Question about Yamaha RX-V430 Receiver
What is the possible problem if yamaha RX-V430 doesn't have a standby light?
guitarman002
  • 80 Answers
SOURCE: No test tone from subwoofer during balance testing Yamaha RX-V430
there's no test tone under normal use for the sub. It only shoud test the three front and two rear. ther' are disc you can use to test all the speakers. ( If you are into Pink Folyd, the movie The Wall has what you need to help balance the speakers
Posted on Jan 19, 2010
  • 19 Answers
SOURCE: remote does not operate receiver anymore. Changed
You could bring you remote control to have the crystal change inside or replace the remote control.
Spider Guy
Posted on Mar 15, 2010
ProColorTV
  • 25 Answers
SOURCE: need an drawing showing hou to connect yamaha rx-
Hell Fixya customer,
Here are two links for the Yamaha receiver, and the Sony user manuals.
Please look through them concerning your specific hookup. If you still have questions or need help, please let me know.
http://www2.yamaha.co.jp/manual/pdf/av/english/re/RX-V430e.pdf
http://www.sony.com.au/support/product/kdl-52z5500
Thank you for using Fixya
Posted on May 01, 2010
AJIN G
  • 6694 Answers
SOURCE: want to know if it
hi,
Only you can hear the record player through the aux of your amp if the record player comes with built in phono preamp. If not you need a phono preamp between the record player and amp or an amp which have a phono input. Phono preamp is available in the open market.
ok
Posted on May 22, 2011
  • 127 Answers
SOURCE: What is the best speaker volume settings for 5.1
As this receiver does not have automatic speaker calibration, you need to set the volumes manually. The best is if the left and right speakers are at the same distance from you (then their volumes can be equal). If one speaker is at more distance than the other, the volume must be higher for this speaker.
You can find instruction for volume setting at p. 21 of your receiver manual. There you can also find settings of the speaker mode - that depends on the specific speakers you have. You can define for each of 5 speakers if they are Large/Small/None (on this setting depends where will be the lowest bass tones directed).
Posted on Oct 21, 2013
Doesn't have HDMI
if it's an old unit pre hdmi you need to get a new receiver
Apr 12, 2014 | Yamaha RX-V430 Receiver
What is the best speaker volume settings for 5.1 system my receiver is Yamaha rx-v430 and room size is 15x20
Oct 20, 2013 | Yamaha RX-V430 Receiver
My yamaha RXV 430 doesnot start with standby button or remote. It is completely dead. The servicing agent changed a small circuit board behindd the transformer. After that it worked for a few days. Now...
It is possible that the amplifier had encountered a fault with a higher current drain which had triggered it to a protection fault condition. The fault can be your output drivers- the MOSFETS/IC's fitted for both the channels, Use a meter after disconnecting to check for short in the drivers. Disconnect the positive and negative voltages to the output and see if the protect changes. Even a fault in the preamp stages that drives in high current into the output can shut the Amplifier. Sometimes this can be a noise like a HUM or HISS before the protect works. Faulty capacitors in these circuits also can cause similar issues and needs close observation.
You need to confirm and replace the specific stages or outputs. If not there can be issues in the mother board, maybe the protect circuit by itself is shutting off due to a faulty bias , maybe a leak in any voltage/current sensing circuit. Also disconnect the speakers and test, if the protect is off then check for short on the speakers.
Jul 16, 2011 | Yamaha RX-V430 Receiver
Need an drawing showing hou to connect yamaha rx-
May 01, 2010 | Yamaha RX-V463 Receiver
Remote does not operate receiver anymore. Changed
Spider Guy
Mar 15, 2010 | Yamaha RX-V430 Receiver
What does it mean when it says small or large speaker setting for main center and surround speakers
If you select small, the receiver will send more bass to the subwoofer. Most people prefer more bass.
Hope this helps
Jan 20, 2010 | Yamaha RX-V430 Receiver
Jan 19, 2010 | Yamaha RX-V430 Receiver
Accoustimas 10 subwoofer problem
Make sure you have both the left and right front channels going into it.
Apr 26, 2008 | Bose Acoustimass 10 III System
Yamaha RX-V430 Receiver Logo
22 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
