Question about OKI B4350 Laser Printer
Changing the toner cartridge in an oki b4350
We have a really old printer at work. I have just received a new toner cartridge but i have no idea how to fit it properly. It keeps saying toner is empty.
  • 115 Answers
Is it a OEM cartridge, which means that its made but the manufacturer of the printer. If it is a refurbished cartridge then it will probably not be "recognized" by the printer and subsequently tell you its low on ink.
Posted on Jun 23, 2009
OKI B4350 error 173
That is a temperature error with the fuser, most likely the thermistor. Really the fuser needs to be replaced. Hope this helps.
Feb 22, 2010 | OKI B4350 Laser Printer
Installed toner cartridge which came with new printer, now showing error message toner missing
check for tape covering toner 'dispenser'. also, that it's installed correctly!
good luck!
Oct 23, 2009 | OKI B4350 Laser Printer
Error tonersns
The toner leak can cause the optical pair responcible for the toner sencing to become dirty. The easiest way to try and rectify this is to vacuum clean the area under the drum unit. At the left side of that area there is a small lever with the magnet in it. Check if it moves smoothly. Vacuum clean everything around that lever. There can be some other reasons worth to check. I put them in this article: http://www.kudesnik.net/faq/mono/fm005.php It's all in Russian but using online translators and looking at the pictures you'll be able to catch the idea of what should be checked.
Jul 24, 2009 | OKI B4350 Laser Printer
I have Oki B4350 printer. The print on both edges
Depending on the age of the model, it could be a couple of things. ***Never touch the drum or expose it to bright light*** The drum unit is bad. It's the shiny brightly-colored large roller in the center of the machine. On most recent smaller machines like this on it's integrated into the toner cartridge. Check it out. If it has toner build up on the ends, it's bad. or The corona wires need cleaning. Some machines have a small slide that moves from one side of the printer to the other which cleans the hidden corona wires. It's usually brightly colored .
Jun 03, 2009 | OKI B4350 Laser Printer
Oki B4540 keeps saying
You should certainly start by looking at the toner cartridge to see if there is any tape to remove. If there is no tape with a visible pull tab, check inside the printer to make sure that there are no pieces of torn paper stuck anywhere inside.
May 05, 2009 | OKI B4350 Laser Printer
Drum change
Step 1. Open Top Cover.(Press the oval button RHFront)
Step 2. Tilt Drum Unit by lifting slightly at the front.(The Toner cartridge sits in the top of this)
Step 3. Remove Drum Unit by lifting straight up.
Step 4. Insert "NEW" Drum Unit. (Steps 3 and 2 in reverse order and direction(s))
May 19, 2008 | OKI B4350 Laser Printer
OKI PRINTER B4350
This sounds like it could be a "toner Sense" error / try removing the drum unit and cleaning the 6 contacts on the left inside of the printer
Apr 09, 2008 | OKI B4350 Laser Printer
Oki 9800 fatal error 230
No reset need to fix fault then clears...
Replace Toner Cartridges with Gen OKI new ones... are you using non oki product? Cause Toner carts, thats where I would start looking cause the error is the machine not receiving correct information from a little chip built into the toner cartridges to allow operation to begin.
Dec 07, 2007 | OKI 9800hdn Laser Printer
OKI Printer B4350
The Solution is:
You must have the Oki Monitor Software installed
When you enter in to the software you have a button that say "Maitenace", then you have a option that says " Reset Drum Counter" or somthing similar. Click on the option and the message disappear from the display.
Sorry my bad english
Nov 23, 2007 | OKI B4350 Laser Printer
Printing darker
charging connections are not properly connected
Sep 06, 2007 | OKI C5150n Led Printer
OKI B4350 Laser Printer Logo
504 people viewed this question
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
