? can you see a bios screen as it tries to boot? is the light on the power supply lighting up?
May 28, 2009 | Dell Latitude D810 PC Notebook
Dell Latitude D810 Notebook Logo
56 people viewed this question
Alun Cox
